uus teema   vasta Tarkvara »  Linux & UNIX »  Kubuntul heli puudu märgi kõik teemad loetuks
erxx
erxx
sõnum 25.01.2011 13:53:01 Kubuntul heli puudu vasta tsitaadiga
Asi siis selline, et ei suuda kuidagi moodi häält kätte saada.
Emaplaat on Asus M2N-E SLI helikaardi kiip on c-media oma ja linuxile driverit ei leia.
Mingisugune oli asuse lehel, aga tolle peale ütleb, et kernel ei sobi vms.
kellelgi ideid? Saab ekh mingit moodi konsoolis asja lahendada?
Master channel peab ikka "Speaker" peal olema?
Windowsi drivereid ei anna kuidagi kasutada nagu seda saab wifi driverite puhul teha?
tiitise
sõnum 25.01.2011 14:09:52 vasta tsitaadiga
pasteeri siia kahe käsu (lsusb, lspci) tulemus konsoolis
erxx
erxx
sõnum 25.01.2011 14:29:34 vasta tsitaadiga
erxx@asus:~$ lsusb
Bus 002 Device 002: ID 0d8c:0201 C-Media Electronics, Inc. CM6501
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
erxx@asus:~$ lspci
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev f3)
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev f2)
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev f2)
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev f3)
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev f3)
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev f3)
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev f3)
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:01.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
01:07.0 Ethernet controller: Marvell Technology Group Ltd. 88w8335 [Libertas] 802.11b/g Wireless (rev 03)
06:00.0 VGA compatible controller: nVidia Corporation G84 [GeForce 8600 GT] (rev a1)
erxx@asus~$
tiitise
sõnum 25.01.2011 16:30:45 vasta tsitaadiga
copy/paste foorumist:
Re: Help with sound in Asus M2N-E SLI
hi, i think i have the solution..
the problem is, that alsa lists your card as number "1", and not number "0".
number "0" is the default card, and that's what most programs expect to use.
this is what i did to achieve it:
1. edit the /etc/modprobe.d/alsa-base file (as root),
2. find the line which contains snd-usb-audio.
3. comment it out, or simply delete it.
4. restart your computer
now everything should work correctly.
(basically, it seems that alsa is configured so that it does not allow the "usb sound card" to become the default card. and, somehow, our sound-card is detected as usb-sound-card. these instructions simply remove that restriction from alsa)
i found this when reading this thread:
http://ubuntuforums.org/showthread.php?t=205449
sõnum 25.01.2011 16:50:42 vasta tsitaadiga
Või on see eraldi kaart?
erxx
erxx
sõnum 26.01.2011 01:24:07 vasta tsitaadiga
Ei ole eraldi kaart, täitsa emaplaadi küljes. Ei saa ise ka aru mis ta seal usb all teeb.
Proovin kohe selle foorumi copy/paste järgi.
EDIT:
Ei tea kas on õige asi, aga heli ei tulnud.
alsa-base fail:
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
# Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
#options snd-usb-audio index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
options snd-usb-caiaq index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
tiitise
sõnum 26.01.2011 13:38:44 vasta tsitaadiga
Proovi alsa-t kasutada, äkist aitab.
sudo apt-get autoremove pulseaudio
Restart
erxx
erxx
sõnum 26.01.2011 14:27:43 vasta tsitaadiga
Tegin midagi icon_biggrin.gif ei tea mida, hääle sain aga kubuntust ei jäänud järgi midagi icon_biggrin.gif
Tundub, et muutus ubuntuks, kuidagi kubuntuks pole tagasi võimalik installida? või siis Estobuntuks?
E:
Kuni sisse logimiseni on ikka kubuntu ja sisse logides muutub nö theme ubuntu omaks. Tagasi ei saaks kuidagi?
tiitise
sõnum 26.01.2011 14:31:36 vasta tsitaadiga
Enne logimist vaata, millisesse aknahaldurisse sisse logitakse.
Juhul kui seal valikus kubuntut (KDE) ei ole siis kirjuta selline asi terminali:
sudo apt-get install kubuntu-desktop (peaks paigaldama kubuntu tagasi)
xpander
xpander
sõnum 26.01.2011 15:25:42 vasta tsitaadiga
Dogbert kirjutas:
Mul sama emaplaat ja näitab samuti USB soundcard. (kuigi tegelikult pole..mingi c-media crapp ta on)
aga mul pole kunagi sellega probleemi olnud..alates ubuntu 7.04 kuni tänase 10.10ni..toimib probleemideta.
kunagi pulseaudio algusaegadel tuli mingisse faili paar rida kirjutada...aga ei mäleta täpselt.
Linux Gaming Videos: Xpander69
sõnum 26.01.2011 20:08:29 vasta tsitaadiga
Windowsis pidavat sel platel ka helikaart USB seadmena kirjas olema, nii et see ongi päriselt USB helikaart seal plate peal. Ei ole mingi Linuxi veidrus ega näita valesti.
xpander
xpander
sõnum 26.01.2011 21:33:18 vasta tsitaadiga
Dogbert kirjutas:
Jah windowsi default driveriga näitab tõesti PnP USB soundcard. kuid Kui cmedia oma peale lasta siis ei näita
aga c-media on teada tuntud kehva driveri supporti poolest.
igatahes linuxis peaks ta küll by default toimima..ei oska muidugi Kubuntu kohta täpselt öelda...mis trikke seal see pulseaudio tegema on pandud.
erxx
erxx
sõnum 27.01.2011 00:57:24 vasta tsitaadiga
suur13
suur13
sõnum 04.03.2011 12:45:27 vasta tsitaadiga
Lihtsalt infoks - see emaplaat (oli endal ka kunagi) on pärit aegadest kui toimus üleminek integreeritud AC97 helilt HD Audio standardile ja kuna nVidia CK804 chipset (nForce 500) ei toetanud veel HD Audio standardit, siis leidis Asus "elegantse" lahenduse, mis oleks nagu iseenesest pidanud pakkuma paremat heli kui vana AC97 (ja Realtek ALC850 või mis iganes kive siis kasutati). Alates nForce 520 seeriast oli HD toetatud ja sellist pornot polnud vaja enam teha.
Kommentaarid: 203 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 188
