praegune kellaaeg 20.11.2026 20:11:31
Turboorav
03.03.2011 21:56:36
Uuesndamine 10.04 10.10 peale |
Sain sellise errori, kui oli faasis "uute tarkvarakanalite seadistamine"
Uuenduse arvutamine polnud võimalik
An unresolvable problem occurred while calculating the upgrade:
E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
This can be caused by:
* Upgrading to a pre-release version of Ubuntu
* Running the current pre-release version of Ubuntu
* Unofficial software packages not provided by Ubuntu
Kui ükski neist ei vasta tõele, raporteeri veast 'update-manager' paki kohta ning pane vearaportisse kõik failid kaustast /var/log/dist-upgrade/.
Et siis, mida teha? Tänan!
_________________ With the Faith of a mustard seed if you tell a mountain to move there it will move |
tiitise
04.03.2011 11:59:17
| mida näitab /var/log/dist-upgrade/apt.log faili viimased read?
| Kommentaarid: 6 loe/lisa |
