marti252
13.08.2010 13:08:14
Sony PRS-600 Digital Book Reader |
Sony PRS-600 Digital Book Reader. Ideaalne kaaslane, kui vaja pidevalt töömaterjale või raamatuid lugeda!
Kuna raamatuid loen palju ja need suht kallid, siis otsustasin ära proovida E-Reader-i.
Tellisin USA ebayst. Maksis 170$, saatmiskulu 32$ ja tollimaks 500 eeki. Kokku seega ca 3000 EEKi. Kohale tuli Fedexiga 4 päevaga. Eestis maksab sama asi kuskil 4500 eeki.
Tehnilised näitajad:
Display Screen
Technology: E Ink® Vizplex™ touchscreen
Screen size (inch): 6
Resolution: 800x600 (h/w)
Grey scale: 8-level grey scale
Storage Capacity
Built in flash memory (MB): 512 (Approx. 350 eBooks) *
MemoryStick™ MS DUO slot: YES
SD Card Slot: YES
Power
Battery Type: Built-in rechargeable lithium-ion battery: DC 3.7 V
Battery Life (reading EPUB eBooks): Approx 7500 page turns
Recharging Time: Four hours with USB, two hours with optional AC charger
Compatible Formats
Unsecured / free eBooks & text files: EPUB eBook, Adobe® PDF, Microsoft® Word, TXT, RTF, BBeB
DRM (Secure / purchased) eBooks and text files: EPUB eBooks (Adept) BBeB eBooks (Marlin)
Unsecured Audio files: MP3, AAC (not most DRM audio)
Image & Photo files: JPEG, GIF, PNG, BMP
General data
Width (mm): 121
Height (mm): 174.3
Depth (mm): 9.8
Weight (g): 286
Audio Output: 3.5 mm stereo mini-jack (for headphones, etc)
Supplied accessories
Soft cover: Pouch
USB Cable: YES
Quick Start guide: YES
eBook Library software: YES
Recommended Minimum System Requirements
Operating System: Microsoft® Windows Vista® (32-bit or 64-bit) or Microsoft® Windows® XP (32-bit only), MAC OS® X 10.4.9 or later
Processor: 800 MHz Intel® Celeron® class processor or better
RAM: 128 MB minimum, or 512 MB minimum for Windows Vista®
Hard Drive: 20 MB Minimum available Hard Drive space
Optical Drive: Capable of reading CD-ROM
USB Port: USB 2.0 high speed
Internet Connection: Broadband
Karp näeb välja selline:
Kaasasolevad asjad. Laadimine käib usb kaabli abil, mis on tegelikult väga kõva eelis, sest siis ostad juurde 12v ja 220v pistiku otsiku ning saab sama usb juhtmega laadida:
Pehme kaitsev ümbris:
Mille ma kavatsen pea vahetada välja lambiga nahast kaante vastu Sony kodulehel on need müügis 49£ ehk umbes 1000EEKi, aga ebayst peaks odavamalt saama:
Suurus võrreldes tikutoosi ja tavalise raamatuga. Kaasasoleva touch screeni pulga saab asetada raamatu ülesse nurka, kus ta seisab magnetiga kinni:
Suurus A4 paberiga:
Peamenüü:
Raamatute menüü:
Raamatu lehekülg:
Lisade menüü:
Pildid:
Samal ajal kui pilte vaadata, saab ka muusikat kuulata:
Kaasaolev lugu:
Kui lugu valitud, võib kohe otsemenüüst raamatulugemist jätkata:
Lugude list:
Niisugune näeb välja, kui tavaline mp3 käima panna:
Saab ka ekraani keerata (orientation):
Landscape vaade:
Kirja suurust on kerge muuta:
XXL kirja suurust peaks ka pime nägema:
S suurus on samas suht pisike:
Siis saab veel alla joonida huvitavaid kohti, mis kanduvad automaatselt notes menüü alla:
Lisaks saab veel higlightida:
Note'd kanduvad eraldi menüüsse,kust saab nad lihtsalt pärast kätte:
Lisaks saab veel memosid kirjutada:
Lisaks sab ka pulgaga kritseldada:
Seadistuste menüü:
Ülevalt vaade, kus on kahe kaardi pesad
Alt vaade:
Tagant vaade:
Kust raamatuid saab?
a) neti saitidel on küllalt raamatuid. Paned otsingusse "Free e books" ja saite tuleb
b) kaasas on programm nimega Library Reader, milles on sisse ehitatud reader store, kust saab iga hinna eest igasugu raamatuid;
c)või ebayst osta 10£ 200,000 raamatut:P 200,000 Ebooks on 4 DVD's The Ultimate Collection
Kokkuvõte:
Kuna mul on vaja peale raamatute lugemise ka töö asju lugeda wordi failidena, siis jääb ära see, et ma pean nad välja printima. Läpakas on lugemiseks liiga kohmakas ja aku ei pea piisavalt kaua vastu. Lisaks ei riku e-reader silminagu arvuti ekraan.
Selle aparaadiga on ka lahendatud mu mp3 mängija probleem.
Mina olen ülimalt rahul sellega
| Kommentaarid: 9 loe/lisa |
9 |
K3ndu
13.08.2010 13:11:05
| Päris kena asjandus ,aga kas ekraan siis nii hele pole ,et lambi ostad kohe?
120 |
lightbluefox
13.08.2010 14:10:21
| K3ndu kirjutas: |
| Päris kena asjandus ,aga kas ekraan siis nii hele pole ,et lambi ostad kohe? |
E-ink on digitaalne paber, st mingit taustavalgustust tal pole. Sestap ei kuluta ka akut muu kui "lehe pööramine" ehk uute tähemärkide kuvamine. Pimedas toas ei saa sealt midagi lugeda.
| Kommentaarid: 45 loe/lisa |
44 |
Ho Ho
13.08.2010 14:25:19
| Battery Life (reading EPUB eBooks): Approx 7500 page turns |
Kas mõnes teises formaadis asjade lugemine kulutab oluliselt rohkem akut ning kas on kaasas ka miski soft convertimaks X formaatidest tollesse EPUB'i formaati?
86 |
Pikkkõrv
13.08.2010 15:41:39
| Epub formaadis raaamatuid saab teha (ja ka konvertida) üsna hõlpsalt näiteks sellise tasuta tarkvaraga nagu Calibre: http://calibre-ebook.com/
kk
13.08.2010 18:52:42
| Ei mõista mina nii väikese ekraani ostjaid... samahästi võib oma ipodi ekraani luubiga piiluda...
7 :: |
94 |
Mercury
13.08.2010 18:53:14
| Kas Book readeritega saab ka netis käia?
| Kommentaarid: 61 loe/lisa |
60 |
lightbluefox
13.08.2010 19:23:26
| kk, kui suur see ekraan siis olla saaks? Tegu on e-readeriga, mitte sülearvutiga, kas sa ostad raamatuid ka A4 formaadis? Ekraan on täisesti sobiv, suurem ei oleks enam käepärane.
44 |
kk
13.08.2010 19:31:12
| A5 kanti oleks ehk mõistlik raamatute lugemiseks... sellel aga mingi 6".. ehk siis u 15cm diagonaal?
7 :: |
94 |
13.08.2010 19:46:27
| kk kirjutas: |
| A5 kanti oleks ehk mõistlik raamatute lugemiseks... sellel aga mingi 6".. ehk siis u 15cm diagonaal? |
A5 ehk siis pool A4'ja.
A5 diagonaal on 257mm, 6 tolli on 152mm.
| Kommentaarid: 85 loe/lisa |
marti252
13.08.2010 20:52:22
| Mercury kirjutas: |
| Kas Book readeritega saab ka netis käia? |
900 versioonil on 3G olemas, millega saab Reader storest raamatuid tõmmata, aga muidu netis nendega surfata ei saa.
| kk kirjutas: |
| Ei mõista mina nii väikese ekraani ostjaid... samahästi võib oma ipodi ekraani luubiga piiluda... |
Nagu ühe pildi pealt on näha, on ta täpselt sama suur kui tavaline juturaamat. Sellises suuruses selle asjanduse võlu ju peitub, et sa saad põhimõtteliselt selle panna jope taskusse. Kui see suurem oleks, siis võiks juba läpaka võtta. Ja pealegi saad ju sellel muuta texti suurust ilma, et sa peaks hakkama lehte scrollima. "Luger" töötleb teksti nii, et lehekülje keeramisel läheks tekst õieti edasi.
9 |
kk
14.08.2010 16:42:01
| See, et ta korpus on peaaegu A5 mõõtu ei tähenda, et ekraan seda oleks. Juturaamatud ei ole kuidagi tavaliselt 15cm lehe diagonaaliga.
7 :: |
94 |
14.08.2010 16:49:50
| kk, raamatus pole tekst ka servast servani.
drag0n
14.08.2010 23:11:37
Kuna ma E-Ink'ist midagi ei tea, siis võrdlemisi asjatundmatu küsimus: kuidas seda päikesevalguse käes lugeda on?
Edit: Sai pisut elektroonilise paberi kohta loetud ja paistab, et päikesevalgus teksti tuhmiks etc. ei tee. Muidugi oleks huvitav kuulda ka ülevaate tegija (või teiste, kes selliste vidinatega kokku puutunud) arvamust/kogemusi.
| Kommentaarid: 23 loe/lisa |
22 |
ruts8
15.08.2010 09:42:46
| drag0n kirjutas: |
Edit: Sai pisut elektroonilise paberi kohta loetud ja paistab, et päikesevalgus teksti tuhmiks etc. ei tee. Muidugi oleks huvitav kuulda ka ülevaate tegija (või teiste, kes selliste vidinatega kokku puutunud) arvamust/kogemusi. |
Päikesevalgus tuhmiks ei tee - loed nagu tavalist paberit. Küll aga võib tekkida (tavaliselt pigem pimedamas ruumis laualambiga lugedes) ekraani pinnalt peegeldusi
Ise oman Sony PRS-505 isendit juba üle aasta ning olen väga rahul. Siiamaani miinuseks oskan tuua vaid seda, et raamatuid kus on sees matemaatilisi valemeid jms ei ole mugav suurendusega lugeda - valemeid näidatakse täiesti valedes kohtades. Samuti ei saa ta suurendamisel tihtipeale korralikult hakkama ka tabelite kuvamisega.
Muidu aga ainult kiidusõnad. Kasutan ise ka Calibre't raamatute haldamiseks ning ka erinevate feed'ide lugemiseks - kuna tavaliselt pole nädala sees eriti aega näiteks google reader'is olevaid postitusi lugeda, siis nädala lõpul tõmban läbi Calibre lugemata postitused otse Sony readerisse.
| Kommentaarid: 47 loe/lisa |
45 |
Mercury
29.08.2010 02:15:20
Kiire küsimus seoses Kindle 3.
Kas olev 3G (Free 3G) Eestis pole kätte saadav?
60 |
29.08.2010 02:50:25
| Tasuta traadita internet (mobiilivõrku pidi) toimib vaid USA pinnal.
eShelobik
30.08.2010 11:35:35
| Aga kui küsida tohib, miks langes valik just selle readeri ostmiseks? Ise plaanin ka osta ja ei suuda otsustada millist, Amazon Kindle ja B&N Nook paistavad üsna ahvatlevad...
| Kommentaarid: 295 loe/lisa |
262 |
lightbluefox
44 |
indrekmartin
02.09.2010 22:14:15
| Oman ka antud isendit ja olen rahul. Võrdlus teistega puudub, aga miks just sony valisin oli märkmete tegemise võimalus. Töö materjale elektrooniliselt meeletult ja nüüd on nende lugemine väga hõlbus. Ise ostsin juurde kohe ka ekraani kaitsekile. Kui enne tuli ikka mitmekiloseid mappe käe otsas tarida jne, siis nüüd paari vajutusega kõik saadaval....pluss meeletu valik ilukirjandust. Lugesin veel kuskilt uudist, et aasta lõpuks peaks Eestis ka eraamatute äri pihta hakkama. Eestikeelsed siis.
| Kommentaarid: 6 loe/lisa |
netcat
03.09.2010 10:55:50
| etc_Shelob kirjutas: |
| Aga kui küsida tohib, miks langes valik just selle readeri ostmiseks? Ise plaanin ka osta ja ei suuda otsustada millist, Amazon Kindle ja B&N Nook paistavad üsna ahvatlevad... |
Nook tundub tore, aga eurooplasele mõttetu, B&N USAst väljaspool sellele contenti ei müü. See alumine värviline ekraaniosa on kah pigem bling-bling väärtuses vooluraiskaja, millel pole suurt mõtet - e-raamatuid endid näed ju ikka mustvalgena põhiekraanil.
Kindle on mõtet kindlasti soetada siis, kui tahad Amazonist raamatuid osta (kes ei tahaks). Mitte et neid ka ilma Kindleta lugeda ei saaks, aga kui kavatsed sealt osta, siis milleks hankida nendega ebakompatiibel reader? Lisaks on Kindle 3 ilma 3G-ta mudel hetkel palju odavam valik. No ja siis see et tal on füüsiline klaviatuur küljes. Minu jaoks tundub see pluss olevat, reaalselt pole muidugi proovinud.
Lisaks veel mõned erinevused Kindle 3 ja Sony vahel:
Sonyl on puutetundlik ekraan. Kindlel ei ole.
Kindle on natuke pikem, klaviatuuri tõttu. Sony (600) on natuke raskem. Sony 650 on Kindlest veidi kergem.
Kindle on plastikust, Sony korpus on alumiiniumist.
Ekraan on mõlemal sama, kuid Sony 600 puutetundlik kiht halvendab tugevalt kontrasti. Uus Sony 650 olla sellest murest prii.
Kindle aku kestab kauem (eriti kui wifi on maha keeratud). Eriti kehtib see Sony uue mudeli, 650 kohta mille uus puutetundlikkuse tehnoloogia võtab rohkem voolu. Kuna mina puutetundlikkusest eriti ei hooliks, siis eelistaks küll kauem kestvat akut.
Kindlel on rohkem sisemist mälu. Sony mälu saab see-eest laiendada. Võib osutuda oluliseks, kui tahate kogu oma raamatukogu hoida lugeja peal või soovite kasutada seda mp3 mängijana.
Lisaks on mp3 mängimise funktsioon on Sony'l arenenum. Kindle oma on päris primitiivne.
See-eest Kindle suudab teksti valjusti ette lugeda ja kooskõlas sellega on tal ka sisse-ehitatud kõlarid. Lisaks toetab DRMitud audiobooke. Sony toetab ainult vabasid. Seega kuulderaamatute fännile on Kindle selgelt parem valik.
Sony't ei saa laadimise ajal kasutada. Ei tea hetkel, kas Kindlet saab.
Kindle softi uuendatakse sagedamini.
PDF tugi on Sony'l parem. Aga Sony'l ei ole brauserit, samas kui Kindlel on. Loogiline ka, sest Sony senistel mudelitel pole ei wifit ega 3G-d, seega brauserist oleks niikuinii vähe tolku. Niiet kui te tahate e-readeri abil näiteks webmaili üle wifi tsekkida vms siis ei tohiks Sony't valida. Samas, kui te olete haruldaselt paranoilised seadme potentsiaalse "call-home" funktsiooni suhtes, või et kardate, et kurjad onud Amazonist kustutavad mõned teie ostetud raamatud järgmise update'ga maha või tuvastavad piraatvara seadmesse laadimise, siis on traadita ühenduse võimaluseta seade kahtlemata parem valik
Lõpuks ärme unusta ära ühte väga olulist vahet:
Kindle on peaaegu 100$ odavam...
Ehk oli kellelegi abiks... iseenda ma juba veensin peaaegu ära... kuigi aasta tagasi olin risti vastupidisel seisukohal...
| Kommentaarid: 7 loe/lisa |
lehm2
25.10.2010 20:14:45
Vaatasin otsisin üht vanat e-raamatulugeja teemat aga ei leidnud. Tahtsin küsida, kas keegi omab uut Kindle readerit, millised on muljed kuidas sobib lugemiseks ? Mul on suhteliselt palju lugemist pdf formaadis, et kuidas uue generatsiooni kindle toetab pdf formaati näiteks ka siis kui on pilte ja diagramme? Teiseks tahtsin küsida, et kus kohast kõige odavamalt saaks, leidsin internetist et netikulleri kaudu peaks isegi saama tellida ?
Aitäh.
_________________ Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust ! |
| Kommentaarid: 15 loe/lisa |
26.10.2010 10:55:19
| mikk36 kirjutas: |
| Tasuta traadita internet (mobiilivõrku pidi) toimib vaid USA pinnal. |
Kindle versioone võib olla erinevaid aga see, mida ma Brüsselis hiljuti näppisin, läks 3G'ga ilusti netti. Tõsi - vaid Amazon ise + Wikipedia töötasid.
147 |
kami
26.10.2010 16:58:29
| Mercury kirjutas: |
Kas olev 3G (Free 3G) Eestis pole kätte saadav? |
Whispernet töötab enam kui sajas riigis. Muuhulgas Eestis (peamiselt EDGE võrgus).
Allikas: Amazon UK ja Interaktiivne kaart
| Kommentaarid: 12 loe/lisa |
12 |
madboy
03.02.2011 14:05:01
Olen nüüd Kindlet (3G) kasutanud viimased paar nädalat. Sain kätte selle vahetult enne reisi ja loopisin täis erinevaid raamatuid ja ka kiirelt kokku klopsitud PDF'id reisi sihtkoha infoga. Niiet sain lennukis hoolega uurida kuhu lähen Kahjuks aga PDFi enda lugemine on suhteliselt ebamugav, kuna kuvab teksti terve lehe laiuselt ja ei jaga ise lauseid ära. Zoomi kasutamine pole ka just kõige parem. Olukorrast päästis raamatu keeramine horisontaal asendisse. Sedapidi lehe laius natuke suurem ja ka tekst oli minu silmadele juba täiesti loetav. See eest ametlik raamatu formaat on super. Väga sobiva kirja suurusega ja seda saab ka nupule vajutusega muuta. Pean nüüd natuke katsetama neid konvertereid ja proovima PDFe sobivamaks muuta.
Mis puutub tasuta võrku, siis see toimib ainult osade lehtetega. Igalpool saab ligi muidugi amazoni raamatupoodi ja endale raamatuid juurde hankida. Samuti on ligipääs wikipedia lehele. Seda siis katsetatud Eestis, Saksamaal ja Trinidad & Tobago saareriigis.
Väga meeldib mulle ka see, et ta on natuke pikem kui ekraan. Siis on selline mõnus osa all, kust kinni saab veel lisaks hoida, ilma ekraani käppimata. Aku pidas ilusti vastu kaks ja pool nädalat. Selle käigus sai siis ikka paar raamatud läbi loetud, kõvasti oma reisifailides soritud, natuke wikipedias surfatud, amazonist raamat ostetud ja veidike ka muusikat kuulatud. Võrk oli muidugi enamus ajast välja lülitatud.
Mis puutub ekraani, siis pole veel ühegi valgusallikaga õnnestunud lugemist segada. Päikse käes oli kõik väga selge ja ka pimedas toas pea kohal oleva otse ekraanile paistva lambiga. Teksti tumedus on alla keskmise olnud koguaeg. Vajadusel saab seda kiirelt muuta.
Eile katsetasin ka natuke ette lugemise varianti. Ingliskeelne tekst kõlas isegi päris talutavalt. Lugeda suudab ta muidugi ainult eraamatu formaadist, mitte igast pdfist.
Ja Kindle sai hangitud itipood.ee'st.
| Kommentaarid: 49 loe/lisa |
44 |
