uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD HD 6000 teema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 23, 24, 25 ... 151, 152, 153  järgmine
NATAS999
sõnum 19.10.2010 10:09 vasta tsitaadiga
erick, minu pärast nimetagu kasvõi poolide keerdude koguarvu järgi, but it doesn't make any sense. täpselt nagu kivi kõrguse ja ümbermõõdu poolsumma korrutis. järjepidevus ja loogika võiks sellistel asjadel olla.
karoona, karoona, karoona, sa uudised endaga tood.
erick
erick
sõnum 19.10.2010 10:19 vasta tsitaadiga
NATAS999 kirjutas:
EDIT: siin ta on.
ot:
There has been rumours of name change going along with this
With only 2 exceptions, names of the ATi's products launched in last 7 years, always corresponded to die size:
101 - 150mm² => x6xx
* RV830 (Radeon HD5500): 104 mm²
* RV635 (Radeon HD3650): 120 mm²
* RV530 (Radeon X1600): 150 mm²
* RV630 (Radeon HD2600): 150 mm²
* RV730 (Radeon HD4600): 150 mm²
151 - 190mm² => x7xx
* RV410 (Radeon X700): 156 mm²
* RV840 (Radeon HD5700): 170 mm²
191 - 340mm² => x8xx
* RV670 (Radeon HD38x0): 192 mm²
* R430 (Radeon X800XL): 240 mm²
* RV770 (Radeon HD4800): 256 mm²
* R420 (Radeon X800XT): 281 mm²
* RV790 (Radeon HD4890): 282 mm²
* R520 (Radeon X1800): 288 mm²
* RV870 (Radeon HD5800): 331 mm²
341 - 500mm² => x9xx
* R580 (Radeon X1900XT): 342 mm²
* R580+ (Radeon X1950XT): 34x mm²
* R600 (Radeon HD2900): 420 mm²
The only two exceptions in this system were two "pipe-cleaner" parts, which were used for testing of new manufacturing process and because of that, they were significantly smaller, than other GPUs of that family: RV570 (80nm), RV740 (40nm).
Järjepidevus aastast 2004 (X800-seeria).
WoT Stats Twitch Stream Ei näe uusi poste WoT teemas? Kliki siia!
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 88
trip
trip
sõnum 19.10.2010 10:34 vasta tsitaadiga
http://forum.beyond3d.com/showpost.php?p=1483543&postcount=3351
Sampsa asked wtf was going on with the codename mess, here's what AMD said
"According to AMD rep, Northern Islands was the original codename for 32nm chips, but when TSMC cancelled the process, AMD had to change their 32nm plans to 40nm plans, and the name swithced to Southern Islands at the same time.
During spring/summer AMD GPU engineers however thought that Southern Islands before the original Northern Islands wasn't logical, so Radeon HD 6000-series chips codenames were returned to the original Northern Islands form. Apparently the naming mess has caused confusion even within AMD itself.
A simpler version (codename first, explanation then):
1. Northern Islands = Original codename for 32 nm gfx chips
2. Southern Islands = NI 32 nm -> 40 nm plans change
3. Northern Islands = Southern Islands before Northern Islands didn't feel logical
4. Southern Islands = Codename for 28 nm gfx chips now
Kommentaarid: 401 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 298
erick
erick
sõnum 19.10.2010 10:52 vasta tsitaadiga
OOPS?
HD6850 - $213
HD6870 - $265
lingid:
http://www.futurepowerpc.com/scripts/product.asp?PRDCODE=1016-EAH6850_DC/2DIS/1GD5&REFID=FR
http://www.futurepowerpc.com/scripts/product.asp?PRDCODE=1016-EAH6870/2DI2S/1GD5
ASUSe kaardid pole kusjuures kunagi oma hea hinna poolest silma torganud ... pigem paarsada EEK kallimad.
Sellest võiks optimistlikult järeldada, et HD6850 = $199 ja HD6870 = $249.
Varsti võib hakata AMD aktsiaid kokku ostma, sest selliste hindade juures need kaardid müüvad nagu viiekroonised blowjob'id missikandidaadilt ...
viimati muutis erick 19.10.2010 10:55, muudetud 1 kord
Dolph
sõnum 19.10.2010 10:53 vasta tsitaadiga
erick kirjutas:
NATAS999 kirjutas:
ehhh. kui 6870 asendaks 5870't, siis peab 6870 olema 6xxx seeriast kiireim single GPU kaart. kui ta seda pole, siis ei saa rääkida siin 1:1 asendamisest. see, kui 6870 tuleb sama jõudlusega, mis 5870, on BS marketing rebranding clusterfuck ja otseselt tarbijatele näkku kusemine. isegi, kui hind samaks jääb.
No mida te lendate selle nime peale üle võlli ikka veel icon_smile.gif Ammu ju ära seletatatud, et AMD puhul märgista kolm viimast numbrit mitte GPU kohta marketingihierarhias, vaid selle PINDALA ruutmillimeetrites. Jah, kiiremad GPU'd on reeglina ka suurema pindalaga, aga see on lihtsalt kokkusattumus.
Seda, et hinnad jäävad samaks kui HD5800 seerial, ei tohiks juhtuda. Sa ei tee marginaalselt nõrgema performanciga refreshi aasta aega hiljem, et seda sama hinna eest müüa kui enne kiiremat ja vanemat kaarti. Seda ma ei loodaks, et HD6850 asendab HD5770ne, aga tema hind on kindlasti tunduvalt madalam kui HD5850-l.
Mina usun raudselt et tegu on marketing nipiga. Hind sõltub ikka turusituatsioonist. Miks peaks AMD müüma uut kaarti odavamalt kui konkurentsitingimused ei sunni. AMD on tublilst välja arendanud kiriemad kaardid aga Nvidial pole tugevat vastast. Kui nüüd 6850 välja lasta ja see oleks 15% kiirem kui 5850 siis oleks selle eest kõrgema hinna küsimine raske. Kõik ootavad sama hinda (nagu 5000 seeria vs 4000 seeria oodati). Aga selle skeemiga saab sama jõudlusega uut kaarti müüa sama hinnaga ja suurema jõudlusega kaartite kõrgema hinnaga ja ostjad ei ole rahulolematud.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
erick
erick
sõnum 19.10.2010 10:57 vasta tsitaadiga
Loe enda omale eelnenud postitust.
Lisaks võta arvesse, et HD6800 seeria on tegelikult umbes 5-10% AEGLASEMAD kui HD5800 seeria.
KrisVr
sõnum 19.10.2010 11:50 vasta tsitaadiga
Sapphire Radeon HD 6800 Series Cards Pictured
TechPowerUP
Sapphire is ready to launch its Radeon HD 6800 series products. As AMD's one of front-line partners, why wouldn't it be? The company will kick off its lineup with a Radeon HD 6870 model that sticks to the AMD reference design, and a Radeon HD 6850 based on an in-house design, probably marketed with the company's popular "Toxic" or "Vapor-X" brands. The Radeon HD 6870 card is compliant with the reference design, and uses reference clock speeds of 900/1050(4200) MHz (core/memory(effective memory)). It features DirectX 11 support, 1120 enhanced stream processors, 1 GB of GDDR5 memory over a 256-bit wide memory interface, and display connectivity that includes two DVI, two mini-DP 1.2, and one HDMI 1.4a. 2-way CrossFire is supported.
The Radeon HD 6850 card, on the other hand, sports an in-house design with both the PCB and the cooler. The PCB is colored in Sapphire's favourite shade of blue. The cooler looks quite muscular with a heatsink (probably making use of vapor-chamber technology) over the GPU, a 90 mm fan, and 8 mm heat pipes conveying heat to additional aluminum fin arrays. This card also reportedly sticks to reference clock speeds of 775/1000(4000) MHz, and features 960 stream processors, and 1 GB of GDDR5 memory over a 256-bit wide interface. Display connectivity on this card is more akin to what we're used to seeing on the HD 5800 series: two DVI, one standard-size DisplayPort 1.2, and one HDMI 1.4a. Expect both these cards to be out on the 22nd. A non-reference HD 6870 later down the line from Sapphire can't be ruled out.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 26
Dolph
sõnum 19.10.2010 12:05 vasta tsitaadiga
erick kirjutas:
No mis siis. loogika on ikka sama. 5750 ja 5770 seeria praegu ju odavam.
erick
erick
sõnum 19.10.2010 13:41 vasta tsitaadiga
Dolph kirjutas:
erick kirjutas:
No nagu ma ütlesin, HD6850 maandub HD5770 ja 5850 launch price'i vahele ($160 & $249) - kusjuures enamvähem täpselt vahele ($199).
HD5850 hinda keegi selle eest nõudma ei hakka.
KrisVr
sõnum 19.10.2010 14:47 vasta tsitaadiga
ASUS Radeon HD 6850 DirectCu OC Graphics Card Pictured
TechPowerUP
AJ
AJ
sõnum 19.10.2010 14:57 vasta tsitaadiga
Quick Look: AMD Radeon HD 6850 and HD 6870 - What We Can Tell You
TweakTown
CoiL
CoiL
sõnum 19.10.2010 15:28 vasta tsitaadiga
Low-profile HD6K kaartide kohta ka uudiseid keegi näinud on? icon_rolleyes.gif
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
trip
trip
sõnum 19.10.2010 15:41 vasta tsitaadiga
G80
G80
sõnum 19.10.2010 16:07 vasta tsitaadiga
Ära siia kliki
Kommentaarid: 240 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 194
pohmakas,
käed värisevad
pohmakas,
sõnum 19.10.2010 16:11 vasta tsitaadiga
äkki neil seal bulldozer kastis
Ehk siis protsessor annab nii palju juurde, kuid sinu arvates kaardid võrdsed?
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 126
kalluka
kalluka
sõnum 19.10.2010 16:49 vasta tsitaadiga
Kui see kõik nii on nagu tripi postituse pildist vaadata ja hinnad kokku panna see tähendab pm sama hinda mis 5770 ja perfi pea 5870 võrra ja see on valus litakas Nvidiale.Oi küll on hea ,et ootasin icon_biggrin.gif.Suu jookseb vett juba.
Aa ja leidsin kahh miskit huvitavat chiphellist http://translate.google.ee/translate?u=http%3A%2F%2Fnews.mydrivers.com%2F1%2F145%2F145887.htm&sl=zh-CN&tl=et&hl=&ie=UTF-8
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 12
G80
G80
sõnum 19.10.2010 16:50 vasta tsitaadiga
kalluka, tõsi ta on. icon_smile.gif Ja ootaks nüüd Techpowerup ülevaadet. icon_razz.gif
Ära siia kliki
kalluka
kalluka
sõnum 19.10.2010 16:52 vasta tsitaadiga
KÕIK 6800 seeria OKTOOBRI SLAIDID!!!
http://hw-lab.com/the-latest-official-amd-info-on-hd-6800.html
OMG
Asju mida me ei teadnudki icon_biggrin.gif.Dx11 ver 2 jne
viimati muutis kalluka 19.10.2010 16:58, muudetud 3 korda
erick
erick
sõnum 19.10.2010 16:56 vasta tsitaadiga
kalluka kirjutas:
See on nüüd natuke liiga optimistlik, hind on siiski oluliselt kõrgem kui 5770-l (Eestis ütleme 2,2K vs ~2,9K) ja performance ikka pigem HD5850-l kandadel. Kellamise osas on ka kahtlusi - ainult üks PCIe 6-pin on ju powerit andmas (kokku 75W + 75W kasutada), samas HD6870 voolutarve 900MHz juures on 150W, ja riistvaralised erinevused on suhteliselt väikesed.
sõnum 19.10.2010 16:57 vasta tsitaadiga
trip kirjutas:
Lol jah tavaline marketingi BS.Skaala algab 0.8 pealt ja seega tunduvad rohelised tulbad väga madalad icon_lol.gif thumbs_up.gif
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 73
G80
G80
sõnum 19.10.2010 17:02 vasta tsitaadiga
erick kirjutas:
kalluka kirjutas:
6-pin piirama ei jää.
HD 6870 lööb madalama hinnaga 5850 ära.
Ära siia kliki
erick
erick
sõnum 19.10.2010 17:04 vasta tsitaadiga
G80 kirjutas:
erick kirjutas:
kalluka kirjutas:
Vaatasin järele, 127W on HD6850 voolutarve. See jätab kellamise jaoks väga vähe ju. Parandage, kui eksin, aga PCI express pesa peaks andma 75W ja PCIe 6-pin peaks ka 75W andma...
CoiL
CoiL
sõnum 19.10.2010 17:10 vasta tsitaadiga
6870 võiks imekombel low-profile ka tulla siis oleks üüüüber kaart! icon_biggrin.gif beer_yum.gif
nah
nah
sõnum 19.10.2010 17:11 vasta tsitaadiga
Päris hea price/performance ratio tundub tulevat...
Kommentaarid: 150 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 141
NATAS999
sõnum 19.10.2010 17:16 vasta tsitaadiga
tomorrow, mis sa neid pulkadest passid, vaata numbreid siis, kus kohas 1 ja teine pulk ära lõpevad.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD HD 6000 teema mine lehele eelmine  1, 2, 3 ... 23, 24, 25 ... 151, 152, 153  järgmine
