uus teema   vasta Tarkvara »  Tarkvara »  hea arvuti friizib vahest... märgi kõik teemad loetuks
Murtpoiss
Murtpoiss
sõnum 09.09.2011 17:00:44 hea arvuti friizib vahest... vasta tsitaadiga
jama siis selline et näiteks n2dalas korra v6i kaks (v6i vahest pysib isegi rohkem kui n2dal aega) arvuti lihtsalt paneb pange ja mitte midagi ei liigu enam ... kõige vingem on see et isegi mingit ylekoormust(töötab ainult nt msn ja mozilla) pole ega midagi sellist ... ainus v6imalus on teha restart ...
tegemist on siis enda ehitatud arvutiga ...
näitajad on sellised:
Computer Type ACPI x86-based PC
Operating System Microsoft Windows 7 Ultimate
OS Service Pack Service Pack 1
CPU Type QuadCore AMD Phenom II X4 Black Edition 955, 3200 MHz (16 x 200)
Motherboard Name ASRock M3A780GXH/128M
System Memory 3072 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: Crucial RM25664BA1339.8FR 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
DIMM2: Crucial RM25664BA1339.8FR 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
BIOS Type AMI (04/24/09)
Video Adapter ATI Radeon HD 3200 Graphics (640 MB)
Video Adapter ATI Radeon HD 4800 Series (512 MB)
3D Accelerator ATI Radeon HD 3200 (RS780)
3D Accelerator ATI Radeon HD 4870 (RV770)
Monitor LG L1752T (Analog) [17" LCD] (160943121)
Monitor LG StudioWorks 520Si [15" CRT] (160216843009)
Monitor Samsung SyncMaster 740N [17" LCD] (HMCY925020)
Audio Adapter ATI Radeon HDMI @ ATI RV770 - High Definition Audio Controller
Storage Controller Microsoft iSCSI Initiator
Disk Drive Samsung S2 Portable 3 USB Device (465 GB, USB)
Disk Drive WDC WD1600AAJS-00B4A0 ATA Device (149 GB, IDE)
Optical Drive HL-DT-ST DVDRAM GSA-4167B ATA Device (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
C: (NTFS) 149.0 GB (42.1 GB free)
K: (FAT32) 465.6 GB (101.5 GB free)
Total Size 614.7 GB (143.6 GB free)
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
DMI BIOS Version P1.00
Power supply Xilence 420w
usb kaudu on yhendatud veel klavi+hiir, väline k6vaketas, ipod(vahest), veebikas ja vahest m6ned mälupulgad ...
ylekuumenemist ka pole ...
Sensor Type Winbond W83627EHF/EHG (ISA 290h)
GPU Sensor Type Diode, Volterra VT1165 (ATI-Diode, 70h)
Chassis Intrusion Detected Yes
Motherboard 38 °C (100 °F)
CPU 42 °C (108 °F)
CPU #1 / Core #1 41 °C (106 °F)
CPU #1 / Core #2 41 °C (106 °F)
CPU #1 / Core #3 41 °C (106 °F)
CPU #1 / Core #4 41 °C (106 °F)
Aux 42 °C (108 °F)
GPU Diode (DispIO) 50 °C (122 °F)
GPU Diode (MemIO) 66 °C (151 °F)
GPU Diode (Shader) 53 °C (127 °F)
GPU VRM 56 °C (133 °F)
WDC WD1600AAJS-00B4A0 34 °C (93 °F)
SAMSUNG HM501IZ 31 °C (88 °F)
CPU 1592 RPM
Aux 2766 RPM
Chassis 2860 RPM
Power Supply 2722 RPM
CPU Core 1.03 V
+3.3 V 3.15 V
+5 V 5.02 V
+12 V 11.93 V
+5 V Standby 4.68 V
GPU VRM 1.26 V
GPU VRM 30.71 A
et ise arvan et on op systeemi viga aga ehk keegi oskab seletada midagi kuidas lahti saab v6i kas teeb kellelgi samamoodi vms...
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
heikis
sõnum 09.09.2011 18:15:00 vasta tsitaadiga
biosi uuenduse võiksid esiteks teha- kindlasti kõik üleliigsed seadmed selle toimingu ajaks lahti ühendada (välised kettap, pleierid jne)
mälu kontrollida memtestiga http://www.memtest86.com
Kommentaarid: 339 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 291
reints
reints
sõnum 09.09.2011 18:21:09 vasta tsitaadiga
Kontrolli kõvaketas üle
Murtpoiss
Murtpoiss
sõnum 09.09.2011 19:09:04 vasta tsitaadiga
heikis kirjutas:
mul on küll yhe plaadi peal mem test olemas aga ma pole kunagi sellest aru saanud mida see t2psemalt teeb ... kontrollib ja annab teada kui midagi viga ?
ja kui pole midagi viga siis ei tee midagi ??
ja veel see et kust ma saaksin endale uue biossi ...
hmmm ... kas teie erust v6ib veel see viga ka olla et mul toide n6rk ?? v6i selline on normaalne ... ?
sõnum 10.09.2011 18:11:12 vasta tsitaadiga
Murtpoiss kirjutas:
heikis kirjutas:
Kasuta parem memtest86+ - eelmise edasiarendus
Jah. Mida muud ta veel tegema peaks? Ootajale kohvi keetma? icon_rolleyes.gif
Emaplaadi tootja kodulehelt otsid oma emaplaadi tüübi "M3A780GXH/128M" järgi.
Tõenäoliselt nõrk jah. Xilence on pigem säästutoide, 420W on lubatud tõenäoliselt väga lühiajaliselt, nominaalne koormus on sellest ehk poole kanti. Sul tundub olevat kaks graafikakaarti korraga masinas ja protsessor pole ka sita pealt riisutud - 420W toidet mina ei riskiks sinna panna ka juhul kui tootja oleks nimekam tegija.
viimati muutis Dogbert 14.09.2011 15:31:52, muudetud 1 kord
Murtpoiss
Murtpoiss
sõnum 14.09.2011 12:58:05 vasta tsitaadiga
et kas see v6ib siis tuleneda sellest et toide on n6rk ?
sõnum 14.09.2011 15:31:08 vasta tsitaadiga
Nagu ma (tagantpoolt 3. lauses) ütlesin - nõrk jah. Või ootad veel arvamusi? Xilence 420W kohta sa vaevalt et midagi muud kuuled.
