janeklass
A.S.
| Kommentaarid: 34 loe/lisa |
34 |
janeklass
A.S.
23.09.2010 19:30:59
Tee kaust C:\Windows\Symbols
WINDBG.EXE käima.
File > Symbol File Path... > SRV*C:\Windows\Symbols*http://msdl.microsoft.com/download/symbols > OK
File > Open Crash Dump... > C:\Windows\Minidump\092310-21060-01.dmp > Open
Teeb oma töö ära ja siis uurid lähemalt.
Edasi annad alumisel käsureal käsu !analyze -v (peaks tekkima lausa lingi kujul).
Jälle ootad ja pärast uurid.
Midagi teha tahad ja ei oska, siis vajutad F1 ja muudkui loed. Täpsemalt juhendada ei oska.
34 |
janeklass
23.09.2010 19:51:49
Põhimõtteliselt info sain kätte aga ega ma sellest suur targemaks ikka nei saanud,ma ei oska sealt suurt midagi välja lugeda.
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Copyright (c) Microsoft Corporation. All rights reserved.
DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS (ce)
A driver unloaded without cancelling timers, DPCs, worker threads, etc.
The broken driver's name is displayed on the screen.
Arguments:
Arg1: 9e6b0104, memory referenced
Arg2: 00000008, value 0 = read operation, 1 = write operation
Arg3: 9e6b0104, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, Mm internal code.
Debugging Details:
Unable to load image \SystemRoot\System32\DRIVERS\cmdguard.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for cmdguard.sys
*** ERROR: Module load completed but symbols could not be loaded for cmdguard.sys
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 831aa718
Unable to read MiSystemVaType memory at 8318a160
9e6b0104
FAULTING_IP:
dump_wmimmc+5104
9e6b0104 ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xCE
PROCESS_NAME: nvvsvc.exe
CURRENT_IRQL: 0
TRAP_FRAME: 9d403c64 -- (.trap 0xffffffff9d403c64)
ErrCode = 00000010
eax=87e5e8e8 ebx=00000000 ecx=87e5e8a8 edx=00000000 esi=00000001 edi=8624d008
eip=9e6b0104 esp=9d403cd8 ebp=9d403d20 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
<Unloaded_dump_wmimmc.>+0x5104:
9e6b0104 ?? ???
Resetting default scope
IP_MODULE_UNLOADED:
dump_wmimmc+5104
9e6b0104 ?? ???
LAST_CONTROL_TRANSFER: from 83088638 to 830c7903
STACK_TEXT:
9d403c4c 83088638 00000008 9e6b0104 00000000 nt!MmAccessFault+0x106
9d403c4c 9e6b0104 00000008 9e6b0104 00000000 nt!KiTrap0E+0xdc
WARNING: Frame IP not in any known module. Following frames may be wrong.
9d403cd4 8bd6221e 00000001 0158fb58 0000001c <Unloaded_dump_wmimmc.>+0x5104
9d403d20 8308544a 00000001 0158fb58 0000001c cmdguard+0x1021e
9d403d20 774064f4 00000001 0158fb58 0000001c nt!KiFastCallEntry+0x12a
0158fb74 00000000 00000000 00000000 00000000 0x774064f4
STACK_COMMAND: kb
FOLLOWUP_IP:
dump_wmimmc+5104
9e6b0104 ?? ???
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: dump_wmimmc+5104
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dump_wmimmc
IMAGE_NAME: dump_wmimmc.
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: 0xCE_dump_wmimmc+5104
Followup: MachineOwner
A.S.
23.09.2010 20:16:31
Tulemüüri draiver (cmdguard.sys) on asjasse segatud, aga millega seoses see probleem tekib, seda ilmselt niisama lihtsalt välja ei uuri. Võid ju guugeldada 'cmdguard.sys blue screen' vms, aga kas ka midagi kasulikku leiad?
Kõige lihtsam oleks tulemüüri vahetada.
Võid ju ka mälu testida http://www.memtest.org/ , aga vaevalt selle viga on. Kindlalt küll ei tea.
34 |
janeklass
23.09.2010 20:29:23
Ma ise ka ei taha uskuda et mälu viga kast on alles mõned kuud vana.Tulemüür viskab veateate kui mäng käivitatakse,ma hoian kasti tavaliselt sleep-i peal ja blue screen on tekinud tavaliselt sell hetkel kui arvuti sleepist välja kutsun.Ilmub blue screen teeb korra restarti ja siis on korras jälle töötab edasi ilusti. Ma tirin selle tulemüüri maha ja jälgin mõnda aega kui midagi ei juhtu enam siis asi korras.
Aga sulle suured tänud abi eest
A.S.
23.09.2010 20:32:03
| Aga see GameGuard võimistaongi, seda eemaldada ei saa? Mängu osa?
34 |
janeklass
23.09.2010 20:41:29
| Kui ma selle eemaldaksin siis tõenäoliselt mäng ei tööta enam,aga kui see tulemüüri eemaldamine nüd ei aita siis ma tirin selle mängu ka arvatavast maha.
A.S.
23.09.2010 21:19:44
Ja see GameGuard peab tingimata netti minema? Kui sa selle C:\Windows\system32(või syswow64)\drivers\etc\hosts faili kaudu enda arvutisse suunad, ehk siis 127.0.0.1 peale, siis poleks sellel nagu tulemüüriga enam mingit pistmist.
Mõte lihtsalt selline, pole ise mängumees.
34 |
janeklass
24.09.2010 15:10:14
| Ma arvan kül et ta peab netti minema,tegemist võrgumänguga ju. Ma ise pole ka mängu mees vend mängib mul. Ma vast ei ei hakka seda suunamist aretama,tõenäoliselt ei saaks ma iseseisvalt hakkama sellega ja ma juba eemaldasin tulemüüri,hetkel pole midagi kahtlast juhtunud,paistab et asi korras.
