praegune kellaaeg 18.11.2026 02:13:05
Nokia
Serverid.ee
13.03.2010 13:21:25
C#: A2S_PLAYER Counter-Strike Query probleem, ei sa kõiki andmeid loetud. |
Tere,
Nimelt probleem selline, et kui serveris on näiteks 6 inimest, siis ilmub ainult nimekirja 3, kuigi kõik 6-e andmed saadakse kätte.
Query kohta siit info võetud siis: http://developer.valvesoftware.com/wiki/Server_queries#A2S_PLAYER
Nende 3 isiku kohta serverit tulev info on täiesti korrektne (score,time,name), aga teised 3 on kuskil kaduma läinud ja aru ei sa kuhu nad kaovad.
Täpsemalt koodijupist siis:
private SourceQuery ParsePlayers(byte[] resp)
SourceQuery ret = new SourceQuery();
var Players = new ListView();
ret.Type = resp[4];
ret.NumPlayers = resp[5];
int NumPlayers = ret.NumPlayers*2;
int pNR = 0;
int Offset = 6;
for (int i = 0; i < resp[5]; i++)
var PlayerItem = new ListViewItem();
PlayerItem.Name = "NR";
PlayerItem.Text = resp[Offset++].ToString();
var Name = new System.Windows.Forms.ListViewItem.ListViewSubItem();
Name.Name = "Score";
Name.Text = GetString(resp, Offset, resp.Length);
PlayerItem.SubItems.Add(Name);
Offset += Name.Text.Length + 1;
var Score = new System.Windows.Forms.ListViewItem.ListViewSubItem();
Score.Name = "Score";
Score.Text = BitConverter.ToInt32(resp, Offset).ToString();
Offset += 4;
PlayerItem.SubItems.Add(Score);
var PlayTime = new System.Windows.Forms.ListViewItem.ListViewSubItem();
PlayTime.Name = "Time";
PlayTime.Text = new TimeSpan(0, 0, (int)BitConverter.ToSingle(resp, Offset)).ToString();
Offset += 4;
PlayerItem.SubItems.Add(PlayTime);
pNR += 1;
Players.Items.Add(PlayerItem);
Vastus mis serverist tuleb (Wiresharkiga püüdsin kinni siis)
....U........D..HDET #kz-baltic......N.D.T6ts........D.Nc-T > Mblwke.wOw~[Lj ReCcc 242.....N.{D.2rgePaukugeMaNoob!........D.G.<3........D.juku.......mD.Cru$her.....Q0.D.Glennu (^.^') Steamer ^^.....@..A.Ainsuuu ^^........C.iRoawR........C.kar7i......D.C.K0nKs.-wTf-........B |
Ehk oskab keegi öelda, kuda asja lahendada? Ise juba mitu päeva pusinud ja ei leia korrektset lahendust veel siiamaani, kui lisada 2 for tsükklit, siis tekib õige number mängijaid nimekirja, aga need pooled mis juurde tulevad, nendel on jällegi kõik info puudu siis.
Tänud
EDIT: Hetkel ta loebki täpselt pool alati, kui on 4 mängijat, siis kuvab 2, 12 =6 jne..
EDIT: Sain korda lõpuks Tänud anyways.
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
