lightbluefox
07.06.2010 21:31:42
Laptopi mälude konflikt (?), pidevad bluescreenid |
Kolin Win7 teema alt siis siia,
Alustuseks uuesti logi
Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 7.06.2010 4:08:27 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x24 (0x1904FB, 0x80D9681C, 0x80D96400, 0x877C5885)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\060710-49651-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT File System Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Sun 6.06.2010 19:47:28 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x19 (0x22, 0x4000, 0x0, 0x0)
Error: BAD_POOL_HEADER
Dump file: C:\Windows\Minidump\060610-35010-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
On Sun 6.06.2010 18:09:18 your computer crashed
Bugcheck code: 0xA (0x14, 0x2, 0x0, 0x8287A477)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\060610-34719-01.dmp
On Sun 6.06.2010 17:32:30 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x82A76144, 0x9C16EB10, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Dump file: C:\Windows\Minidump\060610-49431-01.dmp
On Sat 5.06.2010 19:37:06 your computer crashed
Bugcheck code: 0x1A (0x3452, 0x81B0000, 0xC040DA34, 0x56E8C66)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\060510-31996-01.dmp
Viimane huvitav teooria pakkus veaks mälude konflikti, enne olid mõlemad pesad hõivatud 256mb dd pc2700 pulkadega, nüüd vahetus põhjaalune klots 1024mb ddr pc2700 vastu. Lisaks tohutule kiirusekasvule, tekkisidki suvalised kokkujooksmised, samas nt mängud jooksid veatult ka pikka aega, filmid jooksid mingi aja pärast kokku, samuti ka lihtasalt netis surfates.Flash videotes pidin gpu kiirenduse keelama, kuna muidu oli pilt otsast lõpuni digitaalset sodi täis, ilma oli puhas. Ei olnud kindlat programmi või tegevust mis kokkujooksu põhjustas, ilma koormuseta samas seda ei juhtunud.
Ideid?
Ahjaa, läpakas toetab ametlikult kuni 2gb pc2700 ddrami, ehk siis mõlemas pesas kuni 1gb klots.
| Kommentaarid: 45 loe/lisa |
44 |
07.06.2010 22:07:00
See, et on olemas mingi ametlik kinnitus, see ei pea väga tihti paika - või peab paika ainult mingitel kindlatel tingimustel.
Näiteks siis, kui kasutatakse firma poolt soovtatud mälutootjate kindlat tüüpi mälusid vms.
Aga kui jutt käib vanakesest IBM-i läpparist, siis IBM on ajaloos sellega hakkama saanud küll, et esitab sobivuste kohta igasuguseid omapoolseid nõudmisi.
Niipalju veel, et kuna selles vanakesel IBM-il on videomälu kõigest 32MB, siis on võimalikud ka videokonfliktid - juhul, kui kõikvõimalikud Aerod jms. suurt videomälu nõudvad toimingud on lubatud.
211 |
lightbluefox
08.06.2010 08:11:03
Aero on lubatud, aga reaalselt toimib ju vaid aero basic, kuna dx7 kaart rohkem ei võimalda.
Soovitatud on proovida mälud swappida, põhipesa on ju klaviatuuri all, kui gigiane klots sinna tõsta, ehk midagi muutub. Kui ei, jätta gigane sinna ning lihtsalt 256mb välja võtta.
Gigase pulga kohta niipalju lisainfot:
200-pin unbuffered DIMM
• Density: Low Density
• PC2700 333FSB (Backwards compatiable with PC2100)
• 2.5 Volts
• 6 Layer unbuffered
• CAS Latency 3
• 4 Bank
• Off-chip driver (OCD) impedance adjustment, and on die termination (ODT)
Warranty: Life Time Manufacturer warranty
44 |
virks
08.06.2010 09:07:55
Millisest arvutist täpsemalt jutt?
Memtest puhas?
| Kommentaarid: 526 loe/lisa |
420 |
lightbluefox
08.06.2010 10:05:26
laptop on IBM T41
1,6Ghz Pentium M
Memtesti jooksutanud pole, selliseid vead peaksid juba nt winrariga välja tulema, ostetud ram on uus ja vanad töötavad nii üksi kui kaksi veatult.
44 |
08.06.2010 10:15:53
Raidomarek: Tõenäoliselt siis see teema, et see vanake IBM ei söö korralikult tänapäevaseid mälusid, sõltumata sellest, et kirjade järgi on tüüp sama.
Nii, et ma kipun küll arvama, et veavaba tööd näed siis, kui paned 2x512MB täpselt ühesugused mälud sisse.
Ja veel: Kui see 1024 on selline klots, kus mälukivid on ühel pool plaati, siis võib see IBM süüa selliseid mälusid, millel on need mälukivid mõlemal pool plaati.
Sama jutt sii, et IBM võib tahta kindlate firmade kindlaid mälutüüpe.
211 |
virks
08.06.2010 10:32:39
| Sama masin omal majapidamises ja 2*1GB sees. Erinevad mälud ja probleeme pole. Olen testinud seal igasuguseid ja siiani on kõik kättesattunud isendid toiminud.
420 |
robema
08.06.2010 10:42:28
Alustaks BIOS'i uuendamisest ja liiguks MemTest'i poole.
_________________ 1+1=0 |
| Kommentaarid: 55 loe/lisa |
52 |
08.06.2010 11:14:38
Memtesti võib ju katsetada, ag mina usun küll, et viga pole mitte katkises mälus, vaid selles, et Windowsi all tekivad mälulaadmisel konfliktid, kuna läppar ei oska seda konkreetset toodet õigesti täis-tühjaks kirjutada või adresseerida.
Olen selle enda kunagise, 7 aastat vana, Aceriga ära näinud, kus tuli valida üsna paljude mälutüüpide vahel - enne, kui õnnestus sellised vanematüübilised mälud leida, mida see Acer veavabalt süüa suutis.
Ning sellised, mis ei töötanud, läksid käiku HP Compaqide juures ja Compaqid sõid neid mälusid suurema heameelega.
211 |
lightbluefox
08.06.2010 18:47:45
Bios on 3.2.3, 2007a, ehk siis viimane mis Lenovo pakub.
e: Grr, ei buudi ühegi nipiga usb pulgalt, pidin tegema seda, millega tegeleti ilmselt juba I maailmasõja ajal - Kirjutama cd-plaadi.
Memtest86+ v4.10 jookseb ja ootame tulemust.
edit: ojijah, ca poolteist tundi jooksnud ja selline pilt oli ees. Proovin vist nüüd ainult 256 klotsiga?!
44 |
virks
08.06.2010 18:56:35
| Proovi jah pulgad ükshaaval läbi - siis on näha kas üks pulk vigane või tõesti ei sobi nad koos töötama.
420 |
lightbluefox
08.06.2010 19:55:07
See on siis see gigane üksi, teises mälupesas.
44 |
virks
08.06.2010 20:12:44
| Viga leitud.
420 |
lightbluefox
08.06.2010 20:16:19
| Aga see üksi ei näita, et ramm vigane on (liialt usku eluaegsesse garantiisse), kuna läpakal suri ka wifi pesa ära, on järsku ka võimalus, et lihtsalt emaplaat ajab villast. Nii peaks proovima sama pulga ka teises pesas ära, täpselt nagu memtesti tegijad soovitavad.
44 |
virks
08.06.2010 21:14:56
Eluaegne garantii ei tähenda seda, et seadmed 100% sinu eluae ületavad.
Surevad need samamoodi kui kõik muud pulgad. Lihtsalt tootja annab sulle uue jupi, kui vanaga midagi juhtuma peaks.
Aga teises pesas võid proovida küll. Ma ei usu, et see midagi muudab, sest mõlema pildi peal on vead "lõpus".
420 |
lightbluefox
09.06.2010 07:57:58
Eile testisin gigast pulka peaslotis. Vigu ei tuvastatud.
Lisasin teise eluaeg selles lapatsis olnud 256mb pulga- vead lõpus.
Siiski toimusid kokkujooksmised ka siis kui ainult gigane masinas oli, vead samad, samuti oli flash videotes ikka pilt sassis.
Nüüd jookseb taas 2x256 nagu algusest saadik, flashvideote probleem ei ole kadunud, kui mulle nüüd meenub, siis logi järgi algasidki buudid paar päeva varem kui ramivahetus, kindlalt ei väida. Nüüd pean siis laskma joosta ja vaatama kas sinised tulevad tagasi, aga seda saan alles õhtul kommenteerida.
44 |
robema
09.06.2010 08:36:11
Kommentaariks veel, ei pruugi mälu ise vigane olla, sagedamini on vigased mälupesad, seepärast ongi soovitus alati sama mälu teises arvutis uuesti testida.
52 |
