sõnum  |
KrisVr
22.09.2010 13:29
Darksiders |
• Arendaja: Vigil Games
• Väljaandja: THQ
• Stiil: Hack and slash, action-adventure
• Väljalaske kuupäev: 24 September 2010(EU)
| Darksiders is a single-player action adventure in which the player takes control of the protagonist, War. In third-person perspective, the player engages in combat, puzzles and exploration.[5] The world is divided into separate locations with many areas at first initially inaccessible until War regains many of his lost weapons and abilities. The center of the world, The Scalding Gallow, acts as a hub where War is given new objectives and paths to further unlock new areas. Each contains a series of linear and non-linear paths, many of which require large sections of platforming, climbing and swimming along environment-based puzzles that impair progress that require the use of newly-gained abilities. He fights mainly against Angels and demons, and has a unique way to kill each particular type of enemy, usually tearing them apart painfully. |
Trailer
| Kommentaarid: 29 loe/lisa |
26 |
Timberg
ööKARU
22.09.2010 13:52
| AAsta alguses tuli sama mäng konsoolidele välja, pole midagi väga uhket. Ehk siis god of war, devil may cry fännidele midagi.
246 |
Araablane
22.09.2010 20:43
Xbox peal sai natuke mängitud, mõnus niukene ajuvaba kill everything mäng
| Kommentaarid: 30 loe/lisa |
28 |
Redikate
22.09.2010 23:58
PC oma on kivine port või on selle aastaga ikka tehtud midagi?
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
lopes39
23.09.2010 16:35
kahtlane mäng on see ikka
kaamera on kuskil põlve kõrgusel ja on suunatud tegelase molli poole ja ei leia mingit valemit kuidas kaamara vaadet muuta et näeks vaenlast ka jne
klaver ei funka ja pult funkab normaalselt kuid ikkagi vaadet muuta ei saa
| Kommentaarid: 10 loe/lisa |
Metsjeesus
25.09.2010 21:10
Päris pull mäng. Graafika ilus ja kõik toimib nigu peab
Mingit kaameraprobleemi mul pole, kuigi pole uurinud palju mänguruumi seal on.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
lopes39
25.09.2010 22:08
| Metsjeesus kirjutas: |
Mingit kaameraprobleemi mul pole, kuigi pole uurinud palju mänguruumi seal on. |
kaamera probleem oli mul puldiga ja kui selle tagant ära võtsin siis oli kõik korras
mäng on lihtsalt ulme klõbistamine mida oleks puldiga hea taguda
sirius4k
26.09.2010 16:42
Ma kinni ühes kohas, kus peab valge mõõga ära tooma, et kolmandale kujule kuskil eelpool seada see
Seal esmalt 1 jääelukas ja mingi 5-6 tavalist tegelast
Peale neid on üks mürgikoll ja kaks tavalist tegelast
Need saab tapetud, aga kahte viimast jääkolli ei tapa mingi valemiga ära.
On mingeid nippe/trikke, milledega peaks arvestama, et neist kuidagi jagu saada Praeguse seisuga ei saa ma isegi ühest jagu, kuna need väga tugevad ja kiired ning taovad mõlemalt poolt koguaeg. Mitte kuidagi ei vea välja.
_________________ Hey ! Guess what ?! I got a fever ! And the only prescription... is more cowbell ! |
| Kommentaarid: 51 loe/lisa |
50 |
lopes39
26.09.2010 17:53
| sirius4k kirjutas: |
On mingeid nippe/trikke, milledega peaks arvestama, et neist kuidagi jagu saada Praeguse seisuga ei saa ma isegi ühest jagu, kuna need väga tugevad ja kiired ning taovad mõlemalt poolt koguaeg. Mitte kuidagi ei vea välja. |
mul läks seal kohapeal trainer peale sest asi muutus absurdseks
sirius4k
27.09.2010 17:50
Sain sellest kohast edasi igatahes elu eest rabeledes krt Õlad peale seda jumalast läbi
Ja nüüd kordades hullem koht.. Tiamat siis. Täiesti ajuvaba mäng. Ma valisin Normal raskusastme ja on pigem Very Hard.
50 |
capricorn
27.09.2010 19:06
| Kes ütleks kuidas autot loopida saab? võtan E-ga kätte, siis Q-ga sihin ja mida siis vajutama peab?
| Kommentaarid: 24 loe/lisa |
23 |
wolz
27.09.2010 19:13
| capricorn kirjutas: |
| Kes ütleks kuidas autot loopida saab? võtan E-ga kätte, siis Q-ga sihin ja mida siis vajutama peab? |
Default on hiire rullik ehk keskmine nupp, seadete alt saab seda muuta ka kui vaja.
_________________ If I throw a stick, will you leave? |
| Kommentaarid: 14 loe/lisa |
14 |
Tonsor
28.09.2010 00:05
| Ülikõva mäng, väga meeldib, hulle combosid saab lahmitud. Mängin controlleriga, ei saa vinguda, ainult relvadega laskmine on niru. Hetkel tapsin mingi suure "ussi" ära ka olen teel kolmanda Choseni poole.
30 |
MatchMaker
28.09.2010 02:03
| Peab 100% ja peale veel nõustuma, et ülikõva mänguga tegemist Selliseid konsoolikaid võidaks rohkemgi pc peale veel teha.
sirius4k
28.09.2010 06:59
Mina mänging klaveri ja hiirega ja ei ole nii kõva midagi Ilmselt ongi puldiga mängimiseks mõeldud
50 |
aivo80
28.09.2010 11:35
| MatchMaker kirjutas: |
| Peab 100% ja peale veel nõustuma, et ülikõva mänguga tegemist Selliseid konsoolikaid võidaks rohkemgi pc peale veel teha. |
Kui sul on mõni sõber, kes omab PS3. siis soovitan soojalt ära proovida God of War'i triloogia. Kõvasti vingem, kui Darksiders. (2 esimest osa on natuke kehvema pildiga, kuna olid algselt PS2. mängud.)
| Kommentaarid: 31 loe/lisa |
29 |
KrisVr
30.09.2010 14:31
Ei uskunud, et nii hea mäng on, ülihea lihtsalt! Alguses meenutas natuke Prototype.
26 |
Tonsor
30.09.2010 15:12
| DefXtreme kirjutas: |
Ei uskunud, et nii hea mäng on, ülihea lihtsalt! Alguses meenutas natuke Prototype. |
Natuke?
imo seal oli liiga palju prototype'i ja prince of persiat, aga meeldis endiselt.
30 |
Anar.
30.09.2010 18:25
Väga mõnus mäng tõesti. Mõnes kohas saab isegi natuke ajusid ragistatu. Klaveri ja hiirega täitsa mugav minu arust.
| Kommentaarid: 4 loe/lisa |
Saiapäts
30.09.2010 19:28
Normali peal, sain sealt "põrgust" välja ning tuleb mingi esimene vant kes mind tulega peksab, ei saa temast jagu, peksa palju tahad. Mis tegema peab?
| Kommentaarid: 23 loe/lisa |
23 |
KrisVr
30.09.2010 19:32
| Saiapäts Üks paks värdjas w?
26 |
Saiapäts
30.09.2010 19:46
| Jah, on mingi paks ja sinakas.
23 |
KrisVr
30.09.2010 19:50
Mina peksin nii kaua kui tuli see märk, instant kill vms. Igastahes hüppa hästi palju, eriti kui ta see paks pihv lüüa üritab.
26 |
Tonsor
30.09.2010 21:50
| Saiapäts kirjutas: |
Normali peal, sain sealt "põrgust" välja ning tuleb mingi esimene vant kes mind tulega peksab, ei saa temast jagu, peksa palju tahad. Mis tegema peab?  |
Pmts peksa palju suudad ja kui ta hakkab ründama, pane dash eemale, siis kohe tagasi.
30 |
Metsjeesus
30.09.2010 22:23
Ma siiamaani ainult dashin seal peaaegu. Üliedukas variant tundub.
94 |
