praegune kellaaeg 20.11.2026 20:11:29
Turboorav
08.04.2011 20:36:42
openSUSE Gnome 3 ekraan väga hämar ning musepad ei tööta |
Installisin endale openSUSE 11.4 Gnome 3 keskkonnaga OS'i. Selline jama, et ekraan on ilgelt hämar. Süsteemi sätete alt näitab, et on maksimumis ning klahvide pealt eredamaks, tuhmimaks pannes midagi ei muutu. Lisaks ei töta mousepad plaadi peale vajutamine. St.. nuppude asemel kastan plaaadile vajutamist.
Kuidas neid probleeme parandada.
Läpakas on Samsung R410 plus.
Videokaart mingi Intel Mobile 4 family vms, integreeritud.
Leidsin release notes alt sellise asja:
Initializing Graphics with KMS (Kernel Mode Setting)
With openSUSE 11.3 we switched to KMS (Kernel Mode Setting) for Intel, ATI and NVIDIA graphics, which now is our default. If you encounter problems with the KMS driver support (intel, radeon, nouveau), disable KMS by adding nomodeset to the kernel boot command line. To set this permanently, add it to the kernel command line in /boot/grub/menu.lst. This option makes sure the appropriate kernel module (intel, radeon, nouveau) is loaded with modeset=0 in initrd, i.e. KMS is disabled.
In the rare cases when loading the DRM module from initrd is a general problem and unrelated to KMS, it is even possible to disable loading of the DRM module in initrd completely. For this set the NO_KMS_IN_INITRD sysconfig variable to yes via YAST, which then recreates initrd afterwards. Reboot your machine.
On Intel without KMS the Xserver falls back to the fbdev driver (the intel driver only supports KMS); alternatively, there is the "intellegacy" driver (xorg-x11-driver-video-intel-legacy package) which still supports UMS (User Mode Setting). To use it, edit /etc/X11/xorg.conf.d/50-device.conf and change the driver entry to intellegacy.
On ATI for current GPUs it falls back to radeonhd. On NVIDIA without KMS the nv driver is used (the nouveau driver only supports KMS). |
_________________ With the Faith of a mustard seed if you tell a mountain to move there it will move |
