Chaza!
13.12.2010 14:46:07
Gparted ja GPT |
Mul on siis ketta peal 2 parti ja üritan 3-ndat juurde teha. Ketas oli täiesti tühi ja formattisin osxi all. 1 part on fat32 ja sisaldab EFI bootloaderit. Teine siis hfs+ peal osx. Kloonisin selle tegelikult enda väiksemalt kettalt (80) sellele 320-sele. Kuid nüüd ei õnnestu juurde teha seda parti. Ei tahaks nagu sellest osxi installist loobuda. :/
GParted 0.5.1
Libparted 2.2
Delete /dev/sdb3 (ext4, 124.84 MiB) from /dev/sdb 00:00:00 ( SUCCESS )
calibrate /dev/sdb3 00:00:00 ( SUCCESS )
path: /dev/sdb3
start: 146544930
end: 146800606
size: 255677 (124.84 MiB)
delete partition 00:00:00 ( SUCCESS )
libparted messages ( INFO )
Not all of the space available to /dev/sdb appears to be used, you can fix the GPT to use all of the space (an extra 478341808 blocks) or continue with the current setting?
Create Primary Partition #1 (ext4, 228.21 GiB) on /dev/sdb 00:00:01 ( SUCCESS )
create empty partition 00:00:00 ( SUCCESS )
path: /dev/sdb3
start: 146544930
end: 146800606
set partition type on /dev/sdb3 00:00:01 ( SUCCESS )
new partition type: ext4
create new ext4 file system 00:00:00 ( SUCCESS )
mkfs.ext4 -j -O extent -L "DATA" /dev/sdb3
Filesystem label=DATA
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
Stride=0 blocks, Stripe width=0 blocks
32000 inodes, 127836 blocks
6391 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67371008
16 block groups
8192 blocks per group, 8192 fragments per group
2000 inodes per group
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 38 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
mke2fs 1.41.11 (14-Mar-2010)
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 59 loe/lisa |
53 |
Adebisi
| Kommentaarid: 58 loe/lisa |
55 |
Chaza!
13.12.2010 21:32:49
The magic trick was to just type "#parted /dev/sdb" I'd always been running it like "#parted /dev/sdb1"
When I ran it against "/dev/sdb" and did a print command it gave me the "do you want to fix the GPT?" - I had to tell it twice to fix the GPT and that was that. |
Minul ta ei tee midagi selle peale :S
53 |
kaabakas
14.12.2010 01:12:55
et trellid võtsid eest ära ikka/
96 |
Chaza!
14.12.2010 16:56:12
ikka ikka, parted läheb käima aga midagi fiximise kohta ta ei räägi. Pean vist partitsioonidest backupid tegema ja siis mingeid loomkatseid tegema.
53 |
Adebisi
15.12.2010 01:23:52
| peale partedi käevitamist print käsu andsid?
55 |
Chaza!
15.12.2010 13:08:08
(parted) print
Model: ATA ST9320421AS (scsi)
Disk /dev/sdb: 320GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 20.5kB 210MB 210MB fat32 EFI System Partition boot
2 210MB 75.0GB 74.8GB hfs+ Untitled
(parted) |
53 |
Adebisi
15.12.2010 13:54:07
OSX'i enda all ei ole proovinud uut parti luua?
või proovi parted'i all
mkpart primary 75GB 320GB
quit
idee poolest peaks siis ilusasti uue part'i juurde tegema. et siis peale selle käsu sisse löömist ja rebu peaksid saama uue parti ext4'ks formattida.
55 |
Chaza!
15.12.2010 14:31:38
(parted) print
3 75.0GB 320GB 245GB ext4 primary
(parted) |
suured tänud, toimis, formattisin parti ext4-ks ja töötab.
53 |
Adebisi
55 |
