uus teema   vasta Tarkvara »  Arvutimängude foorum »  Watch Dogs märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 37, 38, 39 ... 41, 42, 43  järgmine
antikondor
antikondor
sõnum 19.06.2014 15:15:28 vasta tsitaadiga
DefXtreme kirjutas:
PC peale tuleb patch paari päeva pärast!
MAJOR GAME FIXES
• Automatically reconstructed corrupted save files which prevented loading to go further than 90%. Some collectibles may remain unrecoverable.
• Fixed the issue preventing players from using hacks in game.
GAMEPLAY FIXES
• Fixed several mission-breaking bugs.
• Fixed minor mission and item-related issues.
• Fixed the issue that caused the empty weapon-wheel.
MULTIPLAYER FIXES
• Fixed several minor respawn issues.
• Fixed some connection and session joining issues.
PC SPECIFIC FIXES
• Fixed graphical glitches on Low & Medium settings.
• Fixed some crashes on SLI configurations.
• Implemented several performance improvements.
• Implemented a few control improvements.
• Fixed issues causing infinite messaging and timing-out when trying to access the Online Shop from the Extras Menu while Uplay is set to Offline mode.
• Fixed issues connecting to a Multiplayer game.
• Implemented several mouse modifications.
• Fixed “Drinking Game” control issue where wrong information was displayed when played with a gamepad.
• Fixed “Chess Game” control issue.
• Fixed bug where the invasion setting was never saved.
• Fixed graphical issues during cut scenes and cinematics.
• Fixed several graphical and texture bugs.
• Removed Vista OS check to prevent false positives.
• Added game version in main menu.
Kurask, Dolby digital live fix seal silma ei jää
Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
Braien
Braien
sõnum 19.06.2014 18:02:13 vasta tsitaadiga
olafsand kirjutas:
londiste, millised need hiire ikaldused on?
Ilmselt see, et menüüdes(telefon näiteks), liigub hiir väga kahtlaselt, ja väga tuntav accelration hiirel.
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 88
softis
softis
sõnum 19.06.2014 18:11:01 vasta tsitaadiga
Jep, see on räigelt tüütu.
Peamenüü on ilgelt turborežiim ja mängus sees telefonimenüüs ja weapon wheelis ei saa üldse aru loogikast. Vahel kihutab, vahel uimab täiega hiir.
sõnum 19.06.2014 18:18:18 vasta tsitaadiga
mitte ainult menüüdes.
accelerationi saab konfifailidest maha kiskuda, aga mingi imelik nõks ja ootamatud sensimuutused on aeg-ajalt sees.
- londiste
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
libe
kvaliteetne mees
libe
sõnum 19.06.2014 21:16:47 vasta tsitaadiga
patch on väljas
vähemalt mingit update mul tegi
sõnum 19.06.2014 21:32:48 vasta tsitaadiga
teeb küll.
sikutab mingi ~80mb juurde mängule.
- londiste
Dave20
sõnum 19.06.2014 22:45:50 vasta tsitaadiga
Patch ainult 80mb? Siis vist midagi erilist loota pole.
xxlmaster
xxlmaster
sõnum 19.06.2014 22:52:03 vasta tsitaadiga
Dave20 kirjutas:
Mees, see on patch mitte mingi DLC map pack.
LKits
LKits
sõnum 19.06.2014 22:53:07 vasta tsitaadiga
Tahtsin just sama öelda, et ega seal patchis pole mingeid tekstuure või kaarte. Paljud koodivead saab ju vähese andmemahuga parandatud.
Dave20
sõnum 19.06.2014 22:54:09 vasta tsitaadiga
Mäletan lihtsalt, et näiteks bf4 patchid olid ikka 300mb jne
xxlmaster
xxlmaster
sõnum 19.06.2014 23:33:08 vasta tsitaadiga
Dave20 kirjutas:
no need mängud on lihtsalt nii perses, et enam väiksematega ei saa hakkama.
Scart
Scart
sõnum 19.06.2014 23:55:16 vasta tsitaadiga
xxlmaster kirjutas:
Dave20 kirjutas:
no need mängud on lihtsalt nii <b>piixus</b>, et enam väiksematega ei saa hakkama.
Sinu arusaam mängude patchimisest on märkimisväärne.
Dave20
sõnum 20.06.2014 00:26:59 vasta tsitaadiga
Olgu kuidas on, aga kas oli siis see 80mb mängu patch ja läks midagi paremaks ka?
Scart
Scart
sõnum 20.06.2014 00:31:28 vasta tsitaadiga
Dave20 kirjutas:
Jõudlus on veel hullem ning hakib tuntavalt rohkem. Ubicrap nagu ikka.
libe
kvaliteetne mees
libe
sõnum 20.06.2014 00:31:55 vasta tsitaadiga
Dave20 kirjutas:
ei tea, mul on kõik puhas kuld olnud, kui välja jätta varjude vilkumine, kuid see on pigem mingi draiverite case
TauC
TauC
sõnum 20.06.2014 02:17:23 vasta tsitaadiga
libe kirjutas:
Dave20 kirjutas:
AMD seppade kannatused. Korralik protsessor ja nVidia kaart ning jookseb nagu siid.
Kommentaarid: 328 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 272
Dave20
sõnum 20.06.2014 02:50:34 vasta tsitaadiga
TauC, Mul ongi amd. Teised mängud jooksevad nagu siid, miks just see siis ei jookse? Inteli fanboy jälle...
Olen teinud mitmes mängus benchmark teste ja tulevad täpselt samad tulemused mis inteliga, kui youtubes vaadata.
TauC
TauC
sõnum 20.06.2014 08:53:45 vasta tsitaadiga
Dave20 kirjutas:
Mitte et ma Inteli fänn oleksin, kuigi eelistan, siis antud juhul on just neil probleemid, kellel on AMD protsessor, videokaart või mõlemad. Kodanikel Intel + nVidia kombinatsiooniga tundub ju kõik hästi olevat.
xxlmaster
xxlmaster
sõnum 20.06.2014 09:22:05 vasta tsitaadiga
Scart kirjutas:
xxlmaster kirjutas:
Dave20 kirjutas:
Ja sina oled endiselt nii märkimisväärselt juhm, et ei saa lihtlabasest lõõpimisest aru kopp.gif
kheelo
kheelo
sõnum 20.06.2014 11:33:58 vasta tsitaadiga
Peale viimast patchi töötab CF veel halvemini. Enne oli vähemalt kuskil linnamelust eemal olles korralik fps tõus, nüüd pole sedagi. Linnas sõites on madalam fps kui 1 kaardiga, samas seinast võtab 110 W rohkem icon_lol.gif . GG
sõnum 20.06.2014 14:55:07 vasta tsitaadiga
nüüd siis tuli mingi kiri, mis tervitas mind watch dogsi mängima ja teatas, et mu progress on 0 ja mänguaeg on 00:00:00.
gg.
ma olen lihtsalt kiire poiss. press q to hack game vms.
- londiste
libe
kvaliteetne mees
libe
sõnum 20.06.2014 17:52:22 vasta tsitaadiga
sai siis lõpuks story läbi tehtud
10 punkti
hea juhitavus masinatel ja mõnus suur linntegevust oli hoolega ja nii mõnigi kõrvalmissioonide lõpetamisega saadud skill oli vägagi abiks
algul küll häiris, et varjud vilguvad, kuid sellest sain lahti, kui gpu buffered frames madalamaks panin
Dave20
sõnum 20.06.2014 18:01:03 vasta tsitaadiga
lopes39, Mul on alati olnud AMD cpu arvutitel ja pole paranduses kordagi käinud, peale selle kui räägid siin 10 aastat tagasi, siis sellel ajal amd-le mängudes vastast polnud. Kui videokaardist rääkida, siis nvidea kaart on muidugi parem kui ati kaardid.
PS. Kui jälgida bf4 teemat, siis millegi pärast on seal mänguga probleem suurem osa inteli meestel, minul aga pole selle mänguga kunagi probleemi olnud, eriti kui sai win8 peale pandud.
Teemasse ka tagasi siis,
libe, kus see hea juhitavus autodel on? Nagu lendavad vaibad lendlevad ringi autod.
-Kaivo-
sõnum 20.06.2014 18:07:38 vasta tsitaadiga
Nöita mulle mängu, kus on parem juhitavus autodel. GTA 4 on täielik bs juhitavus. WD -s on autode juhitavus väga hea. Paljud Arcade mängud peaksid siit midagi õppima. CodeFail peaks juhitavus mudelid üle kopima.
Dave20
sõnum 20.06.2014 18:51:40 vasta tsitaadiga
GTA4 oli väga hea juhitavaus autodel ja gta5-s ka mida xboxil mängisin.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Watch Dogs mine lehele eelmine  1, 2, 3 ... 37, 38, 39 ... 41, 42, 43  järgmine
