sõnum  |
TXX
01.03.2012 17:38
| Peab vist 7970 ostmata jätma ja raha juurde koguma...
| Kommentaarid: 78 loe/lisa |
73 |
siinus
01.03.2012 17:40
väljundpesasid on nagu vähe nati
_________________ ANNA MU SAI! |
| Kommentaarid: 61 loe/lisa |
56 |
pohmakas,
käed värisevad
01.03.2012 18:33
| Blingi on küll, kuid ei usu, et väga efektiivne jahuti on. Näidaku kapoti alla ka..
126 |
madfury
02.03.2012 09:14
| Virge@Anand kirjutas: |
Since this is an obvious fake taken from someone's 3DSMax project, we're closing this up. In the future you guys should probably stop listening to Chiphell.
Tegu siis ibaga. Chiphellist mälu järgi ikka enam-vähem oogoo infot tulnud, järgmine kord olen targem.
_________________ Avatar by Flacko |
| Kommentaarid: 25 loe/lisa |
25 |
trip
03.03.2012 18:58
7850/7870
graafikud kahtlased, 7870 ~ 7970
| Kommentaarid: 401 loe/lisa |
298 |
Kristoferr
174 |
pots4t4j4
03.03.2012 19:03
hinda pole veel ju teada
| Kommentaarid: 447 loe/lisa |
358 |
Kristoferr
174 |
pots4t4j4
03.03.2012 19:10
raudselt tuleb 2% odavam kui 7950 aga nali naljaks ootame ära
358 |
smurfar
03.03.2012 21:08
Andmed on esialgu paljulubavad... Nüüd jääme lootma, et ka hind on hea
_________________ Parandan lõhutud küttepuid. Hind kokkuleppel |
99 |
trip
04.03.2012 08:56
wtf, äkki 2304sp-ga kaart
298 |
Kristoferr
174 |
trip
04.03.2012 18:53
http://www.obr-hardware.com/2012/03/radeon-hd-7970-tahiti-xt-successor.html
Successor of Radeon HD 7970 has 20 percent higher Compute Power (not gaming performance), based on EGCN (Enhanced GCN) and will be launched Q3/2012 or Q1/2013. Specification: 2304 Stream processors, 384-bit mem bus, 3GB GDDR5 6 GHz. TDP 250W, idle 3W.
Next info is about Dual monster Radeon HD 7990, the original information was, that it will be launched in Q1. From a reliable source I know that AMD still can not produce sufficient cooler for card with higher power consumption than Radeon HD 6990. The card disappeared from the roadmap for Q1 and is not in the Q2 too. It may be completely canceled, or may come out later. |
298 |
04.03.2012 19:33
| Kristoferr kirjutas: |
see roheliste kartuses tehtud slaid.  |
Kui oleks mida karta.
| AMD still can not produce sufficient cooler for card with higher power consumption than Radeon HD 6990 |
See on mingi bullshit vist imo. Kui 4870X2 sugusele ahjule saivad jahuti teha, siis saavad seda teha ka hulga väiksemale ja jahedmale 7990-le
| Kommentaarid: 83 loe/lisa |
73 |
heff
04.03.2012 19:34
| 4870X2 jahutamislahendus just kõige parem polnud. Aga jah, raskesti usutav. Peaks olema jahedaim dual-gpu kaart, mis siiani toodetud.
| Kommentaarid: 96 loe/lisa |
88 |
1dumbpcuser
04.03.2012 20:01
Ega's ei jää muud üle kui Arctic appi võtta
Või ei taheta 3-slot jahutit teha?
_________________ M: Corsair H80i v2 AIO |
| Kommentaarid: 87 loe/lisa |
83 |
pohmakas,
käed värisevad
04.03.2012 20:06
| Imo võiks vabalt 3-slot jahutus olla. Mis saaks kasutajatel vast olla, kui by default oleks juba asjalik jahutus peal?
126 |
libe
kvaliteetne mees
04.03.2012 20:08
| Lauri Kiissel kirjutas: |
| Imo võiks vabalt 3-slot jahutus olla. Mis saaks kasutajatel vast olla, kui by default oleks juba asjalik jahutus peal? |
mõni kasutab ka lisakaarte
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
04.03.2012 20:26
See "mõni" paneb siis asjale vee peale ja ei mölise
Tegelikult on variante mitmeid ja nn ultra high end kaardil võiks vabalt by default kolme slotiline peal olla.
| Kommentaarid: 1006 loe/lisa |
727 |
pots4t4j4
04.03.2012 20:31
| neid "ultra" highende võiks ilma jahutuseta müüa siis igaüks saaks valida mis sinna peale paneb selle default rämpsu asemel, nad oleks võinud sõnastada et, amd ei saa 3 dollari eest paremat jahutust kui 6990 peal oli.
358 |
1dumbpcuser
04.03.2012 20:52
| pots4t4j4 kirjutas: |
| neid "ultra" highende võiks ilma jahutuseta müüa siis igaüks saaks valida mis sinna peale paneb selle default rämpsu asemel |
Võiks, aga siis peaks ka valikut olema. Praegu on Arctic prakltiliselt ainus tootja, kes teeb dual-gpudele sobivaid jahutusi. Vesijahutust by default nõuda oleks ka ämbri kolistamine.
83 |
libe
kvaliteetne mees
04.03.2012 21:05
lisakaartide alla käib ka crossfire lahendus
Lord Ami
| Kommentaarid: 54 loe/lisa |
49 |
05.03.2012 08:07
AMD Radeon HD 7850 & HD 7870 2 GB Review:
http://www.techpowerup.com/reviews/AMD/HD_7850_HD_7870/
Igati korralikud kaardid.
Hind hetkel veel tiba kõrge aga seda oli ka arvata.
Oc annab ikka kenasti juurde ja ega perf niisama ka just lahja ei ole.
Ühesõnaga HD7870 on kiirem kui GTX570 ja võtab ~ 2x vähem voolu.
viimati muutis Winterwind 05.03.2012 08:14, muudetud 1 kord |
727 |
pohmakas,
käed värisevad
05.03.2012 08:08
AMD Radeon HD 7850 2GB Reference Video Card Review
Tweaktown
AMD Radeon HD 7870 & Radeon HD 7850 Review
Techspot
AMD Radeon HD 7850 and 7870 review
Guru3D
Päris asjalikud tunduvad ikka olevat. HD7850 voolutarve meeldib kohe eriti, võtab vähem, kui HD77xx kaardid. Klokkuvad ka kenasti, nagu HD7k kaartidele kohane.
126 |
