ranel
22.09.2010 08:52:32
tasuta antiviirus ettevõttes kasutamiseks |
Keegi teab mõnde?
165 |
aldios
| Kommentaarid: 21 loe/lisa |
17 |
NightStriker
22.09.2010 15:01:10
Kas Microsoft security essentals ei ole ettevõttele tasuta?
_________________ Allverelaev sukeldub määramata ajaks... |
| Kommentaarid: 65 loe/lisa |
63 |
22.09.2010 15:17:21
| radist87 kirjutas: |
| Kas Microsoft security essentals ei ole ettevõttele tasuta? |
Sõltub ettevõttest. Kodukontorile tasuta, suuremad kalad ei tohi aga kasutada.
MSE EULA:
1. INSTALLATION AND USE RIGHTS.
a. Use. You may install and use any number of copies of the software on your devices in your household for use by people who reside there or for use in your home-based small business. |
Ahjaa, Microsoftilt võib 5 doltsi kahjutasu nõuda, kui MSE midagi pekki keerama peaks (teatud tingimustel muidugi)
14. Limitation on and Exclusion of Remedies and Damages. You can recover from Microsoft and its suppliers only direct damages up to U.S. $5.00. You cannot recover any other damages, including consequential, lost profits, special, indirect or incidental damages.
This limitation applies to
· anything related to the software, services, content (including code) on third party Internet sites, or third party programs; and
· claims for breach of contract, breach of warranty, guarantee or condition, strict liability, negligence, or other tort to the extent permitted by applicable law.
It also applies even if Microsoft knew or should have known about the possibility of the damages. The above limitation or exclusion may not apply to you because your country may not allow the exclusion or limitation of incidental, consequential or other damages. |
_________________ M: HP Elitedesk 800 G3 SFF
M: HP Elitedesk Mini 800 G2 35W |
| Kommentaarid: 765 loe/lisa |
571 |
aldios
22.09.2010 15:21:55
Microsoft Eesti vastas nii ,et kodukasutajale kes on näiteks fie võib kasutada . Kuid ettevõtte ei tohi kasutada, EULA keelavat seda .
Ettevõttele peaks olema siis microsoftil tasuline kaitse mis prooviversioonina toimib 120 päeva http://technet.microsoft.com/en-gb/evalcenter/bb738009.aspx
17 |
NightStriker
22.09.2010 18:45:19
| Pornomax kirjutas: |
Selle alla peaks ilusti mahtuma oma majas baseeruv väike pereettevõte mahuga 1-2 arvutit (tegevusvorm OÜ). Minu teada ei ole määratletud, kas small business on FIE või OÜ. Tean nii mõndagi FIE-t, kes paneb käibelt pika puuga keskmisele Eest OÜ-le.
63 |
aldios
17 |
NightStriker
22.09.2010 20:31:32
| Both the US and the EU generally use the same threshold of fewer than 10 employees for small offices (SOHO). |
Samas defineerib EU :
| Its current definition categorizes companies with fewer than 10 employees as "micro", those with fewer than 50 employees as "small", and those with fewer than 250 as "medium" |
MSE EULA: "for use in your home-based small business". Seega: kui sul on alla 50 töötaja, ja ettevõte on registreeritud sinu koju, siis peaks tohtima kasutada küll.
Vähemalt ise kavatsen küll sellise loogikakäigu letti lüüa, kui kellelgi kobisemist peaks olema.
Allikas: http://en.wikipedia.org/wiki/Small_and_medium_enterprises
Muidugi, kui antud kategooria alla ei mahu (suhteliselt vähe firmasid on registreeritud omaniku koju), siis tuleb midagi muud tasuta või tasulist vaadata.
63 |
571 |
NightStriker
22.09.2010 20:52:19
Arvestades seda, et töötajaid on kõvasti alla 10 (ehk siis "micro"), ettevõte asub minu registreeritud elukohaga samas majas, siis ei näe ma probleemi, miks ma ei peaks selle EULA punkti alla mahtuma. Kuna hetkel on kasutusel firma arvutites XP, siis ei ole siiamaani ka MSE-d seal kasutusele võtnud. Tulevikus läheb kindlasti peale.
Microsoft võib meilis ühte kirjutada, aga EU pügalad võivad teisti mõelda
63 |
HacaX
23.09.2010 17:57:14
Kui raha eriti vähe ja/või asjalikud kasutajad siis ClamAV suguvõsa on täies mahus vabaks kasutamiseks. Kas ClamAV for Windows (pilvel põhinev variant), MoonSecure AV (on-access poolt sisaldav variant mis kasutab ClamAV mootorit) või siis ClamWin (ei paku on-access lähenemist, küll aga scheduled skänne). Clamiga on küll see teema et ta on Clam (s.t. efektiivsuse osas küsitava väärtusega, ei puhasta ja valeidentifikatsioone on parajal hulgal), aga samas siiski parem kui mittemidagi.
| Kommentaarid: 24 loe/lisa |
22 |
BTK0
| Kommentaarid: 20 loe/lisa |
19 |
Märt.
| Kommentaarid: 29 loe/lisa |
23 |
