Dude .
21.08.2010 10:18:37
[X360/PS3] Portal 2 |
Portal 2
- Koduleht: Siin
- Arendaja: Valve
- Väljaandja: Valve
- Stiil: FPS Puzzle
- Väljalaske kuupäev: 2010 lõpp
- Kirjeldus:
- Portal was a 'trial'. Size and assets specifically kept minimal. Had no idea it would be this popular.
- Portal was a 'test bed', Portal 2 is a 'game'.
- GlaDOS returns as the antagonist.
- Chell returns, and we play as her.
- Portal 2 takes place a long time after the original. Hundreds of years, in fact. The complex has overgrown.
- Those orbs seen at the end of Portal are personality orbs. They've cornered off sections of the labs as their own, and are concerned about the decaying state of the complex.
- The opening sounds **** awesome. Im a bit **** I spoiled it for myself.
- Portal gun remains unchanged.
- Physics will now be part of portal puzzle solving. EG: A vent that sucks air in can be combined with a portal to 'suck' from a different location.
- "Paint" mechanic, various liquid substances that cause some reaction. For example, in the demo shown a orange substance on the floor caused Chell to be propelled upwards. Using portals you can apply these 'paints' to other areas of the level for puzzle solving.
- Reflection cubes will allow Chell to reflect lazers for various puzzles.
- The co-op campaign will have you playing as two bipedal robots. The like to hold hands.
- Splitscreen for people playing on the console, and 'picture in picture' available for those playing remote co-op (eg: PC). This allows you to easily communicate with the other player and combine efforts for puzzle solving.
Multiplayer: Jah
Uudised ja eelvaade: IGN
Videod: Gametrailers
| Kommentaarid: 16 loe/lisa |
16 |
S.I.L.L.U
21.04.2011 23:44:15
Sai just single läbi tehtud ja väga mõnus
Story ning tegelaste vestlus on väga naljakas/huvitav ning igast küljest hoolikalt läbi mõeldud
Mõni "test" pani ikka vahepeal korralikult mõtlema aga ei midagi lahendamatut
Häirisid natuke loading kohad peale igat test ruumi....suht vahet polnud kas oli väga pirakas või väike ruum - tüütu.
Huvipärast proovin esimese osa (PC) ka nüüd ära
94 |
beastbeats
22.04.2011 10:18:40
Kas nii lühike, et juba läbi
M: Shimano XT kiirkinnitused (uued) - 2tk/15€ |
| Kommentaarid: 370 loe/lisa |
286 |
S.I.L.L.U
24.04.2011 00:58:13
Eks ta mingi 6h kestis minu jaoks
94 |
kriist
24.04.2011 18:56:52
| Kas PS3 omad saavad PC versiooni ka kaasa?
93 |
estplayer
24.04.2011 19:10:39
| Tundub nii.
| Kommentaarid: 30 loe/lisa |
26 |
Goon
24.04.2011 19:15:27
| kriist kirjutas: |
| Kas PS3 omad saavad PC versiooni ka kaasa? |
Jep. Kui sa ostad PS3 versiooni siis sa saad PC peal ka seda mängida läbi steami. PC mängijad mängivad coop´i koos ka PS3 mängijatega ehk cross platform tugi
kriist
24.04.2011 19:17:22
Kena!
Kellelgi voucher üle? Võtaks ära.
93 |
angel
24.04.2011 20:50:26
peaks saama mingi koodi kui sa seod oma psn kasutaja steam kasutajaga ära .. seega vaevalt keegi oma koodi sulle anda sooviks.
157 |
kriist
24.04.2011 21:37:02
Ega ma niisama loodagi, ikka õiglase tasu eest.
Vaatasin, et ebays neid koode palju müügil aga ei soovi eriti sealt sebima hakata ja loodan, et kellelgi siin pakkuda.
93 |
EvilKatarn
diivanilill
25.04.2011 07:08:24
| Seda PS3'ga saadavat ekstra koopiat sa enda steami kontole küll ei saa. PS3's logid oma steami sisse ja siis sinna samale kontole tekib ka PC Portal 2. Mingit koodi vms asja, millega peaks saama seda teisele anda, ei ole.
| Kommentaarid: 111 loe/lisa |
kriist
25.04.2011 08:17:49
| EvilKatarn kirjutas: |
| Mingit koodi vms asja, millega peaks saama seda teisele anda, ei ole. |
Mis asja siis ebays müüakse? Õhku?
Link
93 |
asdasd
| Kommentaarid: 14 loe/lisa |
beastbeats
286 |
pealuu
| Kommentaarid: 213 loe/lisa |
172 |
beastbeats
286 |
