praegune kellaaeg 06.11.2026 04:05:38
redenergy
04.01.2011 18:30:47
PHP keelefail ja utf-8 probleem |
Tere,
Nimelt tegin test.php lehe, Annan koodi ka.
| php-brief:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <title>Test</title> </head> <body> <?php ?> <br /> õüöä <br /> <a href="#">õüöä</a> <br /> <a href="testin.php?lang=et"><img src="images/ee.gif" alt="est" /></a><a href="testin.php?lang=en"><img src="images/gb.gif" alt="eng" /></a><a href="testin.php?lang=de"><img src="images/de.gif" alt="ger" /></a><a href="testin.php?lang=fi"><img src="images/fi.gif" alt="fin" /></a> <?php $lang = $_GET['lang']; switch ($lang){ case 'en': include 'lang_en.php'; break; case 'et': include 'lang_et.php'; break; case 'de': include 'lang_de.php'; break; case 'fi': include 'lang_fi.php'; break; default: include 'lang_et.php'; } echo $lang['MENU_WINDMILL']; ?> </body> </html>
Ja lang_de fail:
| php-brief:
<?php $lang['MENU_WINDMILL'] = 'Windmühle'; ?>
Probleem seisneb selles, et include'tud lang_failid ei kuva täpitähti. Esimesed 3 testi töötavad.
Ehk oskab keegi aidata?
| Kommentaarid: 30 loe/lisa |
9 |
Nokia
Serverid.ee
04.01.2011 18:38:41
kas see faili editor mida kasutad, salvestab ka encoding UTF-8?
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
redenergy
04.01.2011 19:31:07
Kasutan Dreamweaver 4CS
Page properties:
Document Type: XHTML 1.0 Traditional
Encoding: Unicode (UTF-8)
Unicode Normalization Form C(Canonical Decomposition, followed by canonical decomposition
Include Unicode Signature (BOM) on linnuke eest ära.
Salvestasin lang_de.php notepadiga UTF-8 formaati ja tööle hakkas!?
Mis mul Dreamweaveri seadetest valesti võib olla siis? Pole neid settinguid ise muutnud.
Hetkel võtsin Preferences - new document - default encodingult linnukese. Ja tundub, et sain tööle.
Failid mis näitavad ? salvestan notepadiga ümber ja pärast seda võin juba dreamweaveriga edasi teha, ilma, et ? tekiks.
9 |
