praegune kellaaeg 16.11.2026 13:14:47
kasparv
26.09.2011 23:14:40
Tagasiside vorm |
Probleem nimelt Saurus CMS tagasiside ankeediga.
Tagasiside ankeedi default "From" väärtus on Website <website@yourdomain.com> ning teema "Subject" Data from website.
Saaja emailiks määrasin enda emaili ehk siis gmaili aadress. Paraku juhtub aga nii, et kõik kirjad hakkavad koonduma ühte vestlusse kuna nii saatja kui ka teema väärtused on koguaeg samad.
Äkki oskab keegi koodis teha muudatusi, et "From" ja "Subject" võetakse hoopis tagasiside ankeeti täites vastavalt "E-mail" ja "Teema" lahtrist.
Teine mure seisneb aga selles, et ankeet kuvab nii success kui ka error teated uuel lehel. Kas oleks väga keeruline määrata veateate kuvamine samal lehel nt ankeedi üleval?
Lisan siia ka koodi
form.php
<?php
* This source file is is part of Saurus CMS content management software.
* It is licensed under MPL 1.1 (http://www.opensource.org/licenses/mozilla1.1.php).
* Copyright (C) 2000-2010 Saurused Ltd (http://www.saurus.info/).
* Redistribution of this file must retain the above copyright notice.
* Please note that the original authors never thought this would turn out
* such a great piece of software when the work started using Perl in year 2000.
* Due to organic growth, you may find parts of the software being
* a bit (well maybe more than a bit) old fashioned and here's where you can help.
* Good luck and keep your open source minds open!
* @package SaurusCMS
* @copyright 2000-2010 Saurused Ltd (http://www.saurus.info/)
* @license Mozilla Public License 1.1 (http://www.opensource.org/licenses/mozilla1.1.php)
# Processes feedback form and sends e-mail
# : is FORM action value for feedback adding forms
# : is independent script, not for including, new Site is generated
global $site;
preg_match('/\/(admin|editor)\//i', $_SERVER["REQUEST_URI"], $matches);
$class_path = $matches[1] == "editor" ? "../classes/" : "./classes/";
include($class_path."port.inc.php");
$debug = $_COOKIE["debug"] ? 1:0;
$site = new Site(array(
on_debug=>$debug
$errors = array();
if(!isset($_SESSION['keel']))
//no session started, prolly a bot, exit
header('Location: index.php');
exit;
if($site->CONF['feedbackform_check_for_captcha'] == 1)
if(isset($_SESSION['scms_captcha']) && is_array($_SESSION['scms_captcha']))
$captcha = array_keys($_SESSION['scms_captcha']);
$captcha['name'] = $captcha[0];
$captcha['text'] = $_SESSION['scms_captcha'][$captcha['name']];
if(strtolower($_POST['captcha_'.$captcha['name']]) == strtolower($captcha['text']))
$capthca_check_failed = false;
else
$capthca_check_failed = true;
else
unset($_SESSION['scms_captcha']);
if($capthca_check_failed)
$errors[] = 'CAPTHCA';
$fdat = sizeof($_POST) ? $_POST : $_GET;
foreach ($fdat as $key=>$value) {
if(is_array($value)) $value = implode(', ', $value);
$site->debug->msg("$key: $value");
list($prefix, $field) = split("_",$key,2);
if (!$field) {
$field = $prefix;
$prefix = "000";
if (preg_match("/^_/",$field)) {
# kui välja nimi algab __ -ga,
# siis ignoreerime seda
$site->debug->msg("skipped");
next;
elseif ($field == 'id') {
# if fieldname is "id" => ignore it (Bug #927)
next;
else {
# Data check
$value = trim($value); //bug #2390
# required field
if(strlen($prefix) <= 3 && strpos(strtolower($prefix), array('a', 'b', 'c', 'd', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z',)) === false)
if (preg_match("/r/i",$prefix) && $value==='') {
$site->debug->msg("error: required");
$errors[] = $field;
# email field
if (preg_match("/e/i",$prefix) && $value!=='' && !preg_match("/^[\w\-\&\.]+\@[\w\-\&\.]+$/i",$value)) {
$site->debug->msg("error: not a email");
$errors[] = $field;
# number with dot field
if (preg_match("/f/i",$prefix) && $value!=='' && !preg_match("/^[\d\.\,]+$/",$value)) {
$site->debug->msg("error: not a number");
$errors[] = $field;
else
$field = $key;
if ($field == "systemfield") {
$site->debug->msg("SYSTEM");
list($tomail,$bad_url,$ok_url,$subject) = split('\|\|\|', $value);
// bug #2388 Tagaside vormist eemaldada e-maili aadress, tagasiasendus
$result = new SQL($site->db->prepare('select mail from allowed_mails where id = ?;', $tomail));
if($result->rows == 1) $tomail = $result->fetchsingle();
$site->debug->msg("to: $tomail");
$site->debug->msg("OK: $ok_url");
$site->debug->msg("ERR: $bad_url");
} else if ($field!="keel" && $field!="op") {
$output .= preg_replace("/((re)|(er)|(rf)|(fr)|(e)|(r)|(f))_/", "", $key).": $value\n";
if ($subject) {
$subject = str_replace("[".$field."]", $value, $subject);
# some enviroment variables
#map {$out{$_} = $ENV{$_}} split(/ /, $$CONF{env_var});
# view allowed_mails table
# added 08.12.2003 by merle: can use multiple e-mails, separated by comma
$sql = $site->db->prepare("SELECT * FROM allowed_mails WHERE FIND_IN_SET(mail,?)",$tomail);
$sth = new SQL($sql);
$sql1 = $site->db->prepare("SELECT * FROM users WHERE FIND_IN_SET(email,?)", $tomail);
$sth1 = new SQL($sql1);
$test = $sth->rows + $sth1->rows;
if ( !$test ) { $errors[] = "Error! Receiver e-mail in mail form has been changed by unauthorized persons."; }
if (sizeof($errors)==0) {
# Send email message
#print "<pre>$output</pre>";
$output = "The following information was submitted by ".$_SERVER["REMOTE_ADDR"]."\nfrom ".$_SERVER["HTTP_REFERER"]."\non ".date("d.m.Y T")."\n\n".$output;
include_once($class_path.'mail.class.php');
$mail = new email(array(
'subject' => ($subject ? $subject : $site->CONF['subject']),
'message' => $output,
'charset' => $site->encoding,
$send_status = $mail->send_mail(array(
'to' => $tomail,
'from' => $site->CONF['from_email'],
//$send_status = mail($tomail, ($subject ? $subject : $site->CONF["subject"]), $output, "From: ".$site->CONF[from_email]."\nContent-Type: text/plain; charset=".$site->encoding);
# kui mail OK
if ($send_status) {
header("Location: ".(empty($_SERVER['HTTPS']) ? 'http://': 'https://').$site->CONF[hostname].$site->CONF[wwwroot].($site->in_editor ? "/editor" : "")."/".$ok_url);
# kirjuta error logi
} else {
new Log(array(
'component' => 'Feedback forms',
'type' => 'ERROR',
'message' => "Error occurred during sending form feedback e-mail: ".$send_status." (From: ".htmlspecialchars($site->CONF[from_email])." To: ".htmlspecialchars($tomail).")",
$errors[] = "Error occurred during sending form feedback e-mail!";
if (sizeof($errors)) {
# Error handling
# $http_headers_out{'Location'} = "$bad_url\&errors=".join("",@errors)."\n\n" unless $fdat{debug};
# Bug #2221: [error] väljastab vigaste väljade nimed ühes jorus
header("Location: ".(empty($_SERVER['HTTPS']) ? 'http://': 'https://').$site->CONF[hostname].$site->CONF[wwwroot].($site->in_editor ? "/editor" : "")."/".$bad_url."&op=error&fields=".join(",",$errors));
$site->debug->print_msg(); |
ja html
<form method="post" action="form.php" name="SCMSForm">
<input type="text" name="r_Nimi" />   Nimi<sup>*</sup><br />
<br />
<input type="text" name="er_E-post" />   E-post<sup>*</sup><br />
<br />
<input type="text" name="f_Telefon" />   Telefon<br />
<br />
<input type="text" name="r_Teema" />   Teema<sup>*</sup><br />
<br />
Sisu<br />
<textarea style="width: 364px; height: 133px;" name="Sisu"></textarea><br />
<br />
<input type="hidden" value="mail@mail.mail|||index.php?id=23|||index.php?id=24|||Tagasiside veebilehelt" name="systemfield" /><input type="submit" class="submit" value="Saada" />    <input type="reset" class="reset" name="Katkesta" value="Katkesta" />
</form> |
