praegune kellaaeg 25.09.2026 16:08:00
Waldof
06.11.2010 16:09:56
Ülekuumemine |
Teema siis selline, et läpakas kuumeneb suht tihti üle.
Viskab lihtsalt pildi kotti kui mänging. Suht iga mänguga selline jama, et high graafikat ei saa panna kuna hakkab kohe jõnksutama ja lagima. Ning low graafikaga mäng toimib ja siis pilt taskus varsti. Temperatuurid ronivad lihtsalt lakke. Idles kuskil 60-70c.
Tegu on siis compal jhl90.
Milles võib siis viga olla????
Tegin väikse ülevaate ka specidest ja asjadest
Summary
Operating System
MS Windows 7 Ultimate 64-bit
CPU
Intel Mobile Core 2 Duo T6500 @ 2.10GHz 60 °C
Penryn 45nm Technology
RAM
4.0GB Dual-Channel DDR2 @ 399MHz (5-5-5-18)
Motherboard
COMPAL JHL90 (U2E1)
Graphics
Generic PnP Monitor @ 1280x800
512MB GeForce 9600M GT (COMPAL Electronics) 67 °C
Hard Drives
313GB SAMSUNG SAMSUNG HM320JI ATA Device (Unknown) 40 °C
Optical Drives
Optiarc DVD RW AD-7590S ATA Device
FUV FS9E3K92JK SCSI CdRom Device
Audio
High Definition Audio Device
Operating System
Installation Date: 18 March 2010, 17:28
CPU
Cores 2
Threads 2
Name Intel Mobile Core 2 Duo T6500
Code Name Penryn
Package Socket P (478)
Technology 45nm
Specification Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz
Family 6
Extended Family 6
Model 7
Extended Model 17
Stepping A
Revision R0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Bus Speed 199.5 MHz
Rated Bus Speed 798.0 MHz
Stock Core Speed 2100 MHz
Stock Bus Speed 200 MHz
Average Temperature 60 °C
Caches
L1 Data Cache Size 2 x 32 KBytes
L1 Instructions Cache Size 2 x 32 KBytes
L2 Unified Cache Size 2048 KBytes
Core 0
Core Speed 1197.0 MHz
Multiplier x 6.0
Bus Speed 199.5 MHz
Temperature 59 °C
Thread 1
APIC ID 0
Core 1
Core Speed 2094.8 MHz
Multiplier x 10.5
Bus Speed 199.5 MHz
Temperature 61 °C
Thread 1
APIC ID 1
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR2
Size 4096 MBytes
Channels # Dual
DRAM Frequency 399.0 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 18 clocks
SPD
Number Of SPD Modules 2
Slot #1
Type DDR2
Size 2048 MBytes
Manufacturer Apacer Technology
Max Bandwidth PC2-6400 (400 MHz)
Part Number 78.A2G75.9L5
Serial Number 02309215
Week/year 21 / 09
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 18
tRC 23
Voltage 1.800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3.0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1.800 V
Slot #2
Type DDR2
Size 2048 MBytes
Week/year 21 / 09
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 18
tRC 23
Voltage 1.800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3.0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1.800 V
Motherboard
Manufacturer COMPAL
Model JHL90
Chipset Vendor Intel
Chipset Model PM45
Chipset Revision 07
Southbridge Vendor Intel
Southbridge Model 82801IM (ICH9-M)
Southbridge Revision 03
BIOS
Brand COMPAL
Version 1.10
Date 10/22/2008
Graphics
Monitor
Name Generic PnP Monitor on NVIDIA GeForce 9600M GT
Current Resolution 1280x800 pixels
Work Resolution 1280x760 pixels
State enabled, primary
Monitor Width 1280
Monitor Height 800
Monitor BPP 32 bits per pixel
Monitor Frequency 59 Hz
Device \\.\DISPLAY1\Monitor0
GeForce 9600M GT
GPU G96M
Device ID 10DE-0649
Revision A2
Subvendor COMPAL Electronics (14C0)
Technology 65 nm
Die Size 144 nm?
Transistors 314 M
Release Date Jun 04, 2008
DirectX Support 10.0
DirectX Shader Model 4.0
OpenGL Support 3.0
Bus Interface PCI Express x16
Temperature 67 °C
ForceWare version 260.99
BIOS Version 62.94.3e.00.05
ROPs 8
Shaders 32 unified
Physical Memory 512 MB
Virtual Memory 2304 MB
Bus Width 128 Bit
Hard Drives
Manufacturer SAMSUNG
Business Unit/Brand Mobile
Model Capacity For This Specific Drive 320GB
Serial Number S16LJ90S631372
Interface Unknown
Capacity 313GB
Real size 320 072 933 376 bytes
S.M.A.R.T
01 Read Error Rate 100 (100 worst) Data 0000000003
03 Spin-Up Time 252 (252) Data 0000000AFC
04 Start/Stop Count 098 (098) Data 0000000939
05 Reallocated Sectors Count 098 (098) Data 0000000019
07 Seek Error Rate 252 (252) Data 0000000000
08 Seek Time Performance 252 (252) Data 0000000000
09 Power-On Hours (POH) 087 (087) Data 0000001B9B
0A Spin Retry Count 252 (252) Data 0000000000
0C Device Power Cycle Count 099 (099) Data 0000000470
BF G-sense error rate 100 (100) Data 0000000F1D
C0 Power-off Retract Count 100 (100) Data 0000000022
C2 Temperature 118 (097) Data 0000070028
C3 Hardware ECC Recovered 100 (100) Data 000000003A
C4 Reallocation Event Count 252 (252) Data 0000000000
C5 Current Pending Sector Count 252 (252) Data 0000000000
C6 Uncorrectable Sector Count 252 (252) Data 0000000000
C7 UltraDMA CRC Error Count 200 (200) Data 0000000000
C8 Write Error Rate / Multi-Zone Error Rate 100 (100) Data 000000000C
C9 Soft Read Error Rate 252 (252) Data 0000000000
DF Load/Unload Retry Count 098 (098) Data 00000008A8
E1 Load/Unload Cycle Count 035 (035) Data 00000A16D2
Temperature 40 °C
Temperature Range ok (less than 50 °C)
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Size 100 MB
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number DC883D71
Size 49GB
Used Space 38.8GB (80%)
Free Space 9.91GB (20%)
Partition 2
Partition ID Disk #0, Partition #2
Disk Letter D:
File System NTFS
Volume Serial Number 8A4C4A63
Size 249GB
Used Space 168GB (68%)
Free Space 81GB (32%)
Optical Drives
Media Type DVD Writer
Name Optiarc DVD RW AD-7590S ATA Device
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive E:
Media Loaded FALSE
SCSI Bus 1
SCSI Logical Unit 0
SCSI Port 1
SCSI Target Id 0
Status OK
Media Type DVD-ROM
Name FUV FS9E3K92JK SCSI CdRom Device
Capabilities Random Access, Supports Removable Media
Drive F:
Media Loaded TRUE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 8
SCSI Target Id 0
Size 3,46 GB
Status OK
Volume Name Cities XL 2011
Volume Serial Number 3663CBEA
Audio
Sound Cards
NVIDIA High Definition Audio
Playback Device
Speakers (High Definition Audio Device)
Recording Devices
Microphone (High Definition Audio Device) (default)
Peripherals
Standard PS/2 Keyboard
Device Kind Keyboard
Device Name Standard PS/2 Keyboard
Location plugged into keyboard port
Driver
Date 6-21-2006
Version 6.1.7600.16385
File C:\Windows\system32\DRIVERS\i8042prt.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
PS/2 Compatible Mouse
Device Kind Mouse
Device Name PS/2 Compatible Mouse
Location plugged into PS/2 mouse port
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouclass.sys
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor Unknown
Location USB Input Device
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouhid.sys
USB Video Device
Device Kind Camera/scanner
Device Name USB Video Device
Vendor Unknown
Comment USB 2.0 Camera
Location 0000.001d.0007.003.000.000.000.000.000
Driver
Date 6-21-2006
Version 6.1.7600.16543
File C:\Windows\system32\drivers\usbvideo.sys
Network
You are connected to the internet
Connected through Intel(R) WiFi Link 5100 AGN
DHCP Enabled
DHCP server
External IP Address
Adapter Type IEEE 802.11 wireless
NetBIOS over TCP/IP Enabled via DHCP
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Using native Wi-Fi API version 2
Available access points count 1
Wi-Fi4
Channel Number 13
Name No name
Signal Strength/Quality 99
Security Enabled
State The interface is connected to a network
Dot11 Type Infrastructure BSS network
Network Connectible
Network Flags Currently Connected to this network
Cipher Algorithm to be used when joining this network Temporal Key Integrity Protocol (TKIP) algorithm
Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
viimati muutis Waldof 06.11.2010 16:22:09, muudetud 1 kord |
ViskeRelv
06.11.2010 16:13:31
Ise küsid, ise vastad.
Puhastamist vajab ja soovitatavlt termopasta vahetust.
Waldof
06.11.2010 16:30:41
Puhastatud, aga ikka sama asi.
Ma kahtlustan ka termopastat, aga ei ole kindel.
Mõtlen, et peaks garantiise viima, aga olen kuulnud, et ordis pikad järiekorrad.
Ning arvutist ilma ei tahaks (ei saaks) olla ka kuskil 3 nädalat!
kuunar
06.11.2010 20:16:25
| mis variandid sul veel siis on?
Maa Mees
07.11.2010 20:57:19
Vaheta termo ära
_________________ Kõike saab korda teha. |
kuunar
07.11.2010 21:04:41
| kui ta selle lahti võtab, kas mitte garantii ei katke?
.:MDK:.
08.11.2010 11:13:36
| Waldof kirjutas: |
Ning arvutist ilma ei tahaks (ei saaks) olla ka kuskil 3 nädalat! |
Kui sa oled Tallinna inimene, siis on Pärnu mnt teeninduses läpakate järjekord hetkel sisuliselt olematu.
