uus teema   vasta Uudised »  Riistvara »  Uus XQD kaardiformaat märgi kõik teemad loetuks
sõnum 12.12.2011 12:15:11 Uus XQD kaardiformaat vasta tsitaadiga
link :: dpreview.com
Compact Flash assotsiatsioon on teatanud uue XQD kaardiformaadi loomisest, mis mõõtudelt paikneb SD ja Compact Flash vahepeal ning põhineb PCI Express tehnoloogial. Reaalseks kirjutamiskiiruseks lubatakse vähemalt 125MB/s. Uut kaarti demonstreeritakse veebruaris Jaapanis CP+ 2012 messil.
Ametlik pressiteade:
CUPERTINO, Calif.--(BUSINESS WIRE)--The CompactFlash Association (CFA) is pleased to announce the release of the XQD specification as a new high performance memory card. This XQD specification is based on the PCI Express® specification, which provides a solid base for future performance scaling.
The CFA has adopted a new card specification with exciting performance and storage capabilities.
The key features of the XQD format include:
Optimized form-factor
Dimensions : 38.5 x 29.8 x 3.8mm
Durable & Robust
Scalable High Performance Interface
PCI Express: 2.5Gbps today and 5Gbps Future
Actual Write Speeds
Target 125MB/sec and Higher
To distinguish the new memory card format, an XQD compatibility mark has been created.
“The XQD format will enable further evolution of hardware and imaging applications, and widen the memory card options available to CompactFlash users such as professional photographers,” said Mr. Shigeto Kanda of Canon, chairman of the board, CFA.
XQD cards will be shown at the CompactFlash Association booth at CP+ 2012, February 9-12 in Yokohama, Japan.
Licensing for CFA members will start in early 2012. Please contact the CompactFlash office for more information.
HV-s ID-kaardiga autentimine
mihhkel
mihhkel
sõnum 12.12.2011 12:33:54 vasta tsitaadiga
sõnum 12.12.2011 12:39:01 vasta tsitaadiga
mihhkel, millest sa räägid - 2 põhilist formaati ju ongi praegu, Compact Flash ja Secure Digital - täiesti erinevatele tänapäevastele kaameratele (esimene profi peegelkaameratele, teine kompaktkaameratele). Antud uus XQD formaat on Compact Flash järglane sisuliselt. Seega tulevikus jääb tõenäoliselt 2 formaati - XQD (Compact Flash järglane) ja SDXC (Secure Digital järglane (tinglikult)) - kui miskit übervinget taas vahepeal ei leiutata. Isegi Sony andis alla ja loobus Memory Stick formaadist ning uusimatel kompaktkaameratel on Secure Digital kaarditugi.
Ho Ho
Ho Ho
sõnum 12.12.2011 12:57:56 vasta tsitaadiga
Teoreetiline max tol XQD'l siis ~500MB/s. Sellega suudaks juba salvestada otse pakkimata 1080p@80FPS ehk 1080p@40FPS ja 3D. Kerge pakkimine juurde ning 4kx2k ning 1080p 60FPS 3D on täitsa teostatav.
Pole viga, ainult et tahaks näha kuidas nad mahutavad nii väiksesse formaati piisava ribalaiusega kivid icon_smile.gif
sõnum 12.12.2011 12:59:04 vasta tsitaadiga
Kiireimad SSD ju evivad ca 500MB/s kirjutamiskiirust icon_rolleyes.gif
Tehnoloogia ja füüsilised mõõdud muidugi erinevad, kuid samas tegemist ju ikkagi sarnaste pooljuhtidega.
Ho Ho
Ho Ho
sõnum 12.12.2011 13:05:29 vasta tsitaadiga
Tanel kirjutas:
Vat neist füüsilistest mõõtudest tulenebki erinevus. SSD'd saavutavad oma kiiruse peotäie kivide läbilaske summeerimisel, sisuliselt tegu RAID0'ga. See eeldab korralikku kontrollerit, hunnikut kive ning eelkõige ruumi kuhu need kõik kokku pakkida. Samuti tarbib selline kooslus üsnagi korralikult voolu.
Loomulikult eks mingi hetk jõutakse kindlasti ka sinna maale, et sarnase kiiruse saavutab ka vähemate kividega kuid selleni kulub veel päris mitu aastat.
sõnum 12.12.2011 13:12:56 vasta tsitaadiga
Sellepärast ju räägitaksegi pressiteates kaardi enda reaalselt 125MB/s kiirustest icon_cool.gif
2,5Gbps ja 5Gbps tähistavad PCI-Expressi kanali teoreetilist läbilaskevõimet.
Ho Ho
Ho Ho
sõnum 12.12.2011 13:15:10 vasta tsitaadiga
Tanel kirjutas:
Tean, lihtsalt võtsingi 5Gbps'i kui antud tehnoloogia teoreetilise maksimumi ning üritasin leida mida sellega teha saab.
mihhkel
mihhkel
sõnum 12.12.2011 13:48:41 vasta tsitaadiga
Tanel kirjutas:
Praegu müüdavatel asjadel jah. See ei muuda aga olematuks karja vanemaid seadmeid, mis söövad nt xD, miniSD või Memory Stick M2 kaarte, mille lugemiseks on vähemalt minul vaja välja otsida eraldi USB-kaardiseade (ja mõnel ka adapter), kuna läpaka sisemine lugeja neid ei toeta. Aga olgu, saan aru, et see on rohkem mu enda probleem (vähemalt seni, kui neid kaarte tarbivad vidinad töötavad), nii et elagu XQD beer_yum.gif
sõnum 12.12.2011 13:52:52 vasta tsitaadiga
No need väljasurnud formaadid praktiliselt, mille edasiarendus oleks täiesti mõttetu olnud.
Aeg läheb edasi ja kiirused kasvavad. Ei kujuta sa ju ka praegu ette interneti kasutamist Pentium II 64MB masinaga icon_smile.gif
WAV
sõnum 12.12.2011 21:56:17 vasta tsitaadiga
mihhkel kirjutas:
Tanel kirjutas:
Tegelikult mulle tundub, et hoopis MicroSD teeb praegu kõige kiiremat edasiarengut. Järjest rohkem erinevaid seadmeid ilmub just selle toega (mitmedki asjad mille senised mudelid töötasid SD baasil, on nüüd oma uusimad mudelid teinud juba ainult MicroSD baasile - diktofonid, salvestid, pleierid näiteks). Muidugi MicroSD ongi elektriliselt sama SD standard, kuid mehaaniliselt tuleks lugeda ikkagi omaette kaardiklassiks. Kuigi mehaanilise adapteriga saab vajadusel ka sellest teha tavalise SD.
HighEnd
HighEnd
sõnum 13.12.2011 03:12:56 vasta tsitaadiga
Kui uus xqd kaart on ilma CF kaarti pinnideta, siis on igati positiivne uudis.. thumbs_up.gif
WAV
sõnum 13.12.2011 04:30:12 vasta tsitaadiga
Huvitav, mille järgi küll uue kaarditüübi loomisel selle "optimeeritud" mõõdud leitakse? Paistab, et siin pole ka niisama huupi võetud, numbrid on põhjalikult komakohalised ja ei tundu olevat ka tollimõõdus kuidagi ümardatuna.
sõnum 13.12.2011 07:11:15 vasta tsitaadiga
HighEnd kirjutas:
ot:
kaart, kaardi, kaarti
hmagi
hmagi
sõnum 14.12.2011 15:35:37 vasta tsitaadiga
Tanel kirjutas:
HighEnd kirjutas:
ot:
ot:
Võibolla peaksid integreerima postituste sisestamisse spelleri?
sõnum 15.12.2011 09:27:13 vasta tsitaadiga
hmagi kirjutas:
Tanel kirjutas:
HighEnd kirjutas:
ot:
ot:
Ehh, word censorit kasutame juba ammu siin foorumis ja see on mitukümmend lehekülge pikk.
Aga antud sõna puhul ei saa ju seda kasutada, vaata selle sõna erinevaid käändeid, eriti just seda viimast icon_wink.gif
aixi
sõnum 24.03.2012 18:49:39 vasta tsitaadiga
Kas kuskil müügil ka neid juba on. Seadmeid kus neid kasutada saab on vist veelgi vähem.
sõnum 26.03.2012 16:40:04 vasta tsitaadiga
Sony lugejad on juba mõnedes hinnakirjades olemas, aga kaarte mitte
https://www.hinnavaatlus.ee/products/pricelist/?Product=xqd
Nikon D4 toetab hetkel vist ainukesena seda formaati ja see Nikoni lipulaev pole just odav icon_eek.gif
https://www.hinnavaatlus.ee/products/Fototehnika/Peegelkaamerad/204828/
