praegune kellaaeg 12.11.2026 21:41:28
M|a|D
28.02.2012 18:24:59
silicon power penmem/memstick write protected |
Mida muffi, 4gb silicon power ilma lock nuputa variant, ei lase järsku midagi kirjutada, proovisin ka netist lahendust otsida... ei midagi
proovitud format win7 alt - ei write protected
mingi regedit varient - ei
lowlevel format mälupulgale ei lase ikkagi
mida veel, lambist läks lolliks
| Kommentaarid: 53 loe/lisa |
46 |
svenman
01.03.2012 07:23:08
Allikas: http://www.tomshardware.co.uk/forum/264557-14-remove-write-protect-flash-memory-silicon-power
Remove USB Memory Stick Write Protected:
How to remove a write protection from your USB memory Stick
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (F8) key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Note:
Before removing USB from your computer, Always remove it safely by going into to my computer then right click on USB and click eject.
| Kommentaarid: 80 loe/lisa |
71 |
M|a|D
11.05.2012 09:35:40
ütles ikka write protected
ega lõppeski ära peale 2x full formaati, pidas täpselt 2a
46 |
