praegune kellaaeg 13.11.2026 18:17:58
Kp
25.05.2012 20:55:17
Interneti ühendus koomas |
Tere
10 minuti eest muutus interneti ühendus hästi aeglaseks. Tegin arvutile restarti ja endiselt oli ühendus aeglane.
Seejärel üritasin ruuterile ligi pääseda, mis osutus ka võimatuks kuna ei saanud ühendust.
Samuti üritasin pingida ruuterit ja ükski pakett kohale ei jõunund.
Peale seda tegin ruuterile restarti ja õnnestus ligi saada.
wifi ruuteri mark on: wbr-3406tx
Kas keegi oskab kommenteerida mida need viimased read tähendavad, ja kas rünnak oli wifi võrgust thetud või kusagilt interneti avarustest
Logi fail on selline.
25. mai 2012. a. 21:39:04 Unrecognized attempt blocked from 88.164.181.194:58682 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:05 Unrecognized attempt blocked from 90.42.150.217:56956 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:05 Unrecognized attempt blocked from 90.184.81.33:11825 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:06 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:07 Unrecognized attempt blocked from 88.164.181.194:58682 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:07 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:07 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:07 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:07 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:08 Unrecognized attempt blocked from 90.42.150.217:56956 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:08 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:09 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:09 Unrecognized attempt blocked from 90.49.21.75:27404 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:10 Unrecognized attempt blocked from 88.164.181.194:58682 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:10 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:10 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:10 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:10 Unrecognized attempt blocked from 90.49.21.75:27404 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:11 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:12 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:12 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:12 Unrecognized attempt blocked from 90.49.21.75:27404 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:12 Unrecognized attempt blocked from 91.73.119.248:22109 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:12 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:13 Unrecognized attempt blocked from 86.184.221.193:51131 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:13 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:14 Unrecognized attempt blocked from 87.68.167.17:33254 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:14 Unrecognized attempt blocked from 90.42.150.217:56956 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:14 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:15 Unrecognized attempt blocked from 87.68.167.17:33254 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:15 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:15 Unrecognized attempt blocked from 91.73.119.248:22109 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:16 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:16 Unrecognized attempt blocked from 88.164.181.194:58682 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:16 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:16 Unrecognized attempt blocked from 90.184.81.33:11991 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:17 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:17 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:17 Unrecognized attempt blocked from 90.184.81.33:11991 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:17 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:18 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:18 Unrecognized attempt blocked from 90.49.21.75:27404 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:18 Unrecognized attempt blocked from 87.68.167.17:33254 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:19 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:19 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:19 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:19 Unrecognized attempt blocked from 90.184.81.33:11991 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:19 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:20 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:20 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:21 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:21 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:22 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:22 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:23 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:23 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:23 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:24 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:24 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:24 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:24 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 87.68.167.17:33254 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:25 Unrecognized attempt blocked from 90.184.81.33:11991 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:26 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:26 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:26 Unrecognized attempt blocked from 90.42.150.217:56956 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:27 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:28 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:28 Unrecognized attempt blocked from 88.164.181.194:58682 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:28 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:28 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:29 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:29 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:29 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:30 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:30 Unrecognized attempt blocked from 31.52.151.1:63112 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:30 Unrecognized attempt blocked from 90.49.21.75:27404 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:30 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:30 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:31 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:31 Unrecognized attempt blocked from 31.52.151.1:63112 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:31 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:31 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:32 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:32 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:33 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:33 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:33 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:34 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:34 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:34 Unrecognized attempt blocked from 31.52.151.1:63112 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:34 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:35 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 116.71.173.2:61831 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:36 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 88.170.196.103:25671 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 87.68.167.17:33254 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:37 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:38 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:38 Unrecognized attempt blocked from 90.184.81.33:12276 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:38 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 159.0.79.117:15843 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:39 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:40 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:40 Unrecognized attempt blocked from 31.52.151.1:63112 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:40 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:40 Unrecognized attempt blocked from 217.210.255.161:62790 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:40 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:41 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:41 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:41 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:41 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:41 Unrecognized attempt blocked from 2.180.59.76:49287 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 86.184.221.193:51131 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 187.57.112.243:63134 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:42 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:43 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:43 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:44 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:44 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:44 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:44 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:45 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:46 Unrecognized attempt blocked from 91.152.245.82:27409 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:46 Unrecognized attempt blocked from 86.184.221.193:51131 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:46 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:46 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:46 Unrecognized attempt blocked from 137.132.187.67:19469 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:47 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:47 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:47 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:48 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:48 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:48 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:48 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:49 Unrecognized attempt blocked from 137.132.187.67:19469 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:49 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:50 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:50 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:50 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:51 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:51 Unrecognized attempt blocked from 87.52.16.50:58946 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:52 Unrecognized attempt blocked from 86.184.221.193:51131 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:52 Unrecognized attempt blocked from 24.77.198.182:58357 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:52 Unrecognized attempt blocked from 31.52.151.1:63112 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 88.174.231.179:29416 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 87.58.8.34:44429 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:53 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:54 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:54 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:55 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:55 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:55 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:55 Unrecognized attempt blocked from 137.132.187.67:19469 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:56 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:56 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:56 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:57 Unrecognized attempt blocked from 87.5.103.176:26085 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:58 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:58 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:58 Unrecognized attempt blocked from 87.2.97.112:21101 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:58 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:39:59 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:00 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:00 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:00 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:00 Unrecognized attempt blocked from 130.204.241.174:20475 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:00 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:01 Unrecognized attempt blocked from 50.98.169.60:57649 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:01 Unrecognized attempt blocked from 93.137.50.129:54080 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:02 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:03 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:03 Unrecognized attempt blocked from 182.18.231.37:37778 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:03 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:03 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:03 Unrecognized attempt blocked from 86.137.182.185:45474 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:04 Unrecognized attempt blocked from 86.184.221.193:51131 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:04 Unrecognized attempt blocked from 93.137.50.129:50883 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:04 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:04 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:05 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:05 Unrecognized attempt blocked from 116.71.173.2:61831 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:05 Unrecognized attempt blocked from 211.30.106.10:60885 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:06 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:06 Unrecognized attempt blocked from 88.170.196.103:25671 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:06 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:06 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:06 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:07 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:07 Unrecognized attempt blocked from 180.151.94.245:19136 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:08 Unrecognized attempt blocked from 93.137.50.129:50883 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:08 Unrecognized attempt blocked from 137.132.187.67:19469 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:08 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:09 Unrecognized attempt blocked from 182.239.201.200:34837 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:09 Unrecognized attempt blocked from 116.71.173.2:61831 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:09 Unrecognized attempt blocked from 88.170.196.103:25671 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:10 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:10 Unrecognized attempt blocked from 93.137.50.129:50883 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:14 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:15 Unrecognized attempt blocked from 116.71.173.2:61831 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:15 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:15 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:16 Unrecognized attempt blocked from 88.170.196.103:25671 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:17 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:17 Unrecognized attempt blocked from 86.155.47.118:18078 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:17 Unrecognized attempt blocked from 88.184.212.218:12209 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:18 Unrecognized attempt blocked from 190.96.17.77:59775 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:19 Unrecognized attempt blocked from 188.177.231.143:26411 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:21 Unrecognized attempt blocked from 93.137.50.129:50883 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:26 Unrecognized attempt blocked from 93.124.243.59:23690 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:27 Unrecognized attempt blocked from 116.71.173.2:61831 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:28 Unrecognized attempt blocked from 88.170.196.103:25671 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:40:29 Unrecognized attempt blocked from 193.150.206.121:24234 to 89.235.215.175 UDP:59317
25. mai 2012. a. 21:42:43 Reassociated: 00-16-DC-6A-82-21 st=0
25. mai 2012. a. 21:42:46 Disassociated: 00-16-DC-6A-82-21 because WPA retey failed
25. mai 2012. a. 21:42:47 Reassociated: 00-16-DC-6A-82-21 st=0
25. mai 2012. a. 21:42:51 Disassociated: 00-16-DC-6A-82-21 because WPA retey failed
| Kommentaarid: 34 loe/lisa |
25.05.2012 21:21:47
Need on ju avalikud IP`d seega, mis sa ise arvad?
Aga rünnakuna see nüüd küll ei paista, äkki jooksutasid ruuteri hoopis torrentiga kooma?
196 |
HacaX
06.06.2012 04:26:33
Eelkõnelejaga nõustuks - nood blokeeritud UDP ühendused tunduvad torrentile viitavat (uTP prokoll mille uTorrenti autorid välja mõtlesid ning mis vaikselt on ka teistesse klientidesse levinud), viimane lõik tundub viitavat sellele et ühendust ei õnnestunud soovitud kujul uuendada.
Torrentikliendis ühendusi vähemaks (ja uTP võiks üldse kinni keerata), siis on ruutril ka piisavat resursse et netiühendut kiirena hoida ning sinupoolsele sisselogimisele korralikult reageerida.
| Kommentaarid: 24 loe/lisa |
22 |
