praegune kellaaeg 24.10.2026 09:18:37
ufo56
14.06.2010 17:44:37
Win 2008 r2 BSOD |
hei
Igatahes nüüd selline asi serveriga, vahel põhjustab bsodi mingi imelik cd-rommi error "the following boot-start or system-start driver s failed to load cdrom" Füüsilist cd rommi pole olemas muidu isegi. Ainuke cd rommi võimalus on üle võrgu läbi ipmi kvmi.See on disabletud. On kellelgi miskit soovitust mida proovida ? Antud error on tekkinud lambist. Võin jagada pikemaid event vieweri logisi
Logi antud errorist http://www.alienservers.org/upload/files/1/logi.evtx
friik1
14.06.2010 20:23:09
Lingi taga on 404.
Võta debugging tools ette ning sööda talle dump ette, vaata mis räägib. Annab sulle mõne dll'i või sys'i ehk.
ufo56
14.06.2010 22:24:44
Logi fail muidu http://www.alienservers.org/upload/files/1/logi.rar
dump file näitab csrss.exe
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\061410-11668-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: Server, suite: TerminalServer SingleUserTS
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`01665000 PsLoadedModuleList = 0xfffff800`018a2e50
Debug session time: Mon Jun 14 16:38:17.771 2010 (UTC + 3:00)
System Uptime: 0 days 2:16:55.349
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, fffffa800d10cb30, fffffa800d10ce10, fffff800019e1540}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
unable to get nt!KiCurrentEtwBufferOffset
unable to get nt!KiCurrentEtwBufferBase
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : csrss.exe
Followup: MachineOwner
Lae pildid -> pilt.io |
arvi16
ufo56
14.06.2010 22:33:36
Uurin
viimati muutis ufo56 14.06.2010 23:09:31, muudetud 1 kord |
arvi16
friik1
14.06.2010 22:53:39
No ma ei usu, et see cdrom üldse asjaga seotud on aga...
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\cdrom
Start = 4
See keelab draiveri laadimise.
ufo56
14.06.2010 23:10:23
Nüüd näitab miskit sellist, alguses on vana jutt et pole sümboleid aga lõpus miskit uut
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
5: kd> .reload
5: kd> .restart /f
Symbol search path is: SRV*DownstreamStore*http://msdl.microsoft.com/download/symbols
Machine Name:
Probably caused by : _
5: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa800d10cb30, Terminating object
Arg3: fffffa800d10ce10, Process image file name
Arg4: fffff800019e1540, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa800d10cb30
IMAGE_NAME: _
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: _
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: TCAdminService
BUGCHECK_STR: 0xF4_TCAdminService
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT_SERVER_MINIDUMP
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80001a61c72 to fffff800016d5600
STACK_TEXT:
fffff880`066aeb08 fffff800`01a61c72 : 00000000`000000f4 00000000`00000003 fffffa80`0d10cb30 fffffa80`0d10ce10 : nt!KeBugCheckEx
fffff880`066aeb10 fffff800`01a0f0a3 : ffffffff`ffffffff fffffa80`0d57eb60 fffffa80`0d10cb30 fffffa80`0dd86490 : nt!PspCatchCriticalBreak+0x92
fffff880`066aeb50 fffff800`0199369c : ffffffff`ffffffff 00000000`00000001 fffffa80`0d10cb30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17936
fffff880`066aeba0 fffff800`016d4853 : fffffa80`0d10cb30 00000000`ffffffff 00000000`7efa4001 fffffa80`0d57eb60 : nt!NtTerminateProcess+0x20c
fffff880`066aec20 00000000`7784017a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0332e808 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7784017a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_TCAdminService_IMAGE__
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
5: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
IMAGE_NAME: _
MODULE_NAME: _
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
friik1
15.06.2010 14:01:42
Tee näiteks c: juurikasse kaust symbols ja pane sümbolite path'iks "SRV*c:\symbols*http://msdl.microsoft.com/download/symbols"
Praegune tee on vale, nagu Debugger väidab.
A process or thread crucial to system operation has unexpectedly exited or been terminated. <--- miski tappis või crashis csrss.
Uuri näiteks, kas masinas pole mõnda viirust, mis seda tapaks (või rootkit, mis corruptiks stacki) või tee üks ring memtesti (kui csrss suri mingi mäluvea tõttu).
ufo56
15.06.2010 14:25:06
See osa tehtud ja kõik ok.
Aga ma ei saagi aru kuidas ma seda symbol pathi panen ma tõmbasin symbolid alla, mingi 280mb ja need asuvad C: win/symbols
friik1
ufo56
15.06.2010 14:36:21
Okei eks ma vaatan, panin full memodry dumpi peale , eks näha kui bsodi viskab
