praegune kellaaeg 24.10.2026 12:39:46
30.05.2012 04:12:30
Küberturbespetsialist viitab salajastele tagaustele Hiinas toodetud kiipides |
link :: minut.ee
Cambridge ülikooli arvutilabori küberturbespetsialist Sergei Skorobogatov on valmis saanud uurimuse, milles väidab, et Hiinas toodetud ümberprogrammeeritavad kiibid on salajaste tagaustega salamisi tarkvarakoodi lisamiseks. Taolisi vihjeid on teinud luureagentuurid üle maailma, kuid nüüd on väidetavalt õnnestunud see ka pildile tabada.
Uut tüüpi skänneritehnoloogia abil uuritud USA militaartööstusele mõeldud krüpteerimiskiip sisaldas varasemalt teadmata tagaust, mille võtme abil on võimalik kiip kasutuks muuta või isegi ümber programmeerida. Taolisi kiipe võib leida näiteks paljudest relvasüsteemidest ja aatomienergeetikaga seotud automaatikast. Seetõttu kardetakse, et Stuxneti "edasiarendus" peitub paljude riikide relvastuses ning ootab salamahti kellegi saadetud märguannet kaose vallandamiseks.
| Claims were made by the intelligence agencies around the world, from MI5, NSA and IARPA, that silicon chips could be infected. We developed breakthrough silicon chip scanning technology to investigate these claims. We chose an American military chip that is highly secure with sophisticated encryption standard, manufactured in China. Our aim was to perform advanced code breaking and to see if there were any unexpected features on the chip. We scanned the silicon chip in an affordable time and found a previously unknown backdoor inserted by the manufacturer. This backdoor has a key, which we were able to extract. If you use this key you can disable the chip or reprogram it at will, even if locked by the user with their own key. This particular chip is prevalent in many systems from weapons, nuclear power plants to public transport. In other words, this backdoor access could be turned into an advanced Stuxnet weapon to attack potentially millions of systems. The scale and range of possible attacks has huge implications for National Security and public infrastructure. |
EDIT: However, Robert Graham, of US security consultancy Errata Security, wrote yesterday that the backdoor is unlikely to have been added maliciously. He claims that the entry route discovered by Skorobogotov is likely to be a debugging tool deliberately installed by the manufacturer.
"It's remotely possible that the Chinese manufacturer added the functionality, but highly improbable. It's prohibitively difficult to change a chip design to add functionality of this complexity."
He also questioned the description of the chip as "military grade". "The military uses a lot of commercial, off-the-shelf products. That doesn't mean there is anything special about it."
Graham writes that the backdoor could pose a security threat, however. "It not only allows the original manufacturer to steal intellectual-property, but any other secrets you tried to protect with the original [encryption] key." |
7 :: |
364 |
Noname
30.05.2012 13:58:08
Serka on KGB poolt USAsse saadetud, et valeinfot tekitada
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
322 |
30.05.2012 17:42:53
Noname: Eks see selline vastastikune populaarne netiluuremäng ka on.
Alles hiljuti olid ju kaks infot liikvel, mis üsna hästi näitasid, millised netiluuremängu fännid USA-kad on:
1. Hillary Clinton isiklikult reklaamis ja kiitis, kui tore on netiluuremängu mängida.
2. Ning FBI lõi hiljuti netiluuremängude tarbeks lausa secretive Net-surveillance unit-i.
(Domestic Communications Assistance Center, which is tasked with developing new electronic surveillance technologies, including intercepting Internet, wireless, and VoIP communications.)
211 |
