praegune kellaaeg 18.11.2026 02:38:18
raitl
18.05.2012 10:21:15
Andke abi MySQL query ja matemaatikaga |
Üks veidi põhjalikum query on koos oma matemaatikaga mind nurka surunud. Ehk viitsib keegi aidata.
Ülesande püstitus:
Wordpressi postidel on lisatud custom post metana geo_latitude ja goe_longitude väljadesse koordinaadid. Nüüd on vaja otsida kõik postitused, mis jäävad etteantud koordinaatidest X raadiusesse.
Tabelid:
CREATE TABLE IF NOT EXISTS `wp_posts` (
`ID` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
`post_author` bigint(20) unsigned NOT NULL DEFAULT '0',
`post_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
`post_date_gmt` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
`post_content` longtext NOT NULL,
`post_title` text CHARACTER SET utf8 COLLATE utf8_estonian_ci,
`post_excerpt` text NOT NULL,
`post_status` varchar(20) NOT NULL DEFAULT 'publish',
`comment_status` varchar(20) NOT NULL DEFAULT 'open',
`ping_status` varchar(20) NOT NULL DEFAULT 'open',
`post_password` varchar(20) NOT NULL DEFAULT '',
`post_name` varchar(200) NOT NULL DEFAULT '',
`to_ping` text NOT NULL,
`pinged` text NOT NULL,
`post_modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
`post_modified_gmt` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
`post_content_filtered` text NOT NULL,
`post_parent` bigint(20) unsigned NOT NULL DEFAULT '0',
`guid` varchar(255) NOT NULL DEFAULT '',
`menu_order` int(11) NOT NULL DEFAULT '0',
`post_type` varchar(20) NOT NULL DEFAULT 'post',
`post_mime_type` varchar(100) NOT NULL DEFAULT '',
`comment_count` bigint(20) NOT NULL DEFAULT '0',
PRIMARY KEY (`ID`),
KEY `post_name` (`post_name`),
KEY `type_status_date` (`post_type`,`post_status`,`post_date`,`ID`),
KEY `post_parent` (`post_parent`),
KEY `post_author` (`post_author`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 AUTO_INCREMENT=7082 ;
-- Tabeli andmete salvestamine `wp_posts`
INSERT INTO `wp_posts` (`ID`, `post_author`, `post_date`, `post_date_gmt`, `post_content`, `post_title`, `post_excerpt`, `post_status`, `comment_status`, `ping_status`, `post_password`, `post_name`, `to_ping`, `pinged`, `post_modified`, `post_modified_gmt`, `post_content_filtered`, `post_parent`, `guid`, `menu_order`, `post_type`, `post_mime_type`, `comment_count`) VALUES
(7016, 1, '2012-05-17 12:12:48', '2012-05-17 10:12:48', '<ul><li><strong>Piirkond:</strong> Põlvamaa</li><li><strong>Ala nimetus:</strong> Räpina-Värska puhkeala</li><li><strong>Osaala:</strong> Räpina osaala</li><li><strong>Asukoht:</strong> Toolamaal, Räpina vallas, Põlvamaal. Regio atlas lk 85 G4, puhkeala kaardil objekt nr 9.</li><li><strong>Koordinaadid:</strong> Long-Lat WGS 84 x:27.373850 y:58.093581</li><li><strong>:</strong> L-EST 97 x:698897 y:6444161</li><li><strong>Parkimisvõimalused:</strong> Kaljupealse lõkkekoha juures ruumi 5-6 autole</li><li><strong>Varustus:</strong> Matkarada on tähistatud viitadega ja 12 huvipunkti kirjeldusega. Rada on metsandusliku sisuga, tutvustatakse erinevaid metsatöid. Rada on võimalik läbida jalgsi, rattaga ja talvel lumega ka suuskadega. </li><li><strong>Telkimisvõimalus:</strong> on</li><li><strong>Kattega lõkkekoht:</strong> on</li><li><strong>Marjad-seened:</strong> mustikad, pohlad, seened</li><li><strong>Talvine kasutus:</strong> Talvel kasutatav suusarajana.
</li></ul> [gallery link="file"] ', 'Võhandu matkarada (6,6 km)', '', 'publish', 'closed', 'open', '', 'vohandu-matkarada-66-km', '', '', '2012-05-17 12:12:48', '2012-05-17 10:12:48', '', 0, 'http://kalakoht.ee/poi/vohandu-matkarada-66-km/', 0, 'poi', '', 0); |
CREATE TABLE IF NOT EXISTS `wp_postmeta` (
`meta_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
`post_id` bigint(20) unsigned NOT NULL DEFAULT '0',
`meta_key` varchar(255) DEFAULT NULL,
`meta_value` longtext,
PRIMARY KEY (`meta_id`),
KEY `post_id` (`post_id`),
KEY `meta_key` (`meta_key`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 AUTO_INCREMENT=29899 ;
-- Tabeli andmete salvestamine `wp_postmeta`
INSERT INTO `wp_postmeta` (`meta_id`, `post_id`, `meta_key`, `meta_value`) VALUES
(29647, 7016, 'geo_latitude', '58.0935822'),
(29648, 7016, 'geo_longitude', '27.3738499'); |
Ja selline oli minu query see hetk, kui juhe kapitaalselt kokku jooksis:
SELECT pmone.post_id, p.post_type, pmone.meta_value
AS geo_lat, pmtwo.meta_value
AS geo_long,(
SELECT (sqrt( sqrt((pmone.meta_value - pmsubone.meta_value) * 40076000) / 360) + sqrt((pmtwo.meta_value - pmsubtwo.meta_value) * 40076000 * cos((pmone.meta_value + pmsubone.meta_value)/2) / 360) )
FROM `wp_postmeta`
AS pmsubone
LEFT JOIN `wp_postmeta`
AS pmsubtwo
ON pmsubone.post_id = pmsubtwo.post_id
LEFT JOIN `wp_posts`
AS p
ON p.ID = pmsubone.post_id
WHERE pmsubone.meta_key = 'geo_latitude'
AND pmsubtwo.meta_key = 'geo_longitude'
AND p.post_type = 'water' LIMIT 1)
AS waters
FROM `wp_postmeta`
AS pmone
AS pmtwo
ON pmone.post_id = pmtwo.post_id
AS p
ON p.ID = pmone.post_id
WHERE pmone.meta_key = 'geo_latitude'
AND pmtwo.meta_key = 'geo_longitude'
AND p.post_type = 'poi' |
| Kommentaarid: 166 loe/lisa |
147 |
kullar
18.05.2012 10:41:27
Kunagi tegin ühe projekti, kus oli vaja tööpakkumisi otsida raadiuse järgi(ehk kui kaugele jääb minust mingi tööpakkumine kaardil) päringus arvutasin kuidagi nii:
SELECT osa, et saada kätte kaugus
$_strSel = "(3959 * acos(
cos(
radians('{$_arrLatitudes['lat']}')
cos(
radians(l.lat)
cos(
radians(l.lng) - radians('{$_arrLatitudes['lng']}')
sin(
) * sin(
radians(l.lat)
) AS distance";
ja mySQL WHERE oli selline:
HAVING distance <= $_intDistance";
_________________ Online Perekonna Eelarve, Keerukamad veebipõhised infosüsteemid jms |
| Kommentaarid: 28 loe/lisa |
25 |
Ho Ho
87 |
raitl
18.05.2012 10:47:44
| Ho Ho, jõudlus pole antud hetkel oluline. Tegu on conversion scriptiga, ehk siis ainult üks kord vaja käima lasta ja andmed ära töödelda.
147 |
jnt
18.05.2012 11:00:43
Konkreetselt igat sulgu läbi ei käinud, kuid kas pütaagoruse teoreem ei kõlba antud juhul? Absoluutväärtused kahe punkti x ja y kordinaatide vahest, need ruutu ja siis ruutjuur ja saad kauguse. Pikkus ja laius on ju tegelikult x ja y kordinaadid.
108 |
Fukiku
18.05.2012 11:39:16
| jnt kirjutas: |
| Konkreetselt igat sulgu läbi ei käinud, kuid kas pütaagoruse teoreem ei kõlba antud juhul? Absoluutväärtused kahe punkti x ja y kordinaatide vahest, need ruutu ja siis ruutjuur ja saad kauguse. Pikkus ja laius on ju tegelikult x ja y kordinaadid. |
Päris nii lihtne see pole. Oleneb soovitavast täpsusest. Katsetasin mingit netist kättesaadava kalkulaatoriga ja leidsin, et üks kraad koordinaatides ida-läänes suunas on Põhja-Eestis ~2,5km lühem kui Lõuna-Eestis. (Pildid spoileris)
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
| Kommentaarid: 85 loe/lisa |
kullar
18.05.2012 11:49:52
Täpsustan enda näidet:
SELECT id, ( 3959 * acos( cos( radians(37) ) * cos( radians( lat ) ) * cos( radians( lng ) - radians(-122) ) + sin( radians(37) ) * sin( radians( lat ) ) ) ) AS distance
FROM askohad HAVING distance < 25 ORDER BY distance LIMIT 0 , 20;
Selgituseks:
37 ja -122 on sinu asukoht ja lat,lng on andmebaasis olevad väljad.
3959 = miilid
6371 = km[/code]
25 |
raitl
18.05.2012 11:54:16
Lahendus käes. Komistasin sellise dokumendi otsa: http://www.scribd.com/doc/2569355/Geo-Distance-Search-with-MySQL
Tulemuseks selline query:
SELECT p.ID, p.post_title, (( ACOS( SIN( ".$latitude." * PI() / 180 )
* SIN( `latitude`.`meta_value` * PI() / 180 )
+ COS( ".$latitude." * PI() / 180 )
* COS( `latitude`.`meta_value` * PI() / 180 )
* COS(( ".$longitude." - `longitude`.`meta_value` ) * PI() / 180 )) * 180 / PI() ) * 60 * 1.1515 ) AS distance
FROM wp_posts p
LEFT JOIN wp_postmeta latitude ON latitude.post_id = p.ID AND latitude.meta_key = 'geo_latitude'
LEFT JOIN wp_postmeta longitude ON longitude.post_id = p.ID AND longitude.meta_key = 'geo_longitude' HAVING distance < 10 |
Ja toimib. tänud kaasamõtlejatele
147 |
Ho Ho
18.05.2012 12:28:06
Maa ei ole kerakujuline
Vahepeal sonari softi kirjutades tuli sellega arvestada kuna muidu läksid koordinaadid kiiresti metsa poole.
87 |
18.05.2012 12:54:24
| Ho Ho, seal artiklis on ka vastavad viited abistamaks täpsemat arvutamist.
jnt
18.05.2012 13:08:32
| Fukiku kirjutas: |
| jnt kirjutas: |
Good point! On jah tegelikult ju nii.
108 |
