praegune kellaaeg 13.11.2026 06:06:26
real
22.04.2012 15:11:23
Pärast renderdamist: roheline triip ääres |
Pärast sony vegas 10 renderdamist tuleb sellinne roheline joon paremale ja alla serva. Olen ka varem videosi teinud, kuid siis pole sellist asja olnud. Keegi oskab kommenteerida? Sõbra arvutis näitab samuti seda triipu.
Enne renderdamist:
General
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 195 MiB
Duration : 47s 422ms
Overall bit rate : 34.6 Mbps
Encoded date : UTC 2012-04-14 01:20:44
Tagged date : UTC 2012-04-14 01:20:44
CNTH : £røÊ'N’ ;€Nòxnñº¿OŸÛ-w×I§k¸µëÂ6"/.(s%î‰_üØÀ(GkÄ;ÞP»(6ȼ,É.~ÈIÜm
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 33.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.664
Stream size : 187 MiB (96%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 534 MiB
Duration : 5mn 3s
Overall bit rate mode : Variable
Overall bit rate : 14.8 Mbps
Encoded date : UTC 2012-04-16 23:40:51
Tagged date : UTC 2012-04-16 23:40:51
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=12
Codec ID : avc1
Duration : 5mn 3s
Bit rate mode : Variable
Bit rate : 14.6 Mbps
Maximum bit rate : 16.0 Mbps
Width : 1 904 pixels
Original width : 1 920 pixels
Height : 1 072 pixels
Original height : 1 080 pixels
Original display aspect ratio : 16:9
Original frame rate : 24.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.298
Stream size : 527 MiB (99%)
Language : English
| Kommentaarid: 9 loe/lisa |
9 |
Seidy
23.04.2012 08:54:48
meenub nagu oleks endal ka mingi sarnane jama olnud vegasega... tol ajal sai vist probleem lahenduse nii, et lasin mingis teises formaadis välja.
hmm.. kui praegu andmeid vaadata, mis sa postitasid, siis hakkavad silma mõõtmed:
olavsu1
külaline
29.04.2012 01:54:40
| Kas proovitarkvara või originaal? Seliseid lisandusi (triip kuskil või mõni nurk rohelise latakakga kaetud) on esinenud proovitarkvaraga ja lahti häkitud proovitarkvaraga. meenub et üks tasuline koodek tegi samasugust nalja, kui litsents aegus või prooviaeg läbi sai.
