praegune kellaaeg 12.11.2026 10:19:07
hax
17.11.2011 19:50:01
Probleem temperatuuriga (tmpin2) |
| Niisiis ,probleem seisneb selles ,et lasin peale programmi hardware monitor(proovinud ka teisi) ja näitab millegipärast mingi tmpin2-80C,mis asi see tmpin2 on ja miks ta nii kõrge on ?
| Kommentaarid: 18 loe/lisa |
15 |
Yankuonu
18.11.2011 15:39:49
TMPIN2 stands for Temperature Input 2. If your motherboard only supports 1 cpu temp, then what ever the value of the memory or bios where the HWMonitor thinks the value is stored it displays. So say the value in that memory or bios block is 128 because there is 128 k length for the name of your motherboard in the bios. I am going to assume since 128 is dividable by 2, lets see 2 to the 7th power, and memory has always been based on power of 2 (64kb then 128 kb then 256 kb) and 128 is a hugely used computer number in that is a full byte of info in binary, that would be 1111 1111.
So again I am going to say you have TMPIN2 checked in settings in HWMonitor but your motherboard doesn't have a sensor for it, so it is just displaying whatever info is stored where it THINKS it should be.
selgituseks, ei viitsi ise tõlkida aga see peaks olema vastus sinu murele.
_________________ "You cannot judge me. I am Justice itself!" |
hax
19.11.2011 16:05:08
| Aitäh!
15 |
