praegune kellaaeg 06.10.2026 01:53:02
Reimo80
11.11.2010 23:25:49
McAfee uninstall |
Tahaks peale lasta kaspersky internet security't, aga siis ütleb, et mul on mcafee peal ja viskab add/remove programsi. Seal ei ole mcafeed, arvuti searchist ei leia ka ühtegi sellise nimega faili. Korralikult uninstallisin maha aga ei lase kaspersktyd peale panna. f-secure sain peale küll, aga see takistab jälle trackmania mängimist(vahel on ikka igav). Niiet ootan siis kahte lahendust :
1) suudate aidata mcafee kaotamisel ja kaspersky peale panemisel
2) või ütlete, miks ei tööta f-sexure ja trackmanania korraga.
Tänks
A.S.
| Kommentaarid: 34 loe/lisa |
34 |
knoppix
12.11.2010 11:45:38
Googeldades leidsin sellise jutu.
for some reason this appears on the F-Secure application control: "TMFORE~1.EXE". It's there in addition to the "TmForever.exe" and the Nadeo Launcher.
I set the "TMFORE~1.EXE" to "Prompt" for both connections. Then I start the game but do not start it in fullscreen. Then F-Secure asks about the connection; at this point *do not* click for F-Secure to remember the selection, just select "Allow". This happens a couple times and soon enough I'm in the game.
Just don't set it to remember the "Allow" preference. If you have a high end PC you can work around the maximum resolution for windowed mode just by setting AA to 8x.
| Kommentaarid: 12 loe/lisa |
10 |
Lord Ami
| Kommentaarid: 57 loe/lisa |
52 |
