praegune kellaaeg 07.10.2026 02:25:52
John Blaze
31.01.2011 14:02:28
Ardour ja Jack |
Nii et siis üritan saada ardouri tööle enda arvutis.
Peal Ubuntu 10.10 64bit ja installitud ubuntu studio audio pack
igasugune abi või suunamine abiks, kuna ei tea sellest teemast eriti midagi
Jack controli tööle pannes saan sellise errori
12:40:01.547 Patchbay deactivated.
12:40:01.573 Statistics reset.
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
12:40:01.598 ALSA connection graph change.
12:40:01.996 ALSA connection change.
12:52:32.424 Startup script...
12:52:32.425 artsshell -q terminate
sh: artsshell: not found
12:52:32.828 Startup script terminated with exit status=32512.
12:52:32.882 JACK is starting...
12:52:32.883 /usr/bin/jackd -r -dalsa -dhw:0 -r44100 -p1024 -n2
12:52:32.887 JACK was started with PID=22478.
Cannot create thread 1 Operation not permitted
jackdmp 1.9.6
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2010 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in non-realtime mode
Cannot lock down memory area (Cannot allocate memory)
audio_reservation_init
Acquire audio card Audio0
creating alsa driver ... hw:0|hw:0|1024|2|44100|0|0|nomon|swmeter|-|32bit
Using ALSA driver HDA-Intel running on card 0 - HDA Intel at 0xefffc000 irq 45
the playback device "hw:0" is already in use. Please stop the application using it and run JACK again
Cannot initialize driver
JackServer::Open() failed with -1
Failed to start server
12:52:33.120 JACK was stopped with exit status=255.
12:52:33.120 Post-shutdown script...
12:52:33.121 killall jackd
jackd: no process found
12:52:33.531 Post-shutdown script terminated with exit status=256.
12:52:35.028 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
12:52:42.291 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
12:52:54.113 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
jack server is not running or cannot be started |
| Kommentaarid: 70 loe/lisa |
pota
01.02.2011 19:13:59
Pean kohe ütlema, et ei ole Ubuntu kasutaja, samas töötab mul ardour (svn) gentoo'ga väga edukalt.
See rida - 'Cannot create thread 1 Operation not permitted' vihjab probleemile pam'i seadistuses,
sul on vaja nn. rtlimits-enabled seadistust - vaata faili '/etc/security/limits.conf' seal peaks olema midagi sellist:
@audio - nice -10
@audio - rtprio 99
@audio - memlock unlimited |
kui ei ole siis lisa need read ja seejärel lisa oma kasutaja gruppi 'audio' (kui ta juba ei ole seal)
Testmiseks käivita jack otse selle sama reaga '/usr/bin/jackd -r -dalsa -dhw:0 -r44100 -p1024 -n2' konsoolist
(mis asi see 'jack control' on, ei tea sellist, äkki mõtled 'qjackctl'...).
Kas Ubuntu mitte ei kasuta pulseaudio't? Kui jah siis peaks selle kuidagi eemaldama või vähemalt jack'i
katsetamise ajaks seiskama, see rida - 'playback device "hw:0" is already in use' ütleb, et miski juba kasutab su helikaarti.
