uus teema   vasta Uudised »  Ülevaated, kasutajate hinnangud »  Ülevaade: Noctua NH-D14 märgi kõik teemad loetuks
K3ndu
K3ndu
sõnum 25.02.2011 15:45:41 Ülevaade: Noctua NH-D14 vasta tsitaadiga
Noctua NH-D14 on nüüdseks juba üle aasta vana kuid endiselt on ta üks parimaid jahuteid, vaatame, uurime ja proovime lähemalt Noctua NH-D14 selles ülevaates.
Esmalt ma tänan ma Noctua'd kes varustas mind selle ülevaate eksemplariga.
Noctua NH-D14
Koduleht
Andmed:
Veel andmeid:
  • 6 heatpipe dual radiator design
    Providing more surface area, better heat-distribution and superior airflow efficiency than conventional tower style heatsinks, the NH-D14’s six heatpipe dual radiator design was developed to provide ultimate quiet cooling performance in dual fan mode.
  • Dual NF-P14/NF-P12 fan setup
    The NH-D14 sports a premium quality dual fan setup consisting of Noctua’s award-winning NF-P12 (120mm) and NF-P14 (140mm) fans, both of which feature Vortex-Control Notches, SCD technology and SSO-Bearings in order to achieve a perfect balance of performance and quietness.
  • Asymmetrical design for high compatibility
    An asymmetrical design that gives more clearance towards the RAM slots ensures good compatibility despite of the cooler’s size. The NF-P12 fan can be moved upwards or left off in order to further improve compatibility.
  • Excellent component cooling
    Hanging out at the bottom of the fin-stacks, the NF-P14 fan doesn’t only contribute to the NH-D14’s superb CPU cooling capabilities but also provides massive airflow over surrounding motherboard components and heatsinks, thus ensuring excellent component cooling performance.
  • SecuFirm2™ multi-socket mounting system
    Noctua’s enthusiast grade SecuFirm2™ multi-socket mounting provides broad socket compatibility (LGA1366, LGA1156, LGA1155, LGA775, AM2, AM2+ and AM3) and meets the highest demands in safety, contact pressure and ease-of-use.
  • NT-H1 thermal compound
    Noctua's much-acclaimed NT-H1 is a well proven pro-grade TIM solution that provides minimum thermal resistance, excellent ease-of-use and outstanding reliability.
Pakendi sisu:
  • Noctua NH-D14
  • Kasutusjuhend/õpetus kahes keeles
  • Kruvikeeraja
  • Inteli paigalduskomplekt
  • AMD paigalduskomplekt
  • Erinevate socketite kinnitused
  • NT-H1 termopasta
  • Noctua metallist kleeps
  • 4 kruvi
  • 4 kummikinnitit
  • Erinevad jaoturid ja pöörete alandajad
Pakend:
Tegemist siis pakendi esiküljega kus on kirjas üleval nurgas mis jahutiga tegemist on, teises nurgas, et tegemist on Noctua jahutusega. Pakendi alumises nurgas on siis põhimõtteliselt veel välja toodud need samad asjad mis on ka Veel andmeid all kirjas. Värvistiil on peaaegu, et sama mis tavaliselt Noctua värvivalik on, ehk siis sinised ja pruunid värvid, kuid mis sellel natuke teistsugune on see, et pakk on üleni suhteliselt valge ja selle peal on Noctua NH-D14 jahutuse joonised. Esiküljel on ka väike teasing pilt ehk siis missugune jahutus välja näeb.
Tegemist siis pakendi parempoolse küljega, natuke informatsioonirikkam külg kui esikülg on. Välja on toodud siis jahutuse mõõtmed kui jahutuse peale on paigaldatud ventilaatorid. Samuti on veel välja toodud paar head asja mis selles pakendist peale jahutuse enda veel leiab. Ja nende kõrval on kohe pilt kus on näha jahutuse enda talda ja nende kuumatorusi.
Tegemist on siis pakendi tagaküljega ja põhimõtteliselt on see järjekordselt see sama mis on kirjas mul Veel andmed all ja mis oli ka pakendi esiküljel näha kuid mis selle teistsuguseks esiküljega teeb on see, et siin on pikalt välja kirjutatud mida miski tähendab. Ma toon ka välja siis paar asja mida sellel pakendil reklaamitakse. Esmalt siis on välja toodud, et kaasas on kaks ventilaatorit suurustes 120mm ja 140mm ja on samuti väga vaiksed. Selle all on kohe pilt, et jahutusel on kaasas SecuFirm2™ kinnitused mis sobib siis kõikidele socketitele. Selle all on kolmas pilt siis kus räägitakse sellest, et on 6 kuumustoru ja kaks radiaatorit, et oleks eriti hea soojusjuhtivus. Minnes jälle üles leiame me pealt neljanda pildi kus räägitakse sellest, et see jahutus ei ole ainult hea protsessorile vaid ta jahutab ka muid komponente arvutis kuna tal on massiivne 140mm NF-P14 ventilaator. Viiendalt pildilt leiame selle, et räägitakse sellest, et radiaator on sümmeetriline ja seega ei tohiks tulla probleeme sellega, et mälud jäävad jahutusele ette. Ja viimaselt pildilt leiame selle, et kaasas on tuntud NT-H1 termopasta mida ma olen siin varem juba ka testinud.
Tegemist siis sama tekstiga mis oli tagaküljel lipu taga ja seda kuues erinevas keeles.
See on siis pakendi pealmine osa mis on kõikidest külgedest andmete poolest võiks öelda, et kõige informatiivsem kuna on välja toodud kõikide asjade (ventilaatorite, radiaatori) mõõtmed ja kaalud ja absoluutselt kõik mida sul on vaja teada nendest.
Siin on siis kõik mis pakendi seest leiab, veel enne seda peab ära mainima, et jahutus ise ja kõik asjad on väga targalt ära pakitud, esmalt pakki avades, leiab sealt pealt pärislaia ja pika karbi kuid paksuselt suhteliselt õhuke kuid mille sisse on ära pandud kõik kinnitused ja tarvikud, peale seda tuleb kohe üks pappümbris või selline mille ära võttes leiame alt jahutuse enda karbi veel oma korda mille sisse jahutus on pandud, jahutus ise on veel omakorda oma karbiga selle teise pappümbrise sees seega kui all on see papp ümbris ja üleval ka siis kui transportimisel peaks pakk maha kukkuma või muud sellist ei tohiks jahutus mitte mingil juhul vigastada saada. Nüüd minnes pakendi sisu juurde siis pakendist leiame me Inteli kinnitused, AMD kinnitused, kruvikeeraja, kasutusjuhend Inglise keeles ja veel leiab sealt üldised asjad.
Tegemist siis nendega mille leiab D14 Common Parts kilekoti seest, alustades vasakult on ülal Noctua kvaliteet termopasta NT-H1, selle all ventilaatori kummikinnitused kui on soovi ventilaatoreid kasutada hoopis korpuse küljes, selle kõrval on metallist Noctua kleeps. Veel on kaasas 4 kruvi millega saab veel ventilaatori kinnitada korpuse külge kui on soovi. Ja siis on veel jagaja, et kui sul on kaks ventilaatorit jahutuse küljes ja emaplaadil on aint 1 pesa kuhu ventilaator pista siis teeb see jagaja oma töö ära ja saad kahest ventilaatori pistikust ühe. Veel on kaasas kaks Ultra-Low-Noise Adaptrit, ehk siis nimetus ütleb ise ära, et kui selle paned ventilaatori juhtme ja pesa vahele siis töötab ventilaator väiksematel pööretel ja seega tekitab vähem müra.
See on siis see metallist Noctua logo mille saab kleepida oma korpusele või kus iganes soovid.
Noctua NH-D14:
Esmalt siis pakendist välja võttes on koheselt tunda kui suur see jahutus on, ta kaalub ilma ventilaatoriteta 900g ja koos ventilaatoritega 1240g mis on tõsiselt massiivne jahutus. Samuti pakendist välja võttes on ventilaatorid kohe küljes ja valmis paigalduseks, kuigi paigalduse jaoks tuleb keskmine ventilaator ära võtta. Samuti on teiselt pildilt näha ka jahutuse ribisid, esimeselt pildil on tegemist Noctua kvaliteet ventilaatoriga nimega NF-P12.
Nagu kahelt pildilt näha on ühel pildil jahutuse teine pool ja teisel pildil teine pool. Samuti on ka näha veel kinnituskruvisid mis on koheselt küljes ja millega on lihtne ja kiiresti võimalik paigaldada jahutus peale. Veel on näha, et kui jahutuse karbist välja võtad siis on talla küljes plastmasskaitse ees, et transportimisel või pakendist välja võttes ei saaks tald kahjustada mis mõjutaks tema jahutusomadusi. Mis üks hea asi veel sellel jahutusel hea on ventilaatorite paigaldus, ise saab valida kui kõrgele ja madalale sa ventilaatori paigaldad, see on just sellepärast hea, et kui mälud jäävad ette siis saab ventilaatori üles poole tõsta ja siis enam ei segagi mälud. Pildilt on ka näha Noctua ventilaatorite paigaldussüsteemi mis on päris unikaalne ja mida ma pole varem näinud, sellel kohal kindlasti suured kiitussõnad kuna ventilaatori paigaldus käib ainult paari sekundiga, võrreldes Xigmateki ventilaatori paigaldusega, on Noctua ventilaatorite paigaldamine mitu korda lihtsam kuna need klambrid on koheselt ka ventilaatorite küljes, seega ei pea neid hakkama ise paigaldama.
Vaade ülalt näitab ära meile 6 kuumatoru kummaski radiaatoris, tegemist on alumiinium radiaatoritega kuid mis Noctua jutu järgi on Nikliga üle pinnatud, mis annab hoopis lahedama välimuse kui lihtsalt alumiinium. Pildilt on veel näha ka mismoodi ventilaatorid kinnituvad klambritega mis neid kinni hoiab radiaatori küljes. Veel on näha, et mõlema radiaatori ühel küljel on selline plastmass või kuidas seda nimetada mis on siis selleks, et kui sa ventilaatori radiaatori külge paigaldad siis ta ei puutuks radiaatoriga kokku ja tekitaks müra ja samas ka selleks, et labad ei käiks vastu radiaatorit mis ei ole kohe üldse hea.
Mu viimases jahuti ülevaates mis oli Xigmatek Aegirist sooviti, et jahutuse tallast teeks ka pilti, siin ta on ja seekord ma siis tegin temast pilti ka, paljud on igalpool ütelnud, et tald ei ole väga sile ja on kumer, minul ta igas tahes sobis hästi peale ja temperatuurid ja näitajad on kõik normis. Näha on ka veel kuute kuumatoru mõlemalt poolelt mis on nikliga üle pinnatud. Üldiselt ütleks, et tald on sile ja ei tohiks tulla probleemi sellega, et jahutus ei puutu kokku piisavalt hästi protsessoriga. Kuid mis natuke negatiivne on see, et puudub H.D.T ehk Heatpipe Direct Touch, ehk siis mis annaks võib olla juurde veel väikest temperatuuri langust kuna kuumustorud puutuksid koheselt protsessoriga kokku ja kuumus transporditaks koheselt üles. Teisel pildil on näha veel kruvi, kruve on kokku kaks ja on nad selleks, et jahutus külge paigaldada, paigaldada on lihtne kuna ventilaator on lihtsalt eemaldatav ja kaasas olev kruvikeeraja teeb oma töö ära.
Noctua NF-P12 120mm ja Noctua NF-P14 140mm:
Tegemist siis kaasasoleva ventilaatoriga mis on võitnud mitmeid auhindu erinevatelt lehtedelt ja ajakirjadelt, mis ta labad huvitavaks teeb on ta sakid seal sees. Andmete poolest töötab ta 12V peal, tarbib 1.08W ja on 0.9A. Õhku liigutab ta 92.3 kuupmeetrit tunnis ja vastavalt kui panna Ultra Low Noise Adapter vahele liigutab ta õhku 63.4 kuupmeetrit tunnis. Häält teeb ta täispööretel 19.8 dB/A ja töötab ta SSO laagritega ehk eesti keeles ise stabiliseeruvate õli rõhu laagrid ja elueaks on tal 150000 tundi mis on piisavalt mitmeteks aastateks. Pööreteks on tal 1300 põõret minutis ja U.L.N.A-ga on 900 pööret minutis. Rääkides veel juhtmest on ta hästi ära kaetud mis on selline nagu kummimaterjal või muud sellist, kuid mis juhtme juures miinuseks on see, et ta on ääretult pikk, andmete järgi lausa 38.5cm.
Nüüd on tegemist siis 140mm ventilaatoriga mis asetseb jahutuse kahe radiaatori vahel, nagu näha on ka tal sakid sees ventilaatoril, mis eelmiselt pildilt puudu jäid on siin pildil olemas ehk siis, traatkinnitused mis on suureks plussiks sellel jahutusel nagu ka eelpool juba mainitud. Mis ka eelmisel ventilaatoril oli heaks, et on hästi ära kaetud juhe, aga mis miinuseks jälle on see, et on juhe liiga pikk ja mis jääb lihtsalt korpusesse ruumi võtma. Rääkides andmetest töötab nagu ikka 12V peal ja tarbib 1.2W ja tahab 0.10A. Nagu ka Noctua NF-P12 on tal SSO laagrid, töötab täispööretel 1200 pööret minutis ja U.L.N.A-ga 900 pööret minutis. Õhku liigutab ta NF-P12 rohkem ja mida oli ka arvata, ehk siis NF-P14 liigutab 110 kuupmeetrit tunnis ja U.L.N.A-ga 83.7 kuupmeetrit tunnis. Müra teeb ta 19.6 dB/A täispööretel ja elueaks on tal sama mis NF-P12'el ehk 150000 tundi.
Paigaldus:
Paigaldus on selle jahutuse juures lihtne, ma ise paigaldasin selle jahutuse AMD süsteemi seega see tähendas seda, et ma ei pidanud tagaplaati ära võtma ja uut asemele panema, kuid kruvid pidin ikkagist lahti keerama tagaplaadilt. Paigaldus on lihtne sellepärast juba, et kaasas on kasutusjuhend illustreerivate piltidega ja seega peaks saama isegi lugemisoskamatu inimene paigaldusega hakkama. Igastahes Rääkides nüüd lähemalt paigaldusest alustab sellest, et esmalt tuleb vanad kruvid ja paigalduse ära võtta ja siis Noctua enda klambrid vastavalt socketile külge panna. Peale seda kannad termopasta peale mis kaasas on või kui soovid võid ka midagi muud panna, peale seda paned jahutuse peale ja keerad kaasasolevate kruvidega jahutuse kinni. Peale seda paned ventilaatorid ka külge ja ongi valmis. Kuid mis natuke raskusi tekitas oli see, et kui oled ventilaatorid jagajasse ära pannud ja hakkad seda pistikut emaplaadi külge panema siis tekib natuke raskusi kuna mul on ventilaatori pistik emaplaadi ülemises osas ja seega oli päris vaev seda pistikut sinna panna.
Lõpptulemus:
Kuumustest:
Jahuteid testiti sellises arvutis:
Emaplaat: Asus M4A89GTD PRO
Protsessor: AMD Athlon X3 435 2.9 GHz @1.5V
Jahutus: Noctua NH-D14
RAM: Kingston DDR3 HyperX PC-12800 1600MHz 4GB
Videokaart: Gigabyte ATI Radeon HD 4870 512MB
Toiteplokk: Corsair HX520
Windows: Windows 7 Ultimate 32-bit
Kast: Cooler Master Gladiator 600
  • Ventilaatori pöörded on BIOS-es põhjas
  • Volt on pandud 1.5V peale, et eraldaks eriti palju sooja
  • Kast on hästi ventileeritud, ees 120mm, taga 120mm ja laes 140mm ja kasti küljepeal on kaks 120mm võre kust tuleb õhku
  • Temperatuure mõõdan HWmonitoriga
  • LOAD test tehakse Prime 95'ga
  • IDLE temperatuur saavutatakse sellega, et arvuti seisab umbes tund aega puutumata töölaual
  • Toatemperatuur on 20 kraadi juures
  • Kasutan kaasas olevat termopastat
Nagu näha ja arvata oli teeb Noctua kõikidele jahutitele ära, isegi passiivis kõlbab kasutamiseks kui ei ole väga võimas protsessor. Noctua NH-D14 pole lihtsalt vastast, kui siis võibolla kallis vesijahutus või midagi veel kangemat. Igastahes selle testi on võitnud täiesti pika eduga Noctua NH-D14.
Lõppsõna:
thumbs_up.gif Jahutab väga hästi
thumbs_up.gif Termopasta kaasas
thumbs_up.gif Vaikne
thumbs_up.gif Võimalik liigutada ventilaatorit üles või alla
thumbs_up.gif Nikliga pinnatud
thumbs_up.gif Lihtne paigaldada
thumbs_up.gif Ultra Low Noise Adaptrid
thumbs_down.gif Ei pruugi mahtuda väiksematesse kastidesse
thumbs_down.gif Kallis
Hinnaks on 83.10€ Hinnavaatluses
viimati muutis K3ndu 27.02.2011 11:09:52, muudetud 1 kord
Kommentaarid: 135 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 125
martin366
martin366
sõnum 25.02.2011 15:49:31 vasta tsitaadiga
Jahuti on super kuid hind on liiiiiga krõbe. TR Silver Arrow FTW thumbs_up.gif
Kommentaarid: 185 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
DamienDK
sõnum 26.02.2011 14:18:03 vasta tsitaadiga
Kena ülevaade. Aga ma olen norija mees, seega.. ürita mõningaid sõnu vähem kasutada, nagu "siis", "nüüd" jne. Mittemidagiütlevad sõnad.
Alguses ülevaadet lugedes mõtlesin, et peaks ise hakkama vist ostma seda. Hinda nähes aga.. icon_biggrin.gif
Osiris
Osiris
sõnum 28.02.2011 08:15:12 vasta tsitaadiga
Einoh kui asi tõesti nõnda hästi jahutab siis suva see hind. Oluline on jahe prose mitte, et igaltpoolt kokku hoiad. Hetkel endal plaanis asi ära osta. Näis siis kas on nõnda hää kui kiidetakse....
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
K3ndu
K3ndu
sõnum 28.02.2011 08:18:55 vasta tsitaadiga
Kui tahad kinnitust siis on olemas veel 249 ülevaadet, http://noctua.at/main.php?show=reviews&lng=de&product_select=34 icon_biggrin.gif
korsten
sõnum 28.02.2011 08:53:32 vasta tsitaadiga
See sihuke nii ja naa teema. Suht paljud jahutused ei sisalda nn. "põhipaketis" vente mis teevad letihinn küll odavamaks aga lisanduvad veel kulutused headele ventidele mis ei pruugi odavad olla (+ järelkäimise ja/või postikulud). Megahalems ja Armageddon olgu näiteks...
Ma ei kuuluta jumalikku tõde vaid avaldan oma isiklikku subjektiivset arvamust.
God Hates Us All
Kommentaarid: 62 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
martin366
martin366
sõnum 28.02.2011 09:07:30 vasta tsitaadiga
Ma ostaks küll ennem TR Silver Arrow-i.
1. Odavam
2. Vaiksemad vendid (2x140mm)
3. Jahutusomadused võrdsed
Saadavusega on niru aint, Soomest saaks. 68€ oli vist.. Saksas on 58€.
Kellel viitsimist tegeleda see saab.
minake
minake
sõnum 01.03.2011 11:14:04 vasta tsitaadiga
huvitav kas see codegen priza black korpusse ka 2ra mahub? peaks 2ra m66tma kodus...
teine asi mis mind m6tlema pani oli see, et ega see 1kg jurakas kuidagi emaplaati v22ndesse ei aja kui ta seal sedasi ripub kuude ja aastate kaupa icon_rolleyes.gif
endal on masin pystises asendis...
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 137
K3ndu
K3ndu
sõnum 01.03.2011 15:33:54 vasta tsitaadiga
minake kirjutas:
Noo eks selle jaoks vastavad kinnitused kaasas.
ModiKomP
ModiKomP
sõnum 01.03.2011 22:02:02 vasta tsitaadiga
Ehehe, kasutajale kes teab kedagi kes teab kedagi kes teab kes käis koputamas noctua lehel, et meil on noctua tooted kallid, sellele vabalt valitud kohal olev noctua toode tasuta koju kätte. Aus ülestunnistus väärib sama tasu. Huvitab miks me kallid oleme, kui oleme turu odavaimad?
Lugupidamine
http://www.modikomp.ee/soodus/
K3ndu
K3ndu
sõnum 02.03.2011 07:13:22 vasta tsitaadiga
ModiKomP kirjutas:
Mina küll kitse pole pannud, tunnistan ausalt üles ja pole ka selleks põhjust.
AJ
AJ
sõnum 02.03.2011 09:24:15 vasta tsitaadiga
ModiKomP kirjutas:
Osiris
Osiris
sõnum 06.03.2011 17:56:14 vasta tsitaadiga
ModiKomP kirjutas:
alustuseks, et mina pole infot levitanud - aga huvitab see, et mis oli siis selle esinduse skype kõne tagajärg icon_biggrin.gif
ModiKomP
ModiKomP
sõnum 08.03.2011 19:45:13 vasta tsitaadiga
PCman kirjutas:
ModiKomP kirjutas:
Sain täna Noctua uuendatud hinnakirja suure pealekäimisele kätte. Eks vaatame, hinnad -soovitused üle. Eks paistab, äkki läheb lõpptarbijal elu paremaks edasi müüa soovijatel ja konkurentidel elu kehvemaks.
Lugupidamine
smurfar
smurfar
sõnum 09.03.2011 06:32:49 vasta tsitaadiga
ot:
ModiKomP kirjutas:
Ehehe, kasutajale kes teab kedagi kes teab kedagi kes teab kes käis koputamas noctua lehel, et meil on noctua tooted kallid icon_razz.gif
Et nagu eestis või teie poes?
Parandan lõhutud küttepuid. Hind kokkuleppel
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 106
K3ndu
K3ndu
sõnum 09.03.2011 07:59:23 vasta tsitaadiga
ModiKomP kirjutas:
PCman kirjutas:
ModiKomP kirjutas:
Noctua annab hinnad ette ja teil kõige soodsam ja te saate ikka kitse? icon_confused.gif
Ox-is sama jahutus müügi l116 eurot ja vanad pole ktise saanudki või?icon_biggrin.gificon_biggrin.gif
sõnum 09.03.2011 13:09:50 vasta tsitaadiga
K3ndu kirjutas:
ModiKomP kirjutas:
PCman kirjutas:
ModiKomP kirjutas:
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 765 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
ModiKomP
ModiKomP
sõnum 09.03.2011 19:24:49 vasta tsitaadiga
K3ndu kirjutas:
ModiKomP kirjutas:
PCman kirjutas:
ModiKomP kirjutas:
Nii ta on, ametlikult on mul ainukesena tegutsev maaletoomis õigus, teised võivad ka müüa läbi hulgifirmade mida reguleerib euroseadus- vabaturumajandus.
Lugupidamine
Osiris
Osiris
sõnum 08.11.2011 23:48:30 vasta tsitaadiga
Sai ka see jurakas külge topitud.
Proseks on Phenom II X4 955 BE - ei tea milles asi aga niisama netis kolades näitab temperatuuriks 50 kraadi ja seda Fractal Design Define R3 korpuses.
Milles asi võiks olla? Kas prose liiga võimas või on paigaldusel ihu läinud?
sakinaga
sõnum 08.11.2011 23:56:27 vasta tsitaadiga
katsu käsi lähedale panna, kas on kuum? Kui ei, siis on midagi valesti läinud paigaldamisel.
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 155
