uus teema   vasta Hinnavaatlus »  Üldfoorum »  HV-s id-kaardiga autentimine märgi kõik teemad loetuks
nah
nah
sõnum 06.04.2012 00:01:40 HV-s id-kaardiga autentimine vasta tsitaadiga
Annab sellise errori:
Certificate-based authentication failed
This server requires a certificate for authentication, and didn't accept the one sent by the browser. Your certificate may have expired, or the server may not trust its issuer. You can try again with a different certificate, if you have one, or you may have to obtain a valid certificate from elsewhere.
Error 117 (net::ERR_BAD_SSL_CLIENT_AUTH_CERT): Bad SSL client authentication certificate.
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 142
sõnum 06.04.2012 00:12:58 vasta tsitaadiga
Mõned read ülevalpool: https://foorum.hinnavaatlus.ee/viewtopic.php?t=351283
Kommentaarid: 761 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
