praegune kellaaeg 11.11.2026 09:10:53
PVAliim
10.04.2010 23:25:15
Ülevaade: Roccat Arvo klaviatuur |
Sai siis hiljuti ostetud Roccat Arvo. Foorumis ei ole näha selle ülevaadet, nii et otsustasin siis ühe teha. Roccat'i enda tutvustus Arvo kohta: “More space on the desktop without the need to forgo all the usual functions. This, and a whole lot more besides, is offered by the compact ROCCAT™ Arvo. It’s the first keyboard to offer a gaming mode integrated into the numpad and unique thumbster keys. These three extra keys can be assigned macros or the practical timer function, which can’t be found on any other keyboard on the planet.
As part of the ROCCAT™ Smart Desktop Management System, the ROCCAT™ Arvo only has a tiny desktop footprint compared to other standard keyboards. The idea behind the SDMS of creating space, order and efficiency is reflected in the keyboard’s compact design. As a result, neither the mouse pad nor mouse will get in your way during gaming – plus optimum use is made of the desktop gaming zone.
The compact design has been made possible simply by combining the numpad and arrow-key pad. The ROCCAT™ Arvo’s dual-assignment numpad means the keyboard takes up considerably less space while at the same time retaining all the functions you’d find on a standard keyboard. It’s easy to switch between normal and gaming mode simply by pressing the mode switch button.
Three unique macro keys are positioned beneath the spacebar which increases the opportunity to use the thumb during gaming, meaning it doesn’t need to be used purely for hitting the spacebar. The three thumbster keys can be individually programmed and easily operated using the thumb.”
Nüansid :
* COMPACT DESIGN
creates optimum gamespace
* MODE SWITCH BUTTON
for switching between Num Pad function and Gaming Mode
* 3 PROGRAMMABLE THUMBSTER KEYS
easy to reach with your thumb
* 2 ADDITIONAL MACRO KEYS
for individual keyboard commands
* MACRO MANAGER
create complex command sequences
* ANTI-GHOSTING CAPABILITY
for simultaneous keystrokes
* MEDIUM-HEIGHT KEYS
with an optimum keystroke response and perfect pressure point
* HIGH DURABILITY
with robust metal base
* 6 ILLUMINATED STATUS KEYS
directional keys, mode switch button and Caps Lock key
* KEY DEACTIVATION
for disabling Windows, Menu, Caps Lock and Tab keys
* ULTRA EFFECTIVE NON-SLIP BASE
with special lock-on keyboard feet for a comfortable gaming height
Karp ,nagu Roccat'il tavaks on, on väga informatiivne ning annab väga hea lühiülevaate klaviatuuri kohta.
Karbi sees leidsin klaviatuuri, kiire installimisjuhendi,Roccat'i kliendikaardi vms ja Driverite CD.
Klaviatuur on ise vägagi kompakte ning pildilt on ka näha suhet tavalise klaviatuuri suurusega(pole minu tehtud pilt)
Klaviatuuri paremal pool Numpad'i üleval on nupp "Mode" sellega saab vahetada numbrite ja noolteklahvide vahel - st ,et all on 4 nuppu vahetatava funktsiooniga.Lisaks on nooleklahvid sinise led tulega lagustatud kui nad aktiivsed on.
Roccat on vähendanud klaviatuuri suurust ,klahvid on väiksemad ning osad nupud ,mida tavaliselt ei kasutatagi on pandud numpadi alla(pilt üleval).
Nupud ise tunduvad näppude all väga mugavad ja allavajutus on palju sujuvam ,kui tavaliselt.Seega kui varem mängides oli palju klahviklõbinat kuulda ,siis praegu on seda tunduvalt vähem kuulda.
Macro nuppe on 5 tükki : 3 tükki space'i all ja 2 tükki numpadil : 1 ja 3 nupud.Võiks arvata ,et vahepeal kogemata ikka vajutad nupu alla ,kuid disain on niiviisi kujundatud ,et seda kogemata ei saa juhtuda.Ise ei kasuta ,eriti Macro nuppe ,kuid kui kasutan ,siis ei ole vaja neid kaugelt otsida -väga mugavas kohas.
Roccati software'iga saab siis määrata Macro nuppudele terve hunniku erinevaid klahvivajutusi.Saab teha ,kas ise Macrosid,teha shortcut'i (shift/alt/ctr/win + puuduvad nupud.(Saab teha ühe nupuvajutuse alla ctrl-alt-delete ) panna stopperi ,teha käsklusi mingile multimeedia playerile (WMP,VLC,Winamp,iTunes), Internet explorerile või saab hoopistükis nupu välja lülitada.
Klaviatuuri all on väga hästi pidavad kummipadjad ja loomulikult nagad ,millega saab klaviatuuri kõrgemale tõsta(ei oska neid paremini kirjeldada).
Klaviatuur ise tundub olevat väga vastupidav ja sees peaks olema allpool metallplaat ,et klaviatuur puru ei läheks.
Ilus ja korralik disain
Software kergesti kasutatav
Klaviatuur ise võtab laual väga vähe ruum
Väga mugavad klahvid
Macro nuppude asetus ning nende paljude funktsioonide olemasolek
Libisemisvastased kummipadjad täidavad oma eesmärki väga hästi
Väga vastupidav
 Hind(nagu kõigil Roccat toodetel,kuid kvaliteet eeldab ka kõrgemat hinda)
(n)Pidevatele Numpad numbrite,noolteklahvide kasutajatele võib alguses raskusi valmistada õigel Mode'il olla ,et oleks aktiivsed vajalikud nupud või ,et saaks nendele vajutada ,kuid küll sellega ka kiiresti ära harjub
viimati muutis PVAliim 11.04.2010 11:57:41, muudetud 3 korda |
| Kommentaarid: 21 loe/lisa |
21 |
Nokia
Serverid.ee
11.04.2010 10:58:47
Mis see hind siis oli?
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
Anna tooli
| Kommentaarid: 367 loe/lisa |
301 |
Waltson
11.04.2010 13:09:17
Abikaasa kinkis sünnipäevaks kõneall oleva jupstüki. Peale ööpäevast kasutamist viisin poodi tagasi ja maksin väheke juurde ja võtsin täis-suuruses Razer Lycosa asemele.
Mis ei meeldinud:
- klahvid tekitasid kohutavat heli (a la 75.- eek Defender vms. klaver), see ei meeldinud ka naisele, kuna plädin oli läbi ukse magamistuppa kuulda
- hea pisike küll, aga kui on vaja numbreid, pg up, insert ja muid selliseid klahve korraga kasutada, siis on tulemuseks peavalu ja minu puhul ka hulk surnud närvirakke
- need tühiku all olevad macro nupud on väga hea mõte, aga võiks toimida tunduvalt kergema vajutuse peale, numpadil olevatele macrodele ei suutnud mina mingit asjalikku rakendust leida (ka mängus pole neist tolku, kuna mängitakse ju ikkagi hiire ja wasd-kombinatsiooniga)
- biosesse minek on ka paras läbi tagumiku hammaste parandamine
- selle raha eest võiks olla kogu klahvistik valgustatud, mitte paar yksikut klahvi
Meeldis:
- netis olevad ilusad pildid ja kena jutt, mis panid seda klaverit endale tahtma
| Kommentaarid: 16 loe/lisa |
16 |
PVAliim
11.04.2010 13:37:08
Endale küll hetkel meeldib see klaver.Ei ole probleeme trükkimisega,klahvivajutuse heli on minut arust ikkagi suht väike,Macrosid ma küll eriti ei kasuta ,kuid las nad olla siis.Macro nupud tühiku all on minu arust küll piisavalt kergelt vajutatavad Polegi vaja igale poole neid valgustusi toppida ju
21 |
alec
27.09.2010 13:41:56
WASD ja noolenuppude pealt hakkavad tähemärgid kuluma
Muus osas olen klaviatuuriga väga rahul (1 aasta omanik olnud) ja võtaks veel ühe kui midagi juhtub.
_________________ You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives |
| Kommentaarid: 23 loe/lisa |
22 |
maalane
27.09.2010 14:56:48
Ise kasutanud seda pea 6 kuud. Kõik on super ainult pöidla macro nuppude kvaliteet , kuna raske vajutada(nagu mõne dvd/digiboxi nupp mis töötab plõksuga). Võinuks siis teha nad samad nagu esc nupp- suurem ja pehmem vajutada ning natuke kõrgem profiil. Muidu annaks hindeks 5+, kuid pöidla nupud võtavad sellest palli maha ja minupoolt 5- sellele. Tuli meelde veel üks pisiviga, mis vahest segab- klahvi tähed on profiilsed, mis vahest ärritavad, samas kui värv ära kulub, siis tunned klahvi ikka ära
kes numpadi kasutavad tihti, siis hoidke sellest klaverist eemale
| Kommentaarid: 34 loe/lisa |
PVAliim
28.09.2010 13:43:41
| Ise olen ka siiamaani selle omanik.Suuruse poolest on igatahes küll väga pluss.Võtab laual vähe ruumi ja samas saab sellega kõik tavalise klaviatuuri asjad ära aetud.Macro nuppude koha pealt kasutan ise playeri ja heli jaoks.Ehk siis heli mute,playeri kerimine edasi-tagasi,muusika kinnipanemine ning uuesti alustamine.
21 |
