uus teema   vasta Tarkvara »  Arvutimängude foorum »  Darksiders II märgi kõik teemad loetuks
KrisVr
sõnum 16.08.2012 14:35:48 Darksiders II vasta tsitaadiga
    • Arendaja: Vigil Games
    • Väljaandja: THQ
    • Stiil : Hack and slash, action-adventure
    • Väljalaske kuupäev: 21 august, 2012
Darksiders II's story will take place in the same time period as the first game, only this time players will take control of the Horseman Death, instead of his brother War. The game will reportedly take place across an entirely new ensemble of maps, confirmed to be double in cumulative size to that of its predecessor. The game will also feature the remaining two horsemen, Strife and Fury, in some capacity.
Darksiders II starts at nearly the same time as the start of the first Darksiders. After War is convicted and sent back to Earth by the Charred Council, they inform the other three Horseman of his fate. The Horseman Death, knowing that his brother War is the most honorable and incorruptible of the four, and would never have started the Apocalypse early, flies into a rage. Believing his brother is victim of a conspiracy, Death defies the Council's orders and sets out on a personal mission to find proof of his brother's innocence. Death travels to the Nether Realms, a place between Heaven and Hell, to call in favors from powerful beings that rule the realm.
Announcement Trailer
Death Lives Trailer
Death Eternal Trailer
Link
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
MatchMaker
MatchMaker
sõnum 16.08.2012 16:32:34 vasta tsitaadiga
Mõned tunnid mänginud ja peab tb.ga enamvähem nõustuma. Halvad tekstuurid mind isiklikult vist esialgu niiväga hetkel veel ei häirigi kuigi kohati riivavad ikka silma küll ja tegelase liigutamisega ka mingeid ülemääraseid probleeme pole kohanud. Samas see, et Vsync ei tööta häirib üsnagi ja inventorys olev tegelase mudel näeb üle mõistuse halb välja. Mäng ise, muusika, asteetika jne on ikka väga lahedad nii, et 5+ selle eest. Aga jah paraku halva pordi eest täit summat kindlasti välja ei käiks.
lopes39
lopes39
sõnum 17.08.2012 14:39:24 vasta tsitaadiga
seal mängus kuskil saab vaadata mis nupud on ja neid ka vahetada ka saab ?
juba klõbistamise mäng on ja pmst. näeb välja POP koopia
trip
trip
sõnum 17.08.2012 17:37:48 vasta tsitaadiga
lopes39 kirjutas:
saab küll http://community.darksiders.com/go/thread/view/138731/29314129/Controller_Options__Remapping_Controls_PC
pkwild618
sõnum 18.08.2012 00:50:28 vasta tsitaadiga
Mulle tundub esmapilgul õudne. Menüüdes liikumisega nägin rohkem vaeva, kui harjunud ning optionsides ka valikud üsna nigelad (pluss see restart to take effect ... kuidas see toimib täpsemalt? mul viskas defaulti tagasi igatahes). Graafika on imo kohutav. Gameplay iseenesest on täiesti korralik ja loomulikult muusika, aga mingi imelik nupp, kaardus alla? Proovisin igasuguseid asju ja ei töötanud. Anyways mina seda mängu enam tõenäoliselt tööle ei pane, olgu see gameplay üldiselt kui korralik tahes, ma pean nii palju aega kulutama elementaarsete tegevuste välja nuputamisele (kuigi ma üsna kärsitu ka) ning silmi rikub ka. Võibolla kui oleks esimest osa mänginud meeldiks rohkem. Keda need vead ei häiri, siis muus osas tundub mäng väga hea.
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 14 :: 5 :: 8
LauriTed
sõnum 23.08.2012 12:04:18 vasta tsitaadiga
Väga hea mäng. Graafika on küll teisejärguline ja tõelisel Darksiders huvilisel see küll mingit tükki küljest ära ei võta.
Kommentaarid: 254 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 231
carbz
carbz
sõnum 23.08.2012 20:55:44 vasta tsitaadiga
Mängisin esimese "ala" läbi. Kasutasin Logitech F710 pulti, tänu millele menüüd ei seganud. Võitlemine on äärmiselt sujuv, varustus juba maast madalast Over the top ja uhke, Mapi kujundus on väga kaunis. Tekstuurid on mis nad on, point on combat, mis on mängu väga tugev külg. Lisaks jookseb mäng väga sujuvalt.
Kui veel kiita tarvis, siis boss fighte, igal bossil (Vähemalt yggdrasilini) on mingi originaalne kiiks mis tuleb üles leida.
lopes39
lopes39
sõnum 26.08.2012 19:43:01 vasta tsitaadiga
suht kahtlane mäng on
tegin läbi normaliga ja siis rääkis et on mingi nightmare mode lahti kuid kui uuesti mängima hakata siis nightmare raskustaset ei saand .. oli mingi apocalyptic vms
samas peabki vist mängu 2 korda läbi tegema kuna kui esimest korda läbi tegin siis sai aint level 25-ni tehtud ja kui jätsin relvad ja asjad alles ja uue mängu tegin siis jooksis seal 25 pealt edasi ja esimesel kaardil leidsin mingi tegelase kes kaelakeesi müüb level 40 on enamjaolt ja kasutada ei saa kuna on punased
samas on kaardi peal kohti kuhu minna ei saa sest pole teleporti ja asju mis mängu käigus avanevad
MaxEvil
MaxEvil
sõnum 27.08.2012 12:29:09 vasta tsitaadiga
Sai ka läbi tehtud, täitsa korralik mängu elamus, 25 mängu tundi tuli ära. Kui uskuda mängu state siis 25st tunnist ainult 5 oli combat icon_biggrin.gif
Esimene osa meeldis väga, teine osa aga jääb natuke alla esimesele, lõpp vajus ära, kuna tegevusi jäi järjest vähemaks iga uue "maailmaga".
Nightmare saad mängida ainult täiesti uue mänguna, +game ei saa
nende juurde tagasi minna kohe kui saad uue vidina millega pääsed ligi ju(siis ei lähe meelsest ära icon_razz1.gif ),
