praegune kellaaeg 14.11.2026 00:16:44
MoonAngel
08.12.2010 14:04:45
LDAP Connection ei tööta |
See pole koolitöö ja ma tahtsin teada miks mu programm ei tööta, olen kõike vaadanud ja ikka ei tööta. Kood on mul lihtsalt enda arendamise jaoks tehtud.
<?php
function a($v,$t = false)
echo '<pre>';
print_r($v);
echo '</pre>';
if($t) die;
$D['host'] = '172.16.1.7';
$D['port'] = NULL; //NULL 636
$D['basedn'] = 'DC=emu,DC=ee';
$D['username'] = 'helen';
//$D['password'] = '';
$ds=ldap_connect($D['host'], $D['port']);
$dn="UID=".$D['username'].",OU=people,".$D['basedn'];
a($dn);
if ($bind=@ldap_bind($ds, $dn, 'passwd'))
a("Login correct");
else
a("Unable to bind to server.</br>");
a("msg:'".ldap_error($ds)."'</br>");#check if the message isn't: Can't contact LDAP server
#if it say something about a cn or user then you are trying with the wrong $dn pattern i found this by looking at OpenLDAP source code
#we can figure out the right pattern by searching the user tree
#remember to turn on the anonymous search on the ldap server
if ($bind=ldap_bind($ds))
$D['filter'] = "CN=*";
a($D);
if (!($search=@ldap_search($ds, $D['basedn'], $D['filter'])))
//a('1');
a("Unable to search ldap server");
a("msg:'".ldap_error($ds)."'</br>");#check the message again
else
//a('2');
$number_returned = ldap_count_entries($ds,$search);
$info = ldap_get_entries($ds, $search);
a("The number of entries returned is ". $number_returned."<p>");
for ($i=0; $i<$info["count"]; $i++)
a($info[$i]);
#look for your user account in this pile of junk and apply the whole pattern where you build $dn to match exactly the ldap tree entry
else
a("Unable to bind anonymously<br>");
a("msg:".ldap_error($ds)."<br>");
mark11
08.12.2010 18:41:16
1) pane kood tagide vahele
2) mis asi täpsemalt ei tööta?
3) oeh
