v2hja
17.08.2003 14:12:06
Kuidas muuta recycle bin nime (õpetus) |
nt "outhouse"
To do this, we're going to use the Registry Editor. Always back up your data before you use RegEdit. If you mess up, you can screw yourself. Honestly. Proceed with care.
Open RegEdit by typing "regedit" (without quotes) in the Run menu.
Open the "HKEY_CLASSES_ROOT" folder.
Open the "CLSID" folder.
Look for the folder within the brackets that starts with {645FF and open it.
Here's the full code:
{645FF040-5081-101B-9F08-00AA002F954E}
This long garble is the Recycle Bin's global unique identifier. All system file folders have 'em.
Double-click Shellfolder.
On the right side, find Attributes. Right-click Attributes and click Modify.
Change the binary value data from default 40 01 00 20 to 70 01 00 20.
Click OK and exit RegEdit.
Now, your Recycle Bin still can't be renamed by right-clicking alone (unless you're using Windows 98 ), but when you right-click and choose Explore, you can now modify it from the File menu! Voila!
Oh, and you now also have the option to delete your Recycle Bin, which isn't as dramatic as it sounds. You can still find your files in C:Recycled, and you can empty your trash from Explorer if you wish.
edit: http://www.techtv.com/screensavers/downloadoftheday/story/0,24330,3492956,00.html
_________________ www.ninjatune.net
RIP Monkey Radio
viimati muutis v2hja 17.08.2003 14:15:58, muudetud 2 korda |
| Kommentaarid: 74 loe/lisa |
60 |
Hiid
17.08.2003 14:14:11
Miks sa vahepeal inglise keelele üle läksid?
Või Copysid selle kusagilt?
Sel juhul oleks ilus viide ka siia panna.
| Kommentaarid: 664 loe/lisa |
512 |
veiks
17.08.2003 14:23:51
| viide on ju olemas
| Kommentaarid: 9 loe/lisa |
carramba
läburaator
17.08.2003 14:24:33
| veiks kirjutas: |
| viide on ju olemas |
irwe
vaadates editimise kellaaega
_________________ he came,he got banned,he logged out - R.I.P |
| Kommentaarid: 53 loe/lisa |
37 |
Lond
18.08.2003 06:12:53
| Lihtsam oleks W98 run-regedit-F3-Recycle Bin-enter-F3(esimese korraga ei tule)-enter-muuda nimi milleks tahad-enter
| Kommentaarid: 15 loe/lisa |
14 |
tommionu
tubli telepoiss
20.08.2003 21:07:47
| Lond kirjutas: |
| Lihtsam oleks W98 run-regedit-F3-Recycle Bin-enter-F3(esimese korraga ei tule)-enter-muuda nimi milleks tahad-enter |
2k puhul see ei aita kindlasti kohe (järgi proovitud) ja XP suhtes ka ei ole kindel ...
| Kommentaarid: 39 loe/lisa |
37 |
TzigaLind
23.08.2003 02:52:14
Kui register on moditud siis peab exploreri enne restartima kui nime saab muuta.(Task Manager abiks kui rebuutida ei viitsi)
_________________ Piix! |
| Kommentaarid: 16 loe/lisa |
14 |
