uus teema   vasta Tarkvara »  Linux & UNIX »  ubuntu 11.04 probleem wifiga märgi kõik teemad loetuks
germo123
germo123
sõnum 27.09.2011 13:08:27 ubuntu 11.04 probleem wifiga vasta tsitaadiga
Arvutiks on HP pavilion dv 4000. Et kuidas siis wifi võrku ühendada?
http://www.upload.ee/image/1690634/IMG_20110927_131607.jpg
ccayser
ccayser
sõnum 27.09.2011 14:40:11 vasta tsitaadiga
Uuri, kas Ubuntu toetab sinu Wifi kaardi tarkvara. Terminalis lshw -l käsuga peaks saama hardware listi.
Kommentaarid: 143 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 127
germo123
germo123
sõnum 27.09.2011 14:54:43 vasta tsitaadiga
germo@ubuntu:~$ lshw -C network
WARNING: you should run this program as super-user.
*-network:0
description: Network controller
product: BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
vendor: Broadcom Corporation
physical id: 5
bus info: pci@0000:06:05.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: bus_master
configuration: driver=b43-pci-bridge latency=128
resources: irq:20 memory:b0104000-b0105fff
*-network:1
description: Ethernet interface
product: RTL-8139/8139C/8139C+
vendor: Realtek Semiconductor Co., Ltd.
physical id: 7
bus info: pci@0000:06:07.0
logical name: eth0
version: 10
serial: 00:0a:e4:da:9c:e8
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full ip=192.168.1.73 latency=128 maxlatency=64 mingnt=32 multicast=yes port=MII speed=100Mbit/s
resources: irq:20 ioport:3000(size=256) memory:b010a400-b010a4ff
*-network DISABLED
description: Wireless interface
physical id: 1
logical name: wlan0
serial: 00:14:a5:1d:05:1b
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=b43 driverversion=2.6.38-8-generic firmware=N/A multicast=yes wireless=IEEE 802.11bg
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
germo@ubuntu:~$
sõnum 27.09.2011 22:04:24 vasta tsitaadiga
Pista masin LAN kaabli otsa ja paigalda Broadcom draiver. Praegu on sul paigaldatud b43 draiver (s.o avatud koodiga vaikimisi draiver), mis üsna paljudel broadcomi kaartidel üldse midagi ei mõika. See on juba aastaid kestev jama selle b43-ga. Mul endal avaneb läpakal sama pilt pärast värsket installi. Kõik näib justkui olevat OK, aga kaart ei leia ühtki võrku.
KDE-s on System menüüjaotises "Additional Drivers" utiliit, mille kaudu saab paigaldada ka graafikadraivereid - sealt saad ka Wifi draiveri paigaldada.
Gnomes peaks vist olema System -> Administration -> Additional Drivers. Unity's ei oska juhendada.
Märt.
Märt.
sõnum 28.09.2011 07:02:45 vasta tsitaadiga
Ise sain õpetuse lingi suurest Ubuntu teemast: https://help.ubuntu.com/community/WifiDocs/Driver/bcm43xx#Installing%20b43%20drivers
Selle järgi sain peale ja töötab. Tõsi, läpakas on 10.04 LTS, aga vahet ei tohiks vist olla.
HGtafka
sõnum 28.09.2011 10:43:45 vasta tsitaadiga
Minu DV5'l on quicklaunch nuppudel wifi sisse/väljalülitamine. Kuigi wifi nupp põles siniselt(on) oli olek off linuxis. Aitas paar korda nupule vajutamine ning restardid icon_smile.gif
germo123
germo123
sõnum 28.09.2011 11:12:11 vasta tsitaadiga
selge!
