uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [X360/PS3] Crysis 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2
tann84
tann84
sõnum 23.03.2011 23:31:02 vasta tsitaadiga
Kas keegi omab juba crysis 2 ps3 versiooni. Jagage muljeid,kuidas graafika on ja kuidas MP on?
PSN: karl877
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 35
TombcaT
sõnum 24.03.2011 22:52:46 vasta tsitaadiga
link :: DigitalFoundry
Kokkuvõte Neogafi lehelt:
360 runs at native 720p, PS3 runs at 1024x720
PS3 version is stretched horizontally leaving a 'stretched' effect
Occasional tearing but is basically invisible during gameplay
Both versions employ temporal AA and also use edge detect blur for the foreground
PS3 has better texture filtering
360 has better framerate than PS3 version
In the most stressful areas PS3 actually manages to hold the framerate a bit better than the 360 even though the 360 commands the framerate advantage
Shadow offset issues on PS3 but on closer inspection the PS3 shadows are less blocky
The game sometimes uses prerendered FMVs, author says they're the worst quality they've seen in some time(my guess is BINK), on top of that they're the same quality on both platforms even though the PS3 game is only 7.5GB and the 360 is 5.5GB so they clearly had tons of space left to improve video quality. Side Note: Could someone with the PC version confirm if the video quality is just as bad there?
Originally Posted by DigitalFoundry:
The crucial thing is that both are phenomenally attractive games, producing effects quite different and in many ways more advanced than anything we've seen elsewhere on console. We all wanted Crysis on console to be an event, a showcase release: by and large, Crytek has delivered, and those cutting edge visuals are backed by a truly impressive game design. However, there's the nagging feeling that a few more months in development could perhaps have ironed out the issues both versions of the game have.
There's little doubt that the Xbox 360 is the cleaner, crisper experience and for the most part it commands a small but significant frame-rate advantage and fewer little glitches; especially outside of combat scenarios, the game just seems to run that much more smoothly.
Crytek has done enough to prove that Crysis can run on consoles - either of them in fact - and certainly the issues the game has in terms of bizarre glitches, performance drops, geometry pop-in and such-like are hardly exclusive to one platform. On balance, 360 has the edge in terms of visuals and general performance, but PS3 more than holds its own, bettering the Microsoft platform in some areas.
omgwtf
omgwtf
sõnum 26.03.2011 15:25:34 vasta tsitaadiga
Milenko kirjutas:
Kange soov on 1 uus shooter soetada aga ei oska nende kahe vahel otsustada: Homefront or Crysis 2 ?
Homefronti küll ära osta.
warsteine
sõnum 28.03.2011 20:17:04 vasta tsitaadiga
Sai siis xboxi versioon mängust soetatud.
Peab mainima, et tegemist on vast kõige ilusama x360 mänguga.
Kellegi eelmise posti täiendamiseks: ta ei jookse native 720p vaid 1172x720p vms (digital foundry andmetel) ent mingit venitust ei näe sellest, pilt on väga ilus. DF andmetel jookseb asi arvuti "HIGH" graafikatasemel, ent probleeme on 30 fps säilitamisega.
Enda kogemuse põhjal FPS on täitsa nauditav, ei lange mängitamatu piirimaile. Temporal AA süsteem veidi häirib, võidaks leiutada viis MLAA rakendamiseks.
Heli on super ning seni pole ka ühegi bugi otsa koperanud thumbs_up.gif.
Kellele fpsid meeldivad, siis proovige kindlasti järgi beer_yum.gif .
Milenko
Milenko
sõnum 28.03.2011 22:02:18 vasta tsitaadiga
omgwtf kirjutas:
Milenko kirjutas:
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 32
beastbeats
beastbeats
sõnum 10.05.2011 18:28:30 vasta tsitaadiga
http://www.joystiq.com/2011/05/10/crysis-2-getting-retaliation-dlc-on-may-17/
Kommentaarid: 366 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 282
xbot
sõnum 18.05.2011 00:39:43 vasta tsitaadiga
huvitav kas nad nüüd on multiplayeri korda teinud? Nädal hiljem peale mängu release lendas multiplayer serverid vastu taevast. Kõigepealt hakkas mingi kala pihta ja paar päeva hiljem oli blackout.. Müüsin mängu selsamas poodi tagasi.
beastbeats
beastbeats
sõnum 09.09.2011 17:42:06 vasta tsitaadiga
Peatselt saab ka esimest osa konsoolidel mängida:
http://www.eurogamer.net/articles/2011- ... to-console
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [X360/PS3] Crysis 2 mine lehele eelmine  1, 2
