praegune kellaaeg 01.10.2026 13:00:37
nah
06.04.2012 00:01:40
HV-s id-kaardiga autentimine |
Annab sellise errori:
Certificate-based authentication failed
This server requires a certificate for authentication, and didn't accept the one sent by the browser. Your certificate may have expired, or the server may not trust its issuer. You can try again with a different certificate, if you have one, or you may have to obtain a valid certificate from elsewhere.
Error 117 (net::ERR_BAD_SSL_CLIENT_AUTH_CERT): Bad SSL client authentication certificate.
Sertifikaadid on kehtivad
142 |
| Kommentaarid: 759 loe/lisa |
569 |
