praegune kellaaeg 20.11.2026 13:13:40
spider364
21.05.2012 15:42:58
Flashchat error |
Ma arvan et seadetes on mingi blokk peale et saab rääkida vaid määratult.. Sest algul kui oled saad suhelda ja kõik korras. Mingi hetk kui palju räägid tuleks nagu blokk et näed mis kirjutatakse aga ei saa rääkida.. Ja kui jutuka valesti kinni paned mitu korda siis tuleb ette lõpuks kiri Ip connection limit exceeded mis tähendab et on mingi ühenduse connektion seadetes.. Otsisin aga ei leidnud seda scriptis üles
<?php
//error_reporting(E_ALL ^ E_NOTICE);
$GLOBALS['fc_config'] = array(
'backtimeOnLogin' => 0, //set to non-zero value to force loading previous messages since XXX minutes ago, upon login
'backtimeMax' => 0, //sets the maximum number of minutes the backtime command will serve up, use 0 to have no max.
'backMax' => 30, //sets the maximum number of lines the back command will serve up, use 0 to have no max.
'timeOffset' => 0, //sets server time offset (needed only to correct server timezone problem), minutes
'debug' => false, //set to true to run in debug mode
'version' => '4.5.7', //architecture release . feature release . patch release
'enableSocketServer' => false, //set to true to enable socket server - see online PDF docs for more details
'liveSupportMode' => false,//set to true to use chat in "Live Support" mode
'errorReports' => false,//set to true to enable error reports
'enableBots' => true, //set to true to enable Bots
'bot_ip' => '0.0.0.0', //virtual ip of bot
'hideSelfPopup' => false,//set to false to allow self popup menu
'showConfirmation'=> true, //set to true to allow confirmation popup window for admin (moderator)
'labelFormat' => "AVATAR[USER] TIMESTAMP: ", //possible values are any combinations of AVATAR, USER and TIMESTAMP
'timeStampFormat' => 'g:i a', //pattern for PHP date function
'loginsPerIP' => 50, // number of logins allowed per IP address
'disabledIRC' => '',// you can put list of IRC commands to disable here, like 'back,backtime'
'mods' => 'addbot,removebot,startbot,killbot', //Moderators Restrictions (which IRC commands are disabled for Moderators)
'modsAdminRestrictions'=> 'bots,uninstall,connections,users', //Moderators Restrictions in admin section (admin.php), like 'bots,uninstall,connections,users'
'maxMessageSize' => 100, //maximum input text size, # characters
'maxMessageCount' => 100, //maximum number of the messages stored in the chat log
'userListAutoExpand' => false, //if true user list opens all the rooms with users in them
'showLogoutWindow' => true, // if false, then use only the ....src=logout.php method, but do not use the popup method at all
'logoutWindowDisplayTime' => 3, // in seconds
'floodInterval' => 1, // in seconds, the amount of time that must pass before the user posts another message
'inactivityInterval' => 24*60*60, // in seconds, if a user has FlashChat open for 'inactivityInterval' seconds, but they
// do not type anything, then the user should be automatically logged-out of the chat
// Note 60*60 - one hour
'splashWindow' => false, //splash non active chat window when new message is received
//Rooms config
'defaultRoom' => 1, //primary key of room where all users go after login
'autoremoveAfter' => 30, //number of seconds before room is removed
'roomTitleFormat' => 'ROOM_LABEL - USER_COUNT', //format string for room title in userlist
'maxUsersPerRoom' => 50,
'listOrder' => 'MOD_STATUS', // options: AZ, ENTRY, MOD_THEN_AZ, MOD_THEN_ENTRY, STATUS, MOD_STATUS
// AZ = alphabetical order, A to Z
// ENTRY = by order of entry only
// MOD_THEN_AZ = same as AZ, but moderators at top
// MOD_THEN_ENTRY = same as ENTRY, but moderators at top
// STATUS = by order of 'status' (Here / Busy / Away / BRB)
// MOD_STATUS = same as STATUS, but moderators at top
//your CMS system
'CMSsystem' => 'defaultCMS',// defaultCMS - default CMS, blank - stateless CMS
//Some systems use UTF-8 encoding for user names. If you are using some CMS systems with non-English character sets, you may need to enable UTF-8 decoding for user names.
'loginUTF8decode' => true,// possible values - true, false
//option
'encryptPass' => 1,//option to encrypt user password for defaultCMS, can be 1 - encrypt and 0 - no encrypt
//motd & welcome message flags
'auto_motd' => 1, // 1 for on, 0 for off (on means it is displayed upon chat entry)
'auto_topic' => 1, // 1 for on, 0 for off (on means it is displayed upon room entry)
// Roles config
'adminPassword' => '', //allows any user to login as a administrator - stateless CMS mode only
'moderatorPassword' => '', //allows any user to login as a moderator - stateless CMS mode only
'spyPassword' => '', //allows any user to login as a spy - stateless CMS mode only
'layouts' => array(), // do not change this
//Sound config
'sound' => array(
'pan' => 0, // range from -100 to 100 (left ... right)
'volume' => 75, // default sound volume, in percent
'muteAll' => false, // true = checked by default, false = unchecked
'muteSubmitMessage' => false,
'muteReceiveMessage' => false,
'muteOtherUserEnters' => false,
'muteLeaveRoom' => false,
'muteRoomOpenClose' => false,
'muteInitialLogin' => false,
'muteLogout' => false,
'muteComboListOpenClose' => false,
'muteUserBannedBooted' => true,
'muteInvitationReceived' => false,
'mutePrivateMessageReceived' => false,
'muteUserMenuMouseOver' => false,
'mutePopupWindowOpen' => false,
'mutePopupWindowCloseMin' => false,
'muteEnterRoom' => true,
'mutePressButton' => true
//Themes config
'themes' => array(),
'defaultTheme' => 'tropical',
//Skins config (available skins in /inc/skins; example: 'defaultSkin' => <swf_name>)
'skin' => array(),
'defaultSkin' => 'xp_skin',
//Text config
'text' => array(
//defaults (presence : is that option visible or hiden)
'itemToChange' => array(
'myTextColor' => false,
'mainChat' => array( 'presence' => true, 'fontSize' => 13, 'fontFamily' => 'Arial'),
'interfaceElements' => array( 'presence' => true, 'fontSize' => 13, 'fontFamily' => 'Arial'),
'title' => array( 'presence' => true, 'fontSize' => 13, 'fontFamily' => 'Arial')
//posible values (to add new value just type something like this : 'itm10' => 25)
'fontSize' => array(
'itm0' => 8,
'itm1' => 9,
'itm2' => 10,
'itm3' => 11,
'itm4' => 12,
'itm5' => 13,
'itm6' => 14,
'itm7' => 16,
'itm8' => 18,
'itm9' => 20
'fontFamily' => array(
'itm0' => 'Arial',
'itm1' => 'Times',
'itm2' => 'Courier',
'itm3' => 'Verdana',
'itm4' => 'Georgia'
//Preloader config
'preloader' => array(
'text' => array(
'settings' => 'Laadin seadeid...',
'smilies' => 'Laadin smile...',
'mainchat' => 'Laadin jututub...',
'starting' => 'Systeem k2ivitub....',
'okText' => 'OK'
'fontFamily' => 'Verdana',
'fontSize' => '11',
'fontColor' => 0x000000,
'BGColor' => 0xFFFFFF,
'barColor' => 0x000000
//Language config. For some languages like Japanese or Chinese.
//This option allows ctrl+enter vs enter and always enables the send button.
'special_language' => array(
'itm0' => 'jp',
'itm1' => 'cn'
//Smile settings
//To disable any smilie, comment or delete the appropriate line.
'smiles' => array(
'smi_smile' => ':) :-)',
'smi_sad' => ':( :-(',
'smi_wink' => ';) ;-)',
'smi_laugh' => ':D :-D',
'smi_red' => ':red:',
'smi_tongue' => ':p :-p',
'smi_ask' => ':? :-?',
'smi_awe' => ':awe:',
'smi_baby' => ':baby:',
'smi_cool' => '8) 8-)',
'smi_evil' => ':evil:',
//'smi_finger' => ':finger:',
'smi_grin' => ':grin:',
'smi_heart' => ':heart:',
'smi_kiss' => ':kiss:',
'smi_newline' => ':break:',
'smi_ninja' => ':ninja:',
'smi_roll' => ':roll:',
'smi_roll_eyes' => ':rolleyes:',
'smi_slash' => ':! :-!',
'smi_sleep' => ':zzz:',
'smi_weird' => ':weird:',
'smi_whistle' => ':whistle:',
'smi_wonder' => '8s',
//addon 1
'smi_call' => ':call:',
'smi_cash' => ':cash:',
'smi_shock' => ':shock:',
'smi_check' => ':check:',
//addon 2
'smi_ball' => ':ball:',
'smi_clap' => ':clap:',
'smi_cry' => ':cry:',
'smi_luck' => ':luck:',
'smi_nono' => ':nono:',
'smi_punch' => ':Punch:',
'smi_skull' => ':skull:',
'smi_yeah' => ':yeah:',
'smi_yinyang' => ':69:',
//addon 3
'smi_earth' => ':earth:',
'smi_huh' => ':huh:',
'smi_hypno' => ':hypno:',
'smi_java' => ':java:',
'smi_no' => ':no:',
'smi_rain' => ':rain:',
'smi_rose' => ':rose:',
'smi_usa' => ':usa:',
//addon 4
'smi_big_grin' => ':biggrin:',
'smi_faint' => ':faint:',
'smi_ill_content' => ':mean:',
'smi_meow' => ':cat:',
'smi_thumbs_down' => ':down:',
'smi_thumbs_up' => ':up:',
'smi_woof' => ':dog:',
'smi_beer' => ':beer:',
'smi_music' => ':music:',
'smi_reading' => ':read:',
'smi_word_bubble' => ':speak:',
'smi_female' => ':female:',
'smi_female2' => ':ms:',
'smi_male' => ':male:',
'smi_male2' => ':mr:',
'smi_admin' => ':admin:',
'smi_moderator' => ':mod:',
'smi_basketball' => ':bball:',
'smi_bowling' => ':bowl:',
'smi_cricket' => ':cricket:',
'smi_football' => ':fball:',
'smi_golf' => ':golf:',
'smi_hockey' => ':hockey:',
'smi_sailing' => ':sail:',
'smi_soccer' => ':soccer:',
'smi_tennis' => ':tennis:',
'smi_AustraliaFlag' => ':au:',
'smi_Brazil' => ':br:',
'smi_CanadaFlag' => ':ca:',
'smi_China' => ':cn:',
'smi_Spain' => ':es:',
'smi_European_Union' => ':eu:',
'smi_France' => ':fr:',
'smi_Germany' => ':de:',
'smi_Greece' => ':gr:',
'smi_IndianFlag' => ':in:',
'smi_Italy' => ':it:',
'smi_Japan' => ':jp:',
'smi_MexicoFlag' => ':mx:',
'smi_PolandFlag' => ':pl:',
'smi_PortugalFlag' => ':pt:',
'smi_Russia' => ':ru:',
'smi_Sweeden' => ':se:',
'smi_UkraineFlag' => ':ua:',
'smi_UK' => ':uk:',
'smi_US_Map' => ':us:',
//Avatar settings
'avatars' => array(
'mod_only' => 'smi_admin,smi_moderator',
// for standard users (& customers, if using support mode)
'user' => array(
'male' => array(
'mainchat' => array(
'default_value' => 'smi_male', // a smilie code
'default_state' => false, // true = checked/on by default
'allow_override' => true, // if false, cannot be changed (combo box is disabled)
'room' => array(
'default_state' => true, // true = checked/on by default
'female' => array(
'default_value' => 'smi_female', // a smilie code
'room' => array(
// for administrators
'admin' => array(
'male' => array(
'default_value' => 'smi_admin', // a smilie code
'room' => array(
'female' => array(
'room' => array(
// for moderators
'moderator' => array(
'male' => array(
'default_value' => 'smi_moderator', // a smilie code
'room' => array(
'female' => array(
'room' => array(
//Message processing
'msgRequestInterval' => 3, //chat refresh time, seconds
'msgRequestIntervalAway' => 15, //chat refresh time in away state, seconds
//NOTE: it should not be bigger than a half of autologoutAfter
//otherwise your users risk being disconnected in away mode
'msgRemoveAfter' => 24*3600, //messages removed after this time, seconds
//Connection processing
'autologoutAfter' => 60, //time of pooling inactivity after which user is considered logged off, seconds
'autocloseAfter' => 3600,//time of pooling inactivity after which connection is removed from database, seconds
'helpUrl' => 'http://tufat.com/docs/flashchat/index.html', //you can use also help.php
//Ban processing
'autounbanAfter' => 36000, //time after user is un-banned, seconds
//Language options
'languages' => array(), //do not change this
'defaultLanguage' => 'et', //two-letter code of the default language (see below)
'allowLanguage' => true, //allow user to choose another language
'base' => '',
//Chat server options
'ChatOwner' => array(
1, // replace with your own values for user names
//2, // look in users table for these values
//3, // add extra lines if required, delete if you need less than 3 users in table
'commands' => array(
'showIP' => true, // show user IP and host at /who if set to true
'userPM' => true, // set to true to output list of user commands to a PM window, false to chat window
'adminPM' => true, // set to true to output list of moderator commands to a PM window, false to chat window
'maxRooms' => 50, // max number of Public Rooms
//external sound options
'sound_options' => array(
'RingBell' => 'sounds/tin_can.mp3',
'LeaveRoom' => 'sounds/door_shut.mp3',
'OtherUserEnters' => 'sounds/jetsons.mp3',
'ReceiveMessage' => 'sounds/aol_receive_message.mp3',
'SubmitMessage' => 'sounds/aol_send_message.mp3',
'RoomOpenClose' => 'sounds/_default.mp3',
'InitialLogin' => 'sounds/harp_cord.mp3',
'Logout' => 'sounds/high_low_chord.mp3',
'ComboListOpenClose' => 'sounds/mouse_over_6.mp3',
'UserBannedBooted' => 'sounds/chime.mp3',
'InvitationReceived' => 'sounds/three_notes.mp3',
'PrivateMessageReceived' => 'sounds/aol_receive_message.mp3',
'UserMenuMouseOver' => 'sounds/mouse_over_1.mp3',
'PopupWindowOpen' => 'sounds/air_swoosh_2.mp3',
'PopupWindowCloseMin' => 'sounds/mouse_over_2.mp3',
'EnterRoom' => 'sounds/ta_da.mp3',
'PressButton' => 'sounds/activate_button.mp3'
//File sharing options
// to disable file sharing, go to /inc/layouts/user.php and set allowFileShare to 'false'
'filesharing' => array(
'allowShareRoom' => false,//moderators can always share with all users in a room - this option is only for non-moderators
'allowShareChat' => false,//moderators can always share with all users in a chat - this option is only for non-moderators
'allowFileExt' => 'zip,rar,jpg,gif,sit,pdf',// allowed file extensions, comma separated (to allow all extensions set to '')
'maxFileSize' => 0.5*1024*1024,//max file size in bytes (2*1024*1024 equals 2 Mb)
'maxFileHoursLife' => 0.5, // time in hours to store the file on the server (file will be deleted after this time)
'avatarbgloading' => array(
'allowFileExt' => 'jpg,swf',// allowed file extensions, comma separated (to allow all extensions set to '')
'maxFileSize' => 0.5*1024*1024,//max file size in bytes (1024*1024 equals 1 Mb)
'maxFileHoursLife' => 24*31, // time in hours to store the file on the server (file will be deleted after this time)
'photoloading' => array(
'allowFileExt' => 'jpg,gif,png,swf',// allowed file extensions, comma separated (to allow all extensions set to '')
'maxFileSize' => 0.1*1024*1024,//max file size in bytes (1024*1024 equals 1 Mb)
//Logout behavior
'logout' => array(
'close' => false, // if true, then FlashChat window is closed upon logout
'redirect' => false, // redirectURL must be a valid URL
'url' => 'http://www.tufat.com/chat.php', // 'redirect' must be set to true for this to work
'window' => '_blank', // the window to open into. possible values: _blank, _self, _parent, or a named window
//module settings (anchored SWF/JPG file)
//banner.swf is a simple Flash banner ad, moduleText.swf is an advanced module with bi-directional communication between FlashChat and the module
'module' => array(
'anchor' => '0',//the anchor point: -1,0,1,2,3 or 4 (0=centered,1-4=corners of space below roomlist) + 5-12 points
//anchor of -1 means that module will occupy a floating window (not anchored with flashchat template)
'path' => '',//set to '' to disable. To see how this works, use 'banner.swf' or 'moduleTest.swf'
'stretch' => 'true',// if true, anchored SWF is stretched horizontally & vertically to fill all available space
'float_x' => '300', // the default "x" position of the floating window (when anchor = -1)
'float_y' => '200', // the default "y" position of the floating window (when anchor = -1)
'float_w' => '200', // the default width of the floating window (when anchor = -1)
'float_h' => '300', // the default height of the floating window (when anchor = -1)
// This 'module' block demonstrates how to load two modules simultaneously
'module' => array(
'anchor' => '0,-1',//the anchor point: -1,0,1,2,3 or 4 (0=centered,1-4=corners of space below roomlist) + 5-12 points
'path' => 'modules/mp3_player/mp3player.swf,modules/mp3_player/mp3player.swf',//set to '' to disable. To see how this works, use 'banner.swf' or 'moduleTest.swf'
'stretch' => 'true,true',// if true, anchored SWF is stretched horizontally & vertically to fill all available space
'float_x' => '300,300', // the default "x" position of the floating window (when anchor = -1)
'float_y' => '200,200', // the default "y" position of the floating window (when anchor = -1)
'float_w' => '300,300', // the default width of the floating window (when anchor = -1)
'float_h' => '300,300', // the default height of the floating window (when anchor = -1)
if(!$GLOBALS['fc_config_stop'])
require_once(INC_DIR . 'flashChatTag.php');
require_once(INC_DIR . 'layouts/admin.php');
require_once(INC_DIR . 'layouts/moderator.php');
require_once(INC_DIR . 'layouts/spy.php');
require_once(INC_DIR . 'layouts/user.php');
require_once(INC_DIR . 'layouts/customer.php');
//SKINS: To disable a skin, comment or delete the appropriate line
require_once(INC_DIR . 'skins/default_skin.php');
require_once(INC_DIR . 'skins/xp_skin.php');
require_once(INC_DIR . 'skins/aqua_skin.php');
require_once(INC_DIR . 'skins/gradient_skin.php');
//THEMES: To disable a color theme, comment or delete the appropriate line
require_once(INC_DIR . 'themes/xp.php');
require_once(INC_DIR . 'themes/macintosh.php');
require_once(INC_DIR . 'themes/gradient.php');
require_once(INC_DIR . 'themes/navy.php');
require_once(INC_DIR . 'themes/metallic.php');
require_once(INC_DIR . 'themes/tropical.php');
require_once(INC_DIR . 'themes/aqua.php');
require_once(INC_DIR . 'themes/olive.php');
require_once(INC_DIR . 'themes/pink.php');
require_once(INC_DIR . 'themes/oak.php');
require_once(INC_DIR . 'themes/black.php');
//LANGUAGES: To disable a language, comment or delete the appropriate line
require_once(INC_DIR . 'langs/et.php'); //Eesti
require_once(INC_DIR . 'langs/en.php'); //English
require_once(INC_DIR . 'langs/gm.php'); //German
require_once(INC_DIR . 'langs/si.php'); //Spanish - Informal
require_once(INC_DIR . 'langs/sf.php'); //Spanish - Formal
require_once(INC_DIR . 'langs/du.php'); //Dutch
require_once(INC_DIR . 'langs/it.php'); //Italian
//require_once(INC_DIR . 'langs/sv.php'); //Sweedish
require_once(INC_DIR . 'langs/gr.php'); //Greek
require_once(INC_DIR . 'langs/ru.php'); //Russian
require_once(INC_DIR . 'langs/ua.php'); //Ukrainian
require_once(INC_DIR . 'langs/he.php'); //Hebrew
require_once(INC_DIR . 'langs/ar.php'); //Arabic
require_once(INC_DIR . 'langs/tr.php'); //Turkish
require_once(INC_DIR . 'langs/ro.php'); //Romanian
//require_once(INC_DIR . 'langs/bg.php'); //Bulgarian
require_once(INC_DIR . 'langs/pt.php'); //Portugal Portuguese
require_once(INC_DIR . 'langs/br.php'); //Brazilian Portuguese
require_once(INC_DIR . 'langs/fr.php'); //French
require_once(INC_DIR . 'langs/lt.php'); //Lithuanian
require_once(INC_DIR . 'langs/pl.php'); //Polish
require_once(INC_DIR . 'langs/no.php'); //Norweigan
require_once(INC_DIR . 'langs/da.php'); //Danish
require_once(INC_DIR . 'langs/hu.php'); //Hungarian
require_once(INC_DIR . 'langs/fi.php'); //Finnish
require_once(INC_DIR . 'langs/sk.php'); //Slovak
require_once(INC_DIR . 'langs/cz.php'); //Czech
require_once(INC_DIR . 'langs/hr.php'); //Croatian
require_once(INC_DIR . 'langs/th.php'); //Thai
require_once(INC_DIR . 'langs/jp.php'); //Japanese
require_once(INC_DIR . 'langs/tw.php'); //Chinese (BIG-5)
require_once(INC_DIR . 'langs/cn.php'); //Chinese (GB)
require_once(INC_DIR . 'langs/hi.php'); //Hindi
require_once(INC_DIR . 'langs/kl.php'); //Klingon (fictional language)
require_once(INC_DIR . 'langs/pg.php'); //Pig Latin (fictional language)
Arvan et peaks olema siin ehk siis confic failis
