praegune kellaaeg 22.11.2026 10:53:54
03.08.2010 15:05:08
Single channel HLNAND SSD prototüüp saavutas rekordilised kiirused |
link :: Techpowerup
MOSAID Technologies Inc. teavitas eile rekorditest, mille saavutas Single channel HLNAND SSD prototüübiga. Lugemiskiiruseks saadi 213MB/s ja kirjutamiskiiruseks 130MB/s. Võrdluseks, praegused teise põlvkonna SSD seadmed vajavad sellise kiiruse saavutamiseks vähemalt 8 või rohkem kanalit.
Selliste kiirustega jääb juba ka SATA 6Gbit/s jalgu. Seeriaviisiliselt toodetavate SSD andmeedastuskiirusteks plaanitakse koguni 1TB/s.
HLNAND SSD Prototype - Design Details
The HLNAND SSD is a fully functional, Serial ATA 3 Gbps (SATA II) compatible prototype incorporating a Field Programmable Gate Array (FPGA)-based controller and MOSAID's HLNAND modules, built in the 3.5 inch form factor. The HLNAND SSD prototype uses two 64GB HLDIMM modules (eight multi-chip packages (MCPs) per module, 16 MCPs in total) arranged on a single channel. MOSAID provided the HLDIMM modules, and INDILINX built the controller and system board.
Prototype design limitations required reducing the HyperLink channel clock from 133 MHz to 75 MHz. A production version of the HLNAND SSD utilizing an FPGA-based or ASIC-based controller with eight channels would operate at the full 133 MHz clock to achieve read and write throughput each exceeding 1 TB/s. |
7 :: |
364 |
sagem
03.08.2010 19:59:09
| Andke hinda!
1dumbpcuser
97 |
aX
03.08.2010 22:09:02
Kahjuks ei jõua neidki osta mis praegu turul on
84 |
kalluka
27.10.2010 19:34:09
| Seni kuni hind ei kuku ei saa endale lubada selliseid luksusi.
| Kommentaarid: 16 loe/lisa |
12 |
