praegune kellaaeg 05.10.2026 19:51:09
yenx
14.07.2010 16:20:14
.dll fail puudu |
HP LaserJet P1005 on puudu P1006CLS.dll fail.
Otsisin internetist seda faili aga kuskilt ei leidnud. Kas keegi saaks saata mulle selle?
ViskeRelv
14.07.2010 16:25:28
| Aga installi printeri driverid uuest.
| Kommentaarid: 188 loe/lisa |
168 |
Anna tooli
300 |
iDemon
14.07.2010 16:26:58
See fail on sul endal seal pakis olemas, pead selle ennem lahti pakkima. See installer on lihtsalt vigane.
The zipped driver package contains 2 additional zip files in it. During setup those zipfiles are extracted to a temp file but somehow not properly… The original driver file has a long name like “ljP1000_P1500-HB-pnp-win32-en.exe”… Although it seems to be an exe file actually it is a zip-exe file… Instead of executing it just unzip it into a folder than you will see additional zipped cab files named “HP1006drv32.cab” and “HP1006enww32.cab”… unzip those cab files you will find missing dlls like P1006CLS.dll
Veidi paremini sõnastatult copypasta:
unzip the downloaded exe file - right click on exe file and chose unzip, unzip it into a folder where you can easily locate - when you check the folder you should see two additional zipped cab files named “HP1006drv32.cab” and “HP1006enww32.cab” in that folder - unzip those cab files with the same method, right click and unzip into the same folder.
| Kommentaarid: 122 loe/lisa |
104 |
