praegune kellaaeg 09.11.2026 21:09:51
GuyFromMars
03.02.2011 20:35:10
Microsoft .NET Framework probleem |
Tere , nimelt on mureks et Microsoft .NET Framework viskab arvuti käivitades ette sellise errori : Unhandled exception has occurred in your application. If you click Continue, The application will ignore this error and attempt to continue. If you click Quit, the application will close immediately
Could not find file 'C:/Documents and Settings/USER/links2.txt'.
Detailides :
************** Exception Text **************
System.IO.FileNotFoundException: Could not find file 'C:\Documents and Settings\USER\links2.txt'.
File name: 'C:\Documents and Settings\USER\links2.txt'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize)
at System.IO.StreamReader..ctor(String path)
at Keygen.Form1.Form1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Operatsiioni süsteemiks on Windows XP SP3 32 bit.
Olen proovinud reinstalli aga pole aidanud.
_________________ XBL GT: GuyFromMars |
A.S.
03.02.2011 20:45:44
Ära siis lase sellist programmi käima, mis seda links2.txt faili vajab.
Guugli soovitus on Malwarebytes.
| Kommentaarid: 34 loe/lisa |
34 |
GuyFromMars
03.02.2011 21:10:54
| A.S. kirjutas: |
Tõmbasin selle , leidis 3 troojat , puhastas ära ja tegi restardi nüüd kõik korras tänud!
