praegune kellaaeg 30.09.2026 16:12:41
ronn
25.08.2010 12:13:18
logitechi pult ja mahl |
| Logitech Harmony 555 pult sai mahlaga kokku, teab keegi kuidas teda lahti võtta. 4 kruvi patareide juures keerasin lahti aga edasi nagu ei julge midagi teha, kergelt painutades ja tirides ka ei juhtu midagi. Äkki lihtsalt lasta ta kraani veega üle ja siis fööniga kuivaks?
| Kommentaarid: 6 loe/lisa |
Spezz
25.08.2010 14:25:16
Käib küll 520 kohta aga äkki on samamoodi:
After taking the four screws out from under the batteries, I figured that the casing would have to be pried apart. On each side there are four spots where you have to insert a *thin* screwdriver and push to separate the cases. The first on is located on either side of the "Glow" button. The next ones are on either side of the <- and -> buttons. The next is on either side of the "Stop" and "Play" buttons. The last is on either side of the "Activities" button. Just insert a flat edge and press as you gently pry the casing apart with your fingers.
67 |
ronn
25.08.2010 15:28:30
| tänud
