sõnum  |
AJ
14.10.2010 08:54
Official Information: AMD Radeon HD 6850'nin technical specifications and price information
Donanim Haber
AMD is prepared to announce on October 22 for the Radeon HD 6800 series we were able to verify the information that is spoken for a long time. Barts and the two different versions of the code with the name of the graphics processing unit will power the new Radeon HD 6850 graphics cards, as mentioned earlier in our news comes from parallel processing unit 800x.
The current product range is expected to replace the Radeon HD 5770 Radeon HD 6850 model, 256-bit memory bus and 1GB of GDDR5 memory capacity. 4GHz memory speed as 775MHz determining if the display card, the graphics processing unit, the manufacturer will offer models running at speeds of 800MHz and above.
So AMD's Radeon HD 6850, which will be available in the price level? According to information obtained by the power of the AMD Radeon HD 6850'nin Barts Pro GPU'sundan, FOB vessel or aircraft that is installed in the Far East seems to be the last price will be around $ 175-180. So for our country, for example, taxes on this price, the profit of the distributor and chain stores (such as -30% in total) to be added. |
| Kommentaarid: 37 loe/lisa |
36 |
trip
14.10.2010 09:22
viimati muutis trip 14.10.2010 09:24, muudetud 1 kord |
| Kommentaarid: 401 loe/lisa |
298 |
Kristoferr
174 |
G80
14.10.2010 09:32
Cayman XT ja Antilles tulevad huvitavad.
| Kommentaarid: 240 loe/lisa |
194 |
Killhoven
OC`er
14.10.2010 11:50
5850 on pea 20% kiirem kui 460GTX 1GB tehase OC (vt näiteks Cyclone) @ 1920x1200. 5850 jõudlus siis pmst sama mis uuel Barts Pro`l. Samas hakkab uus kaart 460st vähemalt 10-20% rohkem ka maksma (peale "uudishindade" rahunemist).
Ühesõnaga ei midagi jalust rabavat. Arvata oli, et AMD-l ei ole kahjuks vajadust heade hindadega välja tulla.
E: Ärge lootkegi, et Cayman XT/Pro teile teab mis soodsalt kätte tulema hakkab. Tõsi, need kaardid tulevad üle 480/470 perfi, aga kindlasti vastavalt ka hind.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
299 |
arvutiH YT
14.10.2010 18:42
Mõned pildid XFX-i 6870-st (vist pole veel siit teemast läbi käinud):
Killhoven
OC`er
14.10.2010 18:53
Huvitav milleks jälle blokeerida õhu väljavoolu? Seekord siis geniaalse firma logoga?
299 |
NATAS999
14.10.2010 18:58
Killhoven, mingi custom made plekk seal taga. nii roostes kruvidega kaarti küll ei taha. wait wat? keegi põlve otsas nüri noaga nüsind selle XFX sinna ve? sest väga kole näeb välja teglt ju. ja tobe ka. varajane aprillinali ehk?
_________________ karoona, karoona, karoona, sa uudised endaga tood. |
| Kommentaarid: 39 loe/lisa |
37 |
Asgate
14.10.2010 19:12
| G80 kirjutas: |
| Cayman XT ja Antilles tulevad huvitavad. |
Just "AMD koopamehi" tuleb oodata !
| Kommentaarid: 16 loe/lisa |
KrisVr
14.10.2010 19:15
| Keegi on jah vist põlve otsas teinud, väga odav näeb välja.
| Kommentaarid: 29 loe/lisa |
26 |
AJ
14.10.2010 19:17
Need pildid ei ole vist siit teemast läbi käinud.
Pldid pärit siit
Radeon HD 6870 card captured in the nude
TechConnect Magazine
36 |
G80
14.10.2010 19:18
| NATAS999 kirjutas: |
Killhoven, mingi custom made plekk seal taga. nii roostes kruvidega kaarti küll ei taha. wait wat? keegi põlve otsas nüri noaga nüsind selle XFX sinna ve? sest väga kole näeb välja teglt ju. ja tobe ka. varajane aprillinali ehk? |
Ise oled roostes, kui ei meeldi kruvi ja võta plekk ära.
194 |
AJ
14.10.2010 19:32
Radeon HD 6850 & HD 6870 get listed, real clocks confirmed?
Craving more info about AMD's Barts-based Radeon HD 6850 and HD 6870 graphics cards? You're in luck as both these cards, which are still a week away from being made official, have been listed by a Dutch store who may or not may get in trouble very soon for jumping the gun.
Found by the guys @ Dinox PC , the listings are of the Sapphire Radeon HD 6850 and HD 6870 featuring DirectX 11 support, updated multi-monitor capabilities (up to six monitors per card), a 256-bit memory interface, 1GB of GDDR5 memory, two DVI, one HDMI 1.4 and two mini DisplayPort 1.2 outputs, CrossFire chops and a TDP of just under 150W.
The Radeon HD 6850 GPU and memory clocks published are 725 MHz and 4000 MHz, respectively, while the card's price tag is €189 ($265.7). The conversion probably isn't an accurate estimate as to how much the card will cost in the US but we just have to underline the higher prices here in Europe.
As for the Radeon HD 6870, it has the GPU/memory set to 900/4200 MHz and costs €255 ($358.5). |
36 |
pohmakas,
käed värisevad
14.10.2010 20:33
hetkeseisuga jään nvidia juurde, jätab täitsa külmaks miskipärast
126 |
Kristoferr
174 |
G80
14.10.2010 21:59
6870 näeb hea välja.
Nüüd ootaks testides tulemusi DX11 benchides ja mängudes.
194 |
trip
15.10.2010 08:33
6870 pcb vs 5870/5850
298 |
KrisVr
15.10.2010 11:37
NVIDIA to Counter Radeon HD 6970 ''Cayman'' with GeForce GTX 580
TechPowerUP
AMD is undertaking its product development cycle at a breakneck pace, NVIDIA trailed it in the DirectX 11 and performance leadership race by months. This November, AMD will release the "Cayman" GPU, its newest high end GPU, the expectations are that it will outperform the NVIDIA GF100, that is a serious cause for concern, for the green team. It's back to its old tactics of talking about GPUs that haven't even taken shape, to try and water down AMD's launch. Enter, the GF110, NVIDIA's new high-end GPU under design, on which is based the GeForce GTX 580.
The new GPU is speculated to have 512 CUDA cores, 128 TMUs, and a 512-bit wide GDDR5 memory interface holding 2 GB of memory, with a TDP of close to that of the GeForce GTX 480. In the immediate future, there are prospects of a more realistic-sounding GF100b, which is basically GF100 with all its 512 CUDA cores enabled, while retaining its 384-bit GDDR5 memory interface, 64 TMUs, and slightly higher TDP than that of the GTX 480. |
26 |
Dolph
15.10.2010 11:42
| Lauri Kiissel kirjutas: |
hetkeseisuga jään nvidia juurde, jätab täitsa külmaks miskipärast  |
Hoia meid kursis, et kuidas Su emotsioonid muutuvad.
14 |
G80
15.10.2010 11:52
| Dolph kirjutas: |
Hoia meid kursis, et kuidas Su emotsioonid muutuvad. |
Mind huvitab ka ehk teeb oma blogi, et saaks tema emotsioonidega kursis olla?
194 |
Kemmukas
15.10.2010 14:44
| Kas ma olen nüüd õigesti aru saanud, et nime poolest uued hd 6850 ja hd 6870 tulevad nende 5750 ja 5770 asemele ning nüüd see hd 6970 vastab 5870-le?
| Kommentaarid: 13 loe/lisa |
KrisVr
15.10.2010 14:45
| Kemmukas kirjutas: |
| Kas ma olen nüüd õigesti aru saanud, et nime poolest uued hd 6850 ja hd 6870 tulevad nende 5750 ja 5770 asemele ning nüüd see hd 6970 vastab 5870-le? |
Peaks nii olema jah!
26 |
kalluka
15.10.2010 14:50
| Ausaltöeldes see tekitab ainult segadust,hindade üle arutlemist ja väga raske on aru saada.Miks ei võiks panna samade nimedega mis 4000 seeria ja 5000 seeria?
12 |
Kristoferr
174 |
NATAS999
15.10.2010 15:07
| kalluka kirjutas: |
| Ausaltöeldes see tekitab ainult segadust,hindade üle arutlemist ja väga raske on aru saada.Miks ei võiks panna samade nimedega mis 4000 seeria ja 5000 seeria? |
sest amd teab paremini kui ati, mis nimega mis radeon peab olema.
37 |
