praegune kellaaeg 15.11.2026 17:54:59
pesanet
09.12.2010 16:13:45
TG784 WAN pordi tegemine |
Ehk on abiks. Töötas TG784'ga.
Enable WAN Ethernet port on st780:
Firmware version 5.4 and lower:
Enter the following commands, pressing Enter after each line:
:ppp relay flush
:ppp flush
:eth flush
:atm flush
:atm phonebook flush
:eth bridge ifdelete intf=ethport4
:eth ifadd intf=ethport4
:eth ifconfig intf=ethport4 dest=ethif4 retry=10 group=default
:eth ifattach intf=ethport4
:ip ifadd intf=WAN_Port dest=ethport4
:dhcp client ifadd intf=WAN_Port
:dhcp client ifattach intf=WAN_Port
:nat ifconfig intf=WAN_Port translation=enabled
:ip ifattach intf=WAN_Port
:saveall
Firmware version 6.1 and higher:
:ppp relay flush
:ppp flush
:eth flush
:atm flush
:eth ifadd intf=eth_wan
:eth ifconfig intf=eth_wan dest=ethif4
:eth ifattach intf=eth_wan
:ip ifadd intf=ip_wan_eth dest=eth_wan
:ip ifconfig intf=ip_wan_eth status=up
:ip ifattach intf=ip_wan_eth
:nat ifconfig intf=ip_wan_eth translation=enabled
:dhcp client ifadd intf=ip_wan_eth
:dhcp client ifconfig intf=ip_wan_eth metric=5 dnsmetric=5
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-lease-time
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-renewal-time
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-rebinding-time
:dhcp client rqoptions add intf=ip_wan_eth option=subnet-mask
:dhcp client rqoptions add intf=ip_wan_eth option=classless-static-routes
:dhcp client rqoptions add intf=ip_wan_eth option=default-routers
:dhcp client rqoptions add intf=ip_wan_eth option=classfull-static-routes
:dhcp client rqoptions add intf=ip_wan_eth option=domain-name-servers
:dhcp client ifattach intf=ip_wan_eth
:saveall
Once you are done entering the commands, you can close the command prompt.
The 4th Ethernet/LAN port will now be configured to recognize a WAN/Internet signal from your Cable modem behind it.
http://forums.modem-help.co.uk/viewtopic.php?p=12601
| Kommentaarid: 11 loe/lisa |
