Crow
25.03.2010 19:57:45
Nokia X6 16G |
Selline tagasihoidlik föön siis turul.
Key features:
* Quad-band GSM support
* Tri-band 3G with HSDPA support
* 3.2" 16M-color TFT LCD 16:9 capacitive touchscreen (360 x 640 pixels)
* Symbian S60 5th edition UI
* ARM 11 434 MHz CPU, 128 MB of RAM memory
* 5 megapixel autofocus camera with dual-LED flash
* VGA video recording at 30fps
* Wi-Fi 802.11 b/g, UPnP technology
* Built-in GPS receiver
* 32GB built-in storage
* FM radio with RDS
* Bluetooth and USB (standard microUSB connector) v2.0
* 3.5mm standard audio jack
* Very good audio quality
* Proximity sensor for screen auto turn-off
* Accelerometer sensor for automatic UI rotation and motion-based gaming
* Stereo speakers
* TV out
* "Comes with music" edition gives you a year of all-you-can-eat music subscription
* Landscape on-screen virtual QWERTY keyboard
* Ovi Maps 3.0 Touch
* Further Ovi and MySpace service integration (direct image and video uploads)
* Most regional retail packages include a set of the great Nokia WH-500 headphones
Main disadvantages:
* X6 is still quite pricey (around 500 euro at the time of writing)
* UI is still immature with somewhat inconsistent user experience
* Touch web browser not quite polished and with dodgy Flash support
* No voice-guided navigation license
* No office document viewer preinstalled
* Doesn't charge off microUSB
* Very poor sunlight legibility
* Slow image gallery
* No DivX/XviD support for the video player
* No microSD card slot (as a connectivity solution)
Copy/past ---> http://www.gsmarena.com/nokia_x6-review-439.php
Elioni Andmed https://pood.elion.ee/epood.asp?t=1365&tt=186&ttt=10858&ta=&t2=&tp=&ug=true&Smenyy=1349
viimati muutis Crow 29.03.2010 00:55:13, muudetud 2 korda |
maxtor1
25.03.2010 21:03:13
| Päris hea näeb välja. Kui saaks oma vastumeelsusest puutetundlikkuse vastu(telefonide juures) üle võiks täitsa mõelda sellise peale.
91 |
WäntWõll
make.believe
25.03.2010 21:03:48
Kõik ilus aga kui rahapeale väga pahane pole siis võiks vaadata nede linkide alla
Aga noh eks ta helistab ikka ja mis kõige tähtsam siis on peal kirjas Nokia.
300 |
its2cold
25.03.2010 21:06:35
Lõpuks jälle üks telefon, mida endale tahaks!
Kahju ainult, et Nokia maailmas juba kaks aastat pea mingit innovatsiooni pole toimunud!
175 |
25.03.2010 21:08:51
noh mis see 6k ikka välja käia on
ma vaatan, et mobla hinnad ikka langenud võrreldes paari aastaga, kui iga uus nokia n seeria mobiil oli kohe 10990.- krooni
WäntWõll
make.believe
25.03.2010 21:12:40
Aga mida nad ikka tegema peaksid kui sulle serveeritakse täpselt sama telefoni 12 eri korpusega aga täpselt sama sisuga
See lause ütleb kõik enamvähem
See "pea mingit" päädibki maemo üllitisega mille tulevik võrreldes Androidiga üsna tume.
300 |
olafsand
25.03.2010 22:06:40
| wanawoll, Sinu pakutud spoileris oleval mudelil samamoodi symbian peal, ehk siis mitte midagi uut võrreldes X6-ga. Muidugi välimus ja kaamera suutlikus on väga erinevad.
| Kommentaarid: 63 loe/lisa |
60 |
zaitz
25.03.2010 22:17:21
| Pmst ongi see facelifted 5800, ma ei saa aru miks Nokia nendes aeglastes prosedes nii kinni on.
| Kommentaarid: 36 loe/lisa |
34 |
25.03.2010 23:04:07
| zaitz kirjutas: |
| Pmst ongi see facelifted 5800, ma ei saa aru miks Nokia nendes aeglastes prosedes nii kinni on. |
Ladu on vaja ju ennem tyhjaks müüa, ennem kui hakkad uut kraami peale tootma
Ja pealegi kui neid saiu ostetakse, milleks siis parema prose peale üle minna. Eks enamus rahvast arvavadki, et nutifonid peavadki sellised "kiired" olema
Crow
25.03.2010 23:25:12
Panin Nokia X6 võrdlusse Emt lehekülje peal N97, N900 siis tulemus oli päris huvitav. link
25.03.2010 23:41:21
| Crow kirjutas: |
| Panin Nokia X6 võrdlusse Emt lehekülje peal N97, N900 siis tulemus oli päris huvitav. link |
midagi sel lingil viga 2x n900 ja Apple iPhone 3G 16GB
Kardan, et ei saa linkida seda
WäntWõll
make.believe
26.03.2010 02:45:49
| olafsand kirjutas: |
| wanawoll, Sinu pakutud spoileris oleval mudelil samamoodi symbian peal, ehk siis mitte midagi uut võrreldes X6-ga. Muidugi välimus ja kaamera suutlikus on väga erinevad. |
seda ma mõtlesingi,sama OS aga kordades viisakamal kujul (kaamera ja prose eesotsas).
Sisemälu pole mingi näitaja
300 |
olafsand
26.03.2010 11:33:01
Sisemälu ma ei ajagi taga. Tegelt on nii, et kolin nüüd siit Vivaz`e teemasse üle. Aitab OT-st
60 |
McCoffin
28.03.2010 18:32:06
Sai just tunnike näpitud, 5800 vs X6 võitluses tuleks võitjaks X6. Sisseehitatud mälu peale saab üle USBi asju kiiremini kopeerida, telefoni enda põhimälu (c: ketas) on ka mõnusalt suur (256MB). Kuna touchscreeni tehnoloogia asub samas lahtris iPhonega, on ka kasutajakogemus mõnusam - kui 5800 kasutades peab näpuga surfides sageli korduvalt "klikkima", sest lihtsalt esimene puude jäi registreerimata ja ka täpsus pole parimate killast, siis X6 ekraan on ikka ehtne puute peale reageeriv ekraan - isegi QWERTY ekraanis sõnumi toksimine oli täiesti tehtav, mis mul 5800ga kuidagi ei taha välja kukkuda, pean alati pulka kasutama. Kuna asjad saab aetud esimese puutega, siis tundub ka telefon kiirem:P X6l puuduvad 5800 omased randid ekraani servades, seega igasugune äärtes scrollimine on mõnusam tegevus ja ka mustust ei kogune serva alla.
Huvitav on see, et uuematel Nokia touchidel on kõikidel pakist võetuna teema efektid sisse lülitatud, sama kehtib ka X6 puhul, mu meelest see prose kiirus ei õigusta efektide kasutusele võtmist, telefon uimerdab siis mulle vastuvõetamatult.
Mulle meeldib see, et tekstisisestuslahtrites on teksti font oluliselt suurem, kui 5800l. Ehk tuleb see uuendus ka 5800le kunagi. Rakenduste menüü all on eraldi Installitud Rakendused kaust, mis on hea, kuna ise peale pandud ja süsteemi enda rakendused on nõnda lihtsalt eristuvad. Tagasi on ilmunud ka Symbiani Kontor kaust, mida minu meelest 5800 default menüüs ei ole.
Telefon on raskem kui 5800, seda on tunda ka käega katsudes. Kui muidu visuaalselt on X6 stiilsema ja tagasihoidlikuma olekuga (pikem ja õhem), siis käega katsudes häirib tugevalt tagakaane all olev tühimik, mis tekitab näotult odava telefoni tunde. Ega 5800 selle koha pealt ka ei hiilga, krõbisevat plastmassi on ka sellel kõvasti, kuid X6 puhul tekib vahest tunne, et tagukaas on lihtsalt lahti ja tuleb tahtmine seda kogu aeg kontrollida ja kinni panna. EMTis oli letitelefonil seesama tagukaas lihtsalt telefoni küljest lahkunud, seega on ilmselgelt nõrga kohaga.
GPS toimib samahästi kui 5800l, kui mitte paremini.
Puudub USB kaabli laadimine endiselt, kaasasolev kaabel on lisaks u 15cm pikk.
Kokkuvõtvalt:
+ekraani tundlikkus
+sisseehitatud mälu (16GB on enam kui piisav, võimalus osta ka 32GB versioon - +1500 eeku umbes), jääb ära mälukaardiga jauramine
+väline disain
+/- 5MP kaamera ei muutnud pildi kvaliteedis suurt midagi, sama halb kui 5800 (Symbian üldiselt).
-tagumine kaas vähendab muidu soliidse telefoni esmast üldmuljet ja jätab odava mulje.
-hinnaklass võiks olla alla 5k
-peale tekstisuuruse muutuse puudub igasugune uuenduslik pool Symbiani poole pealt
-puudub endiselt USB laadimine
| Kommentaarid: 52 loe/lisa |
50 |
olafsand
28.03.2010 22:57:56
McCoffin, väga hea ülevaade
60 |
Vahur
28.03.2010 23:19:20
388 |
Crow
29.03.2010 00:57:51
Vahetasin ära.
Le Inc
29.03.2010 10:51:26
| Väljamaa ülevaadetes ka kurdetakse prose uimamise üle. Tänapäeval võiks ikka ~1 GHz kanti nad olla. Muidu olevat enam-vähem telefon.
| Kommentaarid: 56 loe/lisa |
54 |
Alif
30.03.2010 09:26:29
| X6'l on capacitive touchscreen, tänu millele on ekraani puutetundlikus väga hea, kuid kahjuks ei saa seda kasutada naised, kellel on pikad küüned, st et ekraan reageerib ainult sõrmeotsa puudutusele.
| Kommentaarid: 30 loe/lisa |
26 |
olafsand
30.03.2010 09:28:14
| ot: |
| kas 5800-l on mingit teist tüüpi ekraani tundlikus siis? |
60 |
Alif
26 |
olafsand
30.03.2010 09:48:52
Üldjoontes on capacitive ekraan parem?
60 |
Alif
30.03.2010 09:52:02
| Kui sa küüsi puudutamiseks ei kasuta, siis küll jah - tundlikus on parem
26 |
weasel
30.03.2010 09:57:10
McCoffin, kust neid animatsioone välja saab lülitada?
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
olafsand
30.03.2010 09:57:30
| ot: |
ei ma küüsi ei kasvata. Mehel pole need vajalikud . Aga kui tundlikus on parem kui 5800-l, siis on see tundlikus ikka väga hea nähtavasti. 5800 tundlikus ka mu meelest väga hea |
weasel, lähed teemade alla. Seal siis konks selle teema ees, mis aktiivne. Alt vasakult valikud...teema efektid...lülita sisse/lülita välja.
viimati muutis olafsand 30.03.2010 09:59:54, muudetud 1 kord |
60 |
weasel
30.03.2010 09:59:19
| weasel kirjutas: |
| McCoffin, kust neid animatsioone välja saab lülitada? |
Leidsin.
Kui võrrelda iPhonega, siis on tundlikkus täpselt sama. Mingit vahet pole. Symbiani opsys on see, mis hetkel ei luba 5/5-st hindeks anda.
Alif
30.03.2010 09:59:55
| Capacitive touchscreen on ka kriimustuskindel ning kriimude pärast muretsemine ja kaitsekilede kleepimine on minevik
26 |
olafsand
30.03.2010 10:02:36
| Alif kirjutas: |
| Capacitive touchscreen on ka kriimustuskindel ning kriimude pärast muretsemine ja kaitsekilede kleepimine on minevik |
Kuda see tehtud on? Mingi spets kriimukindel klaas? Samas Iphone peale kleebitakse küll kaitsekilesid. Tollel vist ka ju capacitive ekraan?
60 |
weasel
30.03.2010 10:03:44
| Alif kirjutas: |
Ma panin just kile peale, sest ametlikes specides küll seda kirjas pole, et kriimustustekindel on.
Alif
26 |
olafsand
30.03.2010 10:15:13
Alif, sul täiesti õigus Lisaks siis esimene Nokia capacitive ekraaniga.
60 |
kuunar
30.03.2010 10:42:58
| Kuigi see klaas võib kriimukindel olla tekivad mingi aja jooksul need sinna, seepärast ka iphonedele neid kilesid kleebitakse.
| Kommentaarid: 14 loe/lisa |
Alif
30.03.2010 10:58:24
Iphone'l on ka kriimustuskindel klaas. Kuid samas parem karta kui kahetseda.
Väike video, mis tõestab kui kriimustuskindel Iphone on: http://vimeo.com/344087
26 |
weasel
31.03.2010 09:54:45
Ovi store ajab mingit juttu, et pood pole sellele seadmele saadaval, kuigi paar päeva tagasi sai seal käidud... Kellelgi veel sama jama?
Crow
31.03.2010 23:38:39
Need Nokia Stereo Headset WH-701 valged & musta värvi kõrvaklapid, mis saab ostes kaasa on täis jurad .
Miks ei võinud ka 16gb X6 ostes kaasas olla Nokia - WH-500 Wired Stereo Headphones .
nagu 32GB Nokia X6 on.
KrisVr
01.04.2010 00:39:16
| Mulle meeldivad just need nööpkuularid rohkem telefoniga, teised meeldivad mulle arvuti taga olles. Ringi käies ja telefoniga mussi kuulates tahad vahest, et üks kõrv oleks vaba, sellepärast mulle esimesed meeldivadki. Ise oman ka neid, NOKIA 5530-ga sain.
Crow
03.04.2010 00:35:16
| DefXtreme kirjutas: |
| Mulle meeldivad just need nööpkuularid rohkem telefoniga, teised meeldivad mulle arvuti taga olles. . |
Kahjuks need nööpkuularid ei tee häält nagu oleks vaja. Selle koha pealt on Nokia Fail. On juu olemas ka nööpkuulareid mis on kõvasti paremad.
erkin
03.04.2010 16:57:26
Käisin esinduses näppimas. Väga positiivse mulje jättis. Ekraani tundlikkus on super. Pärast kui N97 kätte võtsin, ei tahtnud selle ekraan kuidagi puudutustele reageerida:-P
Muidu stiilne, väike ja õhuke. Muidu vaataks SE X10 või androidi poole aga kahjuks pole peale nokia teistel normaalset GPS softi. Mingid wisepilotid ja guugle mapsid mulle peale ei lähe, veel enam reaalajas üle M-interneti sikutajad.
| Kommentaarid: 34 loe/lisa |
29 |
Ra*
03.04.2010 17:12:30
Sain ka käed taha ja pettumus väga suur.
Kui piltide pealt tundus õhuke, tugev. Lootsin ala 5800't 6500c kestas, aga ei.
Sama jama plastik korpus nagu X3'l. Nupud ka justkui ligadi logadi.
Sisu okei... aga lihtsalt,ei meeldi,et ta nii "paks" ja plastik.
Viimased Nokia telefonid olnud 6500c ja E66 mil mõlemal mingi metallelement korpuses olnud ja seega plastiku peale väga üdlse ei taha minna.
| Kommentaarid: 135 loe/lisa |
123 |
Crow
03.04.2010 18:35:17
| Ra* kirjutas: |
Millised nupud on ligadi logadi ?
Ees all vaid üks riba (kõne vastu/lõpetamine, menüü) ja üleval (shortcut). Otsa peal (ON/OFF)(USB). Külje peal on tõesti 3 nuppu (+ -) ja manuaalne klahvi ja kuvari lukk , foto pästik.
Kokku siis 3 nuppu , 1 riba ja ekraani nurgas olev shortcut osa ja minu arust on nad kõik paigas, ei logise ja asukohad ning funksonaalsus täpne.
Paksuse kohta nii palju. Minu arust on see paigas.
Nokia X6 16g - 111.0 x 51.0 x 13.8mm
Nokia 5800 Xpress- 111 x 51.7 x 15.5 mm
Nokia 5800 Navigation Edition - 111 x 51.7 x 15.5 mm,
Nokia 6500 C - 109.8 x 45 x 9.5 mm,
Nokia E66 - 107.5 x 49.5 x 13.6 mm
Meeldimine on rohkem maitse küsimus.
erkin
03.04.2010 18:47:45
Mulle meeldib just, et laadimine on tavalise pulk pistikuga. Paljud on selle miinusena välja toonud. Laadima peab pidevalt ja kardan, et USB ei pea pikemas perspektiivis sellele vastu. N900 oli sellega probleeme ja usun, et neid tuleb ka edaspidi, kui telefonid vanemaks hakkavad saama.
viimati muutis erkin 03.04.2010 23:13:09, muudetud 1 kord |
29 |
ivokas
04.04.2010 10:48:22
| 1320 mAh liitiumaku peab ooterežiimil vastu veidi enam kui 16 päeva, ning kõneldes 8,5 tundi (GSM). Muusikat saab kuulata ühe laadimiskorraga 35 tundi järjest, videot (640 x 480 px, 25 fps) saab vaadata 3,5 tundi järjest. Video salvestamise aeg on piiratud aku kestusega 3,5 tunnini. |
See jutt on tõenäoliselt kusagilt "välja imetud"?
_________________ Reisijate ja fekaali vedu kahekorruselise bussiga.
Praepelmeenid ja Vana Tallinn suudavad nii mõndagi muuta! |
| Kommentaarid: 65 loe/lisa |
61 |
Mario.
04.04.2010 10:52:52
| Ei pruugi.
6 :: |
217 |
AlarT
04.04.2010 22:13:31
Tekkis ka tahtmine uus telefon osta ja piltide peal on X6 töesti normaalse välimusega aga kui poes veidi näppisin siis oli pettumus suur.Päriselt on tõesti paras plastiku kärakas ja see puuteekraan ei äratanud erilist usaldusväärsust.Tulemus - ostsin E52 odavam ja viisaka välimusega.
05.04.2010 15:56:23
| ivokas kirjutas: |
See jutt on tõenäoliselt kusagilt "välja imetud"? |
Pigem saavutatav nn "ideaaltingimustes"
M: HP Elitedesk 800 G3 SFF
| Kommentaarid: 756 loe/lisa |
567 |
McCoffin
05.04.2010 17:13:53
Plastine on jah, aga selle saaks vist hea tahtmise korral paberi ja teibiga parandada - viga on tagumises aku kattes, millel jääb aku ja katte enda vahele liiga palju õhuruumi.
Muidu puuteekraan on sellel äge, kuid...ülejäänud osas täpselt sama mis 5800XM ja ta lihtsalt ei vääri seda hinda, mida ta eest küsitakse. Muidugi kui 5800 müüdud, siis jällegi ei oskaks samast vallast jällegi paremat pakkuda - N900 tundub ulme ja kallis (liiga toores toode), N97 on ka nii ja naa. Nokk kinni saba lahti:)
50 |
KrisVr
05.04.2010 17:17:16
Ma vaataks midagi SAMSUNG-ilt või SE-lt. NOKIA S60 UI võiks parem olla, sellega ongi NOKIA teistest maas, muidu täisa .
WäntWõll
make.believe
05.04.2010 17:26:22
Selle asemele tulebki võtta Android OS, mais on veel saabumas X10 Mini mis jääb kenasse hinnaklasssi ca.4500.-
300 |
erkin
05.04.2010 22:38:29
| Ei tea miks elisas, tele2 ja teistes telefoni poodides X6 ei müüda?
29 |
WäntWõll
make.believe
05.04.2010 23:07:53
erkin, elisas on valikusse võetud ja müüki tuleb järgmine nädal
300 |
