26.06.2011 12:40:06
BBC Playeriga väike jama |
Nimelt senimaani kasutanud mingit flash lahendust aga panin tähele et kõrgema kvaliteediga striimid enam ei tööta.
Seega mõtlesin et tirin uue versiooni alla BBC Playerist. Installisin kõik ära mis sel lehel kirjas http://bbc-player.com/ ning endiselt tööle ei lähe.
Viskab ette kas sellise kasti
Kus details all on
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Cannot process request because the process (3340) has exited.
at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
at System.Diagnostics.Process.Kill()
at BBCPlayer.MainForm.reconnectTimer_Tick(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
BBCPlayer
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Program%20Files/BBC%20Player/BBCPlayer.exe
System
Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
AxInterop.ShockwaveFlashObjects
CodeBase: file:///D:/Program%20Files/BBC%20Player/AxInterop.ShockwaveFlashObjects.DLL
CodeBase: file:///D:/Program%20Files/BBC%20Player/Interop.ShockwaveFlashObjects.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. |
Ideid?
| Kommentaarid: 39 loe/lisa |
WäntWõll
make.believe
26.06.2011 12:52:10
.NET paneb n äkku, vigaselt epale läinud ors.
Samas XP-le on kindalalt soovitatud command-line versiooni.
Võid proovida vabenda .NET versioonidest ja võtta kõige uuem ainult, se lõputu 2.0 >> 3.5 jne. patchimine pole äkki kõige trervislikum.
300 |
26.06.2011 12:55:31
jah aga kust ma seda uuemat command line tirin. Mul mingi vana on aga to näitab vaid kõge madalama kvaliteediga. Ükskama kas valin parima kvaliteedi või keskmise.
WäntWõll
make.believe
26.06.2011 13:00:15
Tundub, et nad on toe ära võtnud ja uuendanud pole seda CL versiooni.
Hetkel näen ainult GUI variante.
Seega ega sul eriti midagi üle jää kui lahendada .net kala või värskema OS-i peale.
Muidugi mõni heatahtlik AHV kes teab seda .NET-i elu olu oskab äkki täpsemalt öelda, mis sul seal vajaka täpsemalt jääb.
300 |
30.06.2011 16:01:13
| WäntWõll kirjutas: |
| Muidugi mõni heatahtlik AHV kes teab seda .NET-i elu olu oskab äkki täpsemalt öelda, mis sul seal vajaka täpsemalt jääb. |
Jah paraku XP-st ei jaga mina ööd ega mütsi
Selline exeption on küll tavaliselt ühekordne.
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
| Kommentaarid: 92 loe/lisa |
