praegune kellaaeg 24.10.2026 09:18:39
asjameez
17.06.2010 12:58:42
.3ds ja lib3ds |
Tegin ühe väikse klassi, mis OpenGL ja lib3ds kasutades renderdab .3ds mudeleid. 95% netis leiduvatest .3ds failidest renderdab kenasti ära, aga mõned mudelid renderdab nii, et meshid on "laiali puistatud".
Eriti problemaatiline on näiteks see mudel:
http://www.3dm3.com/modelsbank/model428.htm
Täpselt selline pilt siis avaneb:
http://www.upload.ee/image/640387/mess.png
Samas näiteks GLC Player ja Meshlab suudavad seda sama Land Cruiserit ilusti komplektsena näidata. Olen uurinud nende source koodi, aga pole avastanud midagi sellist, mis selle vea ära parandaks.
Minu joonistustamise funktsiooni kood:
void Model3DS::Draw() {
assert(Model != NULL);
// Calculate the number of faces we have in total
GetTotalFaces();
Lib3dsMesh * Mesh;
Lib3dsVector * Normals = new Lib3dsVector[TotalFaces * 3];
// Loop through all the meshes
for(Mesh = Model->meshes; Mesh != NULL; Mesh = Mesh->next) {
glBegin(GL_TRIANGLES);
lib3ds_mesh_calculate_normals(Mesh, Normals);
// Loop through every face
for(GLuint CurrentFace = 0; CurrentFace < Mesh->faces; CurrentFace++) {
Lib3dsFace * Face = &Mesh->faceL[CurrentFace];
for(GLuint i = 0;i < 3; i++) {
Lib3dsMaterial *Material = 0;
Material = lib3ds_file_material_by_name(Model, Mesh->faceL[CurrentFace].material);
GLfloat Black[4] = { 0.0, 0.0, 0.0, 1.0 };
GLfloat White[4] = { 1.0, 1.0, 1.0, 1.0 };
if(Material) {
glMaterialfv(GL_FRONT_AND_BACK, GL_AMBIENT, Black);
glMaterialfv(GL_FRONT_AND_BACK, GL_DIFFUSE, Material->diffuse);
glMaterialfv(GL_FRONT_AND_BACK, GL_SPECULAR, Material->diffuse);
glMaterialfv(GL_FRONT_AND_BACK, GL_EMISSION, Black);
GLuint s = pow(2, 10.0 * Material->shininess);
if(s > 128.0) {
s = 128.0;
glMaterialf(GL_FRONT_AND_BACK, GL_SHININESS, s);
} else {
GLfloat Diffuse[4] = { 0.7, 0.7, 0.7, 1.0 };
glMaterialfv(GL_FRONT_AND_BACK, GL_DIFFUSE, Black);
glMaterialfv(GL_FRONT_AND_BACK, GL_SPECULAR, Black);
glMaterialf(GL_FRONT_AND_BACK, GL_SHININESS, 0);
glNormal3fv(Normals[CurrentFace*3+i]);
glVertex3fv(Mesh->pointL[Face->points[i]].pos);
glEnd();
// We no longer need lib3ds
lib3ds_file_free(Model);
Model = NULL;
Mingi parameeter puudu, mis tükid kokku paneb või milles võib viga olla? Ise rohkem progeja kui modelleerija
| Kommentaarid: 63 loe/lisa |
61 |
Braien
17.06.2010 13:02:39
Proovi sellise programmiga nagu Zmodeler importida, kas siis ka eraldi asjad?
90 |
asjameez
17.06.2010 13:28:20
| braien334 kirjutas: |
| Proovi sellise programmiga nagu Zmodeler importida, kas siis ka eraldi asjad? |
See programm ei avane kahjuks üheski arvutis.
61 |
