praegune kellaaeg 09.11.2026 12:41:00
K3891
07.07.2011 01:21:34
The attempt to burn a disc failed. An unknown error occurred (4450). |
Mis värk on? Miks CD kirjutada ei lase?
| Kommentaarid: 60 loe/lisa |
49 |
woozy
07.07.2011 01:39:22
What was my fix for iTunes 4450 error? - a different CD-R brand! I was burning with Memorex's 52x CD-R... when I switched to a Maxell's CD-R, the error was gone! And I left the burn speed at 'maximum'. It did it in about 4minutes. Good luck! \
Another 4450 iTunes error fix - capacity of your CD. For example, if total amount of memory your songs need are 750mb, but your CD is only capable of writing 700mb, you will get error 4450. In fact, when I wrote this article about switching the brands, what may have happened is that the Maxell's CD-R brand has bigger memory capacity... 800mb vs 700mb.
Suht esimene quote, mis google andis..
120 |
