praegune kellaaeg 24.04.2026 16:54:02
mightythor
25.04.2011 02:00:02
Debian ja Sierra Wireless MC8755 HSDPA adapter |
Mul on IBM T60 sülearvuti integreeritud Sierra Wireless MC8755 HSDPA adapteriga:
# lsusb | grep -i sierra
Bus 003 Device 008: ID 1199:6804 Sierra Wireless, Inc. MC8755 Device
Dmesg väljundi kohaselt on adapter seotud /dev/ttyUSB0 failiga. wvdialconf utiliidi abil tekitasin järgmise seadistuse:
# cat /etc/wvdial.conf
[Dialer Defaults]
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Modem Type = Analog Modem
; Phone = <Target Phone Number>
ISDN = 0
; Username = <Your Login Name>
Init1 = ATZ
; Password = <Your Password>
Modem = /dev/ttyUSB0
Baud = 9600
..ning seda kohendades on mul praegu /etc/wvdial.conf faili sisu järgmine(operaator on EMT):
[Dialer Defaults]
Baud = 9600
ISDN = 0
Phone = *99#
Init1 = ATZ
Init3 = AT+CGDCONT=1,"IP","internet.emt.ee"
Username = usern
Password = passwd
New PPPD = yes
Stupid mode = on
Auto Reconnect = off
Modemi asukoht(/dev/ttyUSB0) on õige, andmeedastuskiirus on kah sobiv, number(*99#) peaks olema õige. Modemile saadetavad käsud peaksid olema korras- kõige olulisem parameeter APN peaks olema "internet.emt.ee". Proovisin ka lihtsalt "internet". Kuna Eesti operaatorid autentimist ei taha, siis "Password" ja "Username" parameetrid panin suvalised ning hetkel keelasin korduva ühendamise(Auto Reconnect = off). "New PPPD = yes" on wvdial.conf manuali soovitusel, sest kasutan uuemat PPPD versiooni kui 2.3.0.
Paraku aga ei õnnestu PPP ühendust luua:
# wvdial
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZ
ATZ
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Sending: AT+CGDCONT=1,"IP","internet.emt.ee"
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
ATDT*99#
CONNECT
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Mon Apr 25 01:24:07 2011
--> Pid of pppd: 27355
--> pppd: p[1d]�[08]8[1c]�[08]�[1b]�[08]
--> Using interface ppp0
--> Authentication (CHAP) started
--> Authentication (CHAP) successful
--> Disconnecting at Mon Apr 25 01:24:08 2011
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
/var/log/messages faili kirjutatakse järgmist:
Apr 25 01:24:07 T60 pppd[27355]: pppd 2.4.5 started by root, uid 0
Apr 25 01:24:07 T60 pppd[27355]: Using interface ppp0
Apr 25 01:24:07 T60 pppd[27355]: Connect: ppp0 <--> /dev/ttyUSB0
Apr 25 01:24:07 T60 pppd[27355]: CHAP authentication succeeded
Apr 25 01:24:07 T60 pppd[27355]: Modem hangup
Apr 25 01:24:07 T60 pppd[27355]: Connection terminated.
Apr 25 01:24:08 T60 pppd[27355]: Exit.
AT modemi käsud tunduvad õiged olevat.. Peale CHAP autentimise õnnestumist peaks hakkama võrgukihi parameetrite(IP aadress, DNS server) jagamine, kuid seda ei juhtu.
Lisaks veel seda, et kui ma "Stupid Mode" keelan, siis on tulemus selline:
# wvdial
--> Sending: ATZ
ATZ
OK
OK
OK
--> Sending: ATD*99#
ATD*99#
CONNECT
--> Carrier detected. Waiting for prompt.
--> Don't know what to do! Starting pppd and hoping for the best.
--> Starting pppd at Mon Apr 25 01:53:28 2011
--> Pid of pppd: 27507
--> pppd: ���[08]���[08]���[08]Xg�[08]
--> Disconnecting at Mon Apr 25 01:53:29 2011
On ehk kellegi ideid, mida veel proovida? Või oli minu seadistustes kuskil viga? Kui mingit lisainfot on tarvis, siis küsige kohe
| Kommentaarid: 62 loe/lisa |
53 |
Riivo
25.04.2011 17:28:04
| Justkui mäletan, et kunagi sai ise sama probleemi otsas oldud, aga lahendust ei mäleta. Kui võimalus mõnelt tuttavalt hetkeks USB modem laenata, siis proovi sellega samu seadistusi ja SIM-kaarti. See aitaks probleemi piirata modemile saadetavate käskudeni.
221 |
mightythor
29.04.2011 02:48:05
Riivo, mul polnud võimalik USB liidesega modemit laenata, kuid natuke põhjalikumalt uurides tuli välja, et mainitud MC8755 adapter on operaatorilukuga. Terminali emulaatoriga modemilt PIN koodi staatust küsides oli vastuseks:
AT+CPIN?
+CPIN: PH-NET PIN
OK |
Seega ma alustasin sellest, et panin virtuaalamasinas jooksma Windows 7 ja paigaldasin sinna peale DC-unlocker tarkvara, millega peale mõningat pusimist õnnestus operaatorilukk eemaldada.
Peale lahti lukustamist PIN koodi staatust küsides on vastuseks:
at+cpin?
+CPIN: SIM PIN
OK |
Seega sisestasin SIM'i PIN koodi käsuga:
..mille peale muutus staatus:
..ning olin operaatori võrgus registreeritud(tundub, et sellel MC8755 kaardil on isegi temperatuuri sensor olemas):
at!gstatus?
!GSTATUS:
Current Time: 11186 Temperature: 39
Bootup Time: 2866 Mode: ONLINE
System mode: WCDMA PS state: Attached
WCDMA band: IMT2000 GSM band: GSM900
WCDMA channel: 10712 GSM channel: 75
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
WCDMA L1 State:L1M_PCH_SLEEP RRC State: DISCONNECTED
RX level (dBm):-73
OK |
Viimaks käivitasin PPP wvdial -i abil(sama wvdial.conf seadistus, mis esimeses postituses) ning sain omale kenasti automaatselt võrguparameetrid
53 |
