sõnum  |
beastbeats
| Kommentaarid: 343 loe/lisa |
264 |
minake
07.12.2011 20:55
So why are those PS Vita memory cards so costly?
Well according to Sony it's you!
They say that part of the cost is because of the included DRM systems to provide Sony with security from their customers!
One of the questions asked to Sony Vita developers recently was in regard to 'On Custom Memory Cards', their reason for it is:
Explained Shimada, The reason Sony didn't use general memory cards like SD Cards and instead opted for a custom memory card is because they wanted to make sure they could have something with an equal condition for everyone. Additionally, they were concerned with security.
Shimada also drew distinction about describing the cards as merely a device for saving games. They're "storage" for the Vita, and are used for patches, game data, download content and more.
Viewing the 'source link' below, you can find some other important PS Vita answers to more questions.
Like 'Adobe Flash' (they are still talking with Adobe) - Translation - 'Don't hold your breath'!
And 'PSP Backwards Compatibility' (it will be a combo of software and hardware, with firmware updates) - Translation - 'Feature to be removed at later date'! |
http://www.maxconsole.com/cgi-bin/maxconsole/rknewz.pl?function=detail&id=RKSID00000000000000000334&cat=PSP
Q: How many PSN account can be set up on a Vita system?
Then the answer is:
A: Only 1 account. If you want to to use a different account, you need to format the system to factory settings.
http://ps3gens.com/2011/12/03/only-1-psn-account-per-ps-vita/
| Kommentaarid: 150 loe/lisa |
129 |
beastbeats
09.12.2011 13:16
"Sony associate brand marketing manager Crystal MacKenzie said that PlayStation Network accounts will be connected to the Vita’s proprietary memory cards, not the hardware itself."
http://www.wired.com/gamelife/2011/12/vita-accounts/
_________________ Päevad lõpevad siis, kui lased neil minna... |
264 |
kalluka
09.12.2011 14:07
| Oh loodame, et kähku ära lahti kräkitakse see seade. Nõme, et ikka jõulude ajaks välja ei tule.
| Kommentaarid: 16 loe/lisa |
12 |
iDemon
09.12.2011 14:11
| kalluka, milleks sul seda kräkituna vaja on?
| Kommentaarid: 122 loe/lisa |
104 |
beastbeats
09.12.2011 14:18
| kalluka kirjutas: |
| Oh loodame, et kähku ära lahti kräkitakse see seade. Nõme, et ikka jõulude ajaks välja ei tule. |
Tuleb ju - Aasias
P.S selle "kräki" jutuga võid...
264 |
minake
09.12.2011 21:56
| kalluka kirjutas: |
Mina isiklikult ei n2e miskit positiivset uue seadme hackimisel, ma saan aru, et asi on juba 3-4a turul olnud ja m2ngude nimekiri on piisavalt suur ning enamus tootjaid on juba raha piisavalt saanud siis maybe oleks asjal m6tet.
129 |
kalluka
09.12.2011 22:24
| Nojah, ise sai ka vanale riistapuule mänge ostetud aga ausaltöeldes viskasid need plaadid kopa ette ja samuti ka nende hind.
12 |
minake
09.12.2011 22:43
| kalluka kirjutas: |
| Nojah, ise sai ka vanale riistapuule mänge ostetud aga ausaltöeldes viskasid need plaadid kopa ette ja samuti ka nende hind. |
alguses on k6ik asjad kallid, ei tasu kohe tormata, hetkel saaks ka tellida endale aasiast vita j6uludex eestisse, ainult, et see l6bu l2hex mingi 500-600 euri maksma
plaadid olid jah suht uimased jne, nüüd tuleval konsoolil on m2lukaardil m2ngud, mis peaks tunduvalt nobedamad olema kui psp-l plaatidega oli.
129 |
kalluka
17.12.2011 11:40
Esimesed ülevaated juba lekivad. Tsuksikeeles nad on aga toidab.
12 |
beastbeats
264 |
kalluka
19.12.2011 17:38
Njaaa. Pandav konsool ikka . Aga tõesti. Miks vaja selle mälukaardiga jebida niimoodi. Sama oli selle ms pro duoga. Ullu pappi maksid suuremahulised kaardid. Miks ei võinud seda edasi kasutada? Enamus sony seadmeid kasutavad sama mälukaarti.
12 |
minake
19.12.2011 18:35
| kalluka kirjutas: |
Njaaa. Pandav konsool ikka . Aga tõesti. Miks vaja selle mälukaardiga jebida niimoodi. Sama oli selle ms pro duoga. Ullu pappi maksid suuremahulised kaardid. Miks ei võinud seda edasi kasutada? Enamus sony seadmeid kasutavad sama mälukaarti. |
ilmselt on nii majanduslikult sony-le kasulikum
edit: keri natu ylespoole, seal sellest ka v2he kirjas mix seda teed mindi.
129 |
kalluka
19.12.2011 19:02
Jeps tõesti. Samas kui mul mitu sony seadet, mis sama lahendust kasutab siis see tähendab, et pean jälle hunniku raha kulutama
Aga saan neist täiesti aru. Eks konsool ikka omamoodi odava hinnaga
12 |
beastbeats
264 |
iDemon
20.12.2011 15:21
Esimese kahe päevaga.
104 |
minake
20.12.2011 16:01
n2is mis hinnaga see siia j6uab ja kas siis juba rohkem m2nge ka sellele on... hetkel play-aasiast tellides l2hex 525$ + transa + toll ja sinna juurde veel m2ngud... ei kisu kuidagi ostma
129 |
iDemon
20.12.2011 16:12
minake, hinnast on ju juttu olnud.
249€ on WiFi mudel.
299€ on 3G+WiFi mudel.
Müügil juba vähem kui kahe kuu pärast.
Mängude hinnad on varieeruvalt 19€~39€
104 |
minake
20.12.2011 19:38
| iDemon kirjutas: |
249€ on WiFi mudel.
Mängude hinnad on varieeruvalt 19€~39€ |
muig, see on reklaamitud hind, vaevalt, et alguses neid osta sellise hinnaga saab
+ veel arvestades meie kaupmeeste ahnust.
Samas saab muidugi amazonist ka tellida, ex vaatab.
A esialgu ei usu, et sellise hinnaga alguses saab... julgelt v6ib igale hinnale 50 euri otsa lisada, ei imestax kui meil hakkab hind olema algul 350 ja 400
129 |
beastbeats
20.12.2011 21:40
minake, nt. Soomes saab selliste hindadega pre-order'eid teha
Eesti hindadest ei hakkaks parem rääkima - "nämmutatud" teema juba
264 |
Shade
20.12.2011 21:44
| minake kirjutas: |
| + veel arvestades meie kaupmeeste ahnust. |
Ahnusest on tihti peale asi kaugel. Kui ette kujutust pole mis hinnaga asjad siia turule liiguvad, siis pole mõtet kaupmehi kohe maha peksta ja liigkasu võtjateks tembeldada. Alati paneb ostuhinna tugevalt piaka kogus, ja eestis me just suurte kogustega hõisata ei saa. Ja isegi kui me paneks siia juurde need kogused mida hetkel netist ostlejad ostakisd, ei küündiks meie kogused mitte kuhugile.
Mina peaks lähiajal esimesed hinna kalkulatsioonid kätte saama, ise arvan et Wifi tuleb 269-279 ja 3G kuskil 319-329 hinnakanti.
Uuest aastats igatahes plaan tugevamalt Sony pigistama hakata, et kas Eesti on euro liidu osa või oleme ikkagi jäänuk, kui kuulutatte hinna välja siis pakkugu ka sellist ostuhinda, mis võimaldab meil antud hindasid ka järele teha.
_________________ GT: janrist
PSN: janrist
Just for fun: Mängupunker |
| Kommentaarid: 23 loe/lisa |
21 |
JOKKER666
20.12.2011 22:48
| Kas mitte nt Euronics ei ole ka Soomes ja Rootsis. Miks väike Eesti Euronics ostab sisse kalllimalt kui Rootsi ja Soome, kindlasti on neil mingi keskladu ja ikkagi eestlasi nööritakse. Ja kui siiski sellisel suurel firmal ostetakse sisse kaupa eraldi igas riigis eraldi, on nagu midagi väga valesti.
| Kommentaarid: 46 loe/lisa |
42 |
beastbeats
20.12.2011 23:04
| JOKKER666 kirjutas: |
| Kas mitte nt Euronics ei ole ka Soomes ja Rootsis. |
Nagu ma aru olen saanud, siis see Eesti hädaks ongi - ühes "potis" koos suurte (ja rikaste) Skandinaavia "vendadega"...
264 |
minake
20.12.2011 23:05
okei, ex ootame ja n2eme mis maksma hakkavad.
leidsin veel sellise huvitava fakti, ei tea kas see ka edaspidi hakkab olema aga:
Sony has confirmed that the $249 PS Vita will be UNABLE to play the following titles out of the box:
@field
Uncharted: Golden Abyss
Dream Club Zero
Disgaea 3
Hot Shots Golf 6
Monster Raider
Ridge Racer
For all of those games to run you MUST buy an add on memory card as they will be unable to save to their own carts.
Why does Nintendo include a memory card when it really is optional (all retail games save to their own carts) yet Sony omits one when its an absolute requirement if you want to play their biggest launch titles? |
http://www.maxconsole.com/cgi-bin/maxconsole/rknewz.pl?function=detail&id=RKSID00000000000000000348
129 |
beastbeats
20.12.2011 23:19
minake, see on ju juba mõnda aega teada, et osad mängud töötavad ainult koos mälukaardiga; mis iseenesest on tobe...
264 |
